Wallie betaalmiddel
  • djordyh
  • 19 juli 2010 om 17:26
  • djordyh
    Hey,
    Ik was bezig met een wallie betaalmiddel via targetpay.com. Dit is allemaal gelukt etc maar er is één probleem. Als ik naar de wallie betaalmethode gaat dan krijg ik:
    Transaction ID: 13036401
    URL: https://www.targetpay.com/wallie/start.php?trxid=13036401
    Dus dan zou je de URL moeten kopiëren om naar de betaal scherm te gaan?? Hoe zorg ik voor een redirect in dit script?? :
    * Ideal example on how to use the ideal class!
    * SVE
    * 11-01-2009
    ini_set ( 'display_errors', '1');
    include ( 'TargetPayWallie.class.php');
    # Set your rtlo ere
    $iRtlo = 57591;
     if ( !isset ( $_GET['ShoppingCartID'] ) ) {
        # To initiate a payment, initiate the class
        $oWallie = new TargetPayWallie ( $iRtlo );
        # Set wallie amount in cents so 500 cent will be 5 euro
        $oWallie->setWallieAmount ( 150 );
        # Set wallie description
        $oWallie->setWallieDescription  ( 'Buy donator');
        # Set return url, wich should return on succes
        $oWallie->setWallieReturnUrl ( 'Linkweggehaald' );
        * OPTIONAL PARAMETERS FOR WALLIE
        * UNCOMMENT IF YOU WANT TO USE
        $oWallie->setWallieCountry ( '31' ); // Set the country   (optional)
        $oWallie->setWallieLang ( 'NL' ); // Set wallie language (optional)
        $oWallie->setWallieCurrency ( 'EUR '); // Set wallie currency ( optional )
        # Now we can initiate the payment
        $aReturn = $oWallie->startPayment();
        # This is the transaction id
        $intTrxId = $aReturn[0];
        # this will be the bank url that will rederect to the bank.
        $strURL = $aReturn[1];
        # For check we can echo it here. (uncomment if you want to see. )
        echo 'Transaction ID: '. $intTrxId . '<br/>URL: '. $strURL;
        # Rederect your user now to:
        header ( 'Location :'. $strURL );
    * This function will validate the payment
    # ?action=vtrxid= 'trxid'
    if ( isset ( $_GET['ShoppingCartID'] ) ) {
        # Init the class
        # Test mode? 1 = test mode, 0 = normal
        $iTest = 0;
        # Once, only validate the payment once?
        $iOnce = 1;
        if ( $oWallie->validatePayment ( $_GET['ShoppingCartID'], $iOnce, $iTest  ) == true ) {
    		mysql_query("UPDATE `speldata` SET `cashmoney`=`cashmoney`+'2500000' WHERE `id`=".ID." LIMIT 1") or die(mysql_error());
            mysql_query("UPDATE `status` SET `donateur`=`donateur`+'1' WHERE `id`=".ID." LIMIT 1") or die(mysql_error());
            echo 'Your payment was successful';
        else {
            echo 'Payment failed.';
    Alvast bedankt!
    Djordy.
  • Superior
    • 19 juli 2010 om 17:41
    [func]header[/func]
  • djordyh
    • 19 juli 2010 om 18:10
    Ja maar dat werkt toch niet zo? Want de script maakt de url aan? Dus hoe kan ik dat dan doen?
    Djordy.
    • 19 juli 2010 om 20:23
    Dit werkt volgens mij:
    <meta http-equiv="refresh" content="0;URL=<?php echo $strURL; ?>" />
    En dan de content="0; veranderen met het aantal seconden dat er moet worden doorgelinkt.
    Je mag header namelijk NOOIT gebruiken als je ervoor al een HTML output hebt.
    Plaats deze code op lijn 51, en dan NIET in de php tags plaatsen!
    Dus eerst ?> nu die code, en dan weer <?php.
    Veel succes,
    Lars
  • Linkforsoad
    • 19 juli 2010 om 22:00
    Waarom niet gewoon iets als
    require("URL");
    op de plek waar het venster moet komen. Of even iFramen, wat niet echt een top oplossing is natuurlijk...
    Oh, ja, en een redirect kan gewoon met de META tag die Lars geeft.
    Tijdzone: EDT
  • Axl_H
    WAN\'T TO LEARN SOMETHING
    • 19 juli 2010 om 22:11
    header( "Refresh:5; url=hierjeurl.bla" );
      echo 'You\'ll be redirected in about 5 secs. If not, click <a href="$">here</a>.';
    Ik gebruik t zelf ook
  • Superior
    • 19 juli 2010 om 22:16
    Citaat van Axl_H
    error: Line 2 ;)
  • Mokerr
    Webspetter.nl
    • 19 juli 2010 om 22:50
    Sup @ Lijn 2 moet einigen met '; en niet met .;
    - Edit;
    Ow. Ik snap al wat je bedoelt. -
  • djordyh
    • 20 juli 2010 om 10:20
    Citaat van larsisgoed9
    Thx het werkt nu!
    Djordy.
  • MauriceB
    MBDGames.info
    • 20 juli 2010 om 14:19
    meta werkt niet bij alle browsers, neem IE7 of IE8 daar wil het nog wel eens niet werken..
    Boze berichten van klanten/spelers hoopt niemand probeer gwn java ofz.
    Example:
    <script>
    setTimeOut("location.href='SITE.nl'",1000);
    Snel gemaakt kan fouten bevatten.
    Project gotkilled.mbdgames.info
    Status 35%
    Door MBDGames
  • W0utR
    GTFO
    • 20 juli 2010 om 15:14
    Ten eerste is het javascript, java is iets totaal anders.
    En wat als iemand zijn javascript uitschakelt?
    Dan gaat jouw stukje niet werken.
    Don\'t like me?
    • 20 juli 2010 om 20:41
    Die van mij gebruik ik op m'n hele site.
    Ik heb m'n site getest in:
    - IE 6,7,8
    - Chrome, Iron
    - Firefox
    En daar werkt het gewoon goed, dus no problem ;)
    Header moet je niet gebruiken op je site (php functie), omdat je meestal ervoor een output hebt, en dan krijg je errors en/of warning ;)
    Lars
