  • Verschillende domeinen
Inloggen
  • SvenB
  • 14 juni 2012 om 10:37
  • SvenB
    Hoi,
    Zit met een inlogfout! Eerst de html, daarna de php!
    <strong>Inloggen</strong><br /><br />
    Login met je gegevens waarmee je je hebt geregistreerd om officieel toegang te krijgen tot het systeem!<br /><br /><br />
    <table width="300" border="0" align="center" cellpadding="0" cellspacing="1" bgcolor="#CCCCCC">
    <form name="form1" method="post" action="?p=checklogin">
    <td>
    <table width="100%" border="0" cellpadding="3" cellspacing="1" bgcolor="#FFFFFF">
    <td colspan="3"><strong>Inloggen </strong></td>
    <td width="78">Email:</td>
    <td width="6">:</td>
    <td width="294"><input name="myusername" type="text" id="myusername"></td>
    <td>Password</td>
    <td>:</td>
    <td><input name="mypassword" type="password" id="mypassword"></td>
    <td>&nbsp;</td>
    <td>&nbsp;</td>
    <td><input type="submit" name="Submit" value="Login"></td>
    </td>
    </table><br /><br />
    // username and password sent from form
    $myusername=$_POST['myusername'];
    $mypassword=$_POST['mypassword'];
    $encrypted_mypassword=md5($mypassword);
    // To protect MySQL injection (more detail about MySQL injection)
    $myusername = stripslashes($myusername);
    $mypassword = stripslashes($mypassword);
    $myusername = mysql_real_escape_string($myusername);
    $mypassword = mysql_real_escape_string($mypassword);
    $sql="SELECT user_email, user_wachtwoord FROM stamperz_users WHERE user_email='$myusername' and user_wachtwoord='$encrypted_mypassword'";
    $result=mysql_query($sql);
    // Mysql_num_row is counting table row
    $count=mysql_num_rows($result);
    // If result matched $myusername and $mypassword, table row must be 1 row
    if($count==1){
    // Register $myusername, $mypassword and redirect to file "login_success.php"
    session_register("myusername");
    session_register("mypassword");
    header("location:login_succes.php");
    else {
    echo "Je hebt foute gegevens ingevoerd! Probeer het nogmaals";
    Hij laat dus de echo zien dat ik continu foute gegevens ingevoerd heb.
  • Malik
    • 14 juni 2012 om 13:37
    Probeer is de variabelen in query te wijzigen in een login dat wel klopt met je database.
    Alhoewel ik je manier van wachtwoord vars vreemd vind.
    (vanaf gsm)
  • ZiraX
    IT Expert
    • 14 juni 2012 om 13:41
    Je gebruikt wel extreem oude PHP..
    $_SESSION['sessienaam'] = 'inhoud';
    is al voldoende.
    Ook snap ik niet waarom je bovenaan 2x password hebt in een var terwijl eigenlijk alleen de encrypted belangrijk is.
    Zo zijn er nog wel meer foutjes.
    1) Eigenaar & CEO // iSenses
  • Laura
    Lady
    • 14 juni 2012 om 16:52
    Je zegt dat je een inlogfout hebt, maar welke foutmelding krijg je dan juist?
    Ik zou je code als volgt maken:
    session_start();
    if(isset($_POST['myusername'])){
    //start your connection to the database first!!!
    $myusername=mysql_real_escape_string(stripslashes($_POST['myusername']));
    $encrypted_mypassword=md5($_POST['mypassword']);
    $sql="SELECT 1 FROM stamperz_users WHERE user_email='".$myusername."' and user_wachtwoord='".$encrypted_mypassword."' LIMIT 1";
    $result=mysql_query($sql) or die(mysql_error());
    $count=mysql_num_rows($result) or die(mysql_error());
    if($count==1){
    $_SESSION['myusername'] =$myusername;
    $_SESSION['mypassword'] =$encrypted_mypassword;
    else {
    }else{
    <form name="form1" method="post">
    <td>
    <td>Password</td>
    <td>:</td>
    <td>&nbsp;</td>
    <td>&nbsp;</td>
    </td>
    <?php } ?>
    Groetjes,
    Laura
    x
    Groetjes,
    Laura
    xxx
  • ozziePHP
    • 14 juni 2012 om 16:56
    Beste laura dat klopt niet helemaal ! @ts , Waar geef je aan dat je html gebruikt ? Mischien handig om html5 te gaan gebruiken ?
    Je kan als iemand op de post button ramt het script laden. Om je html er zo in te plempen gaat ook niet helemaal goed wel.
    Als je html5 gebruikt denk dan om de verlpichte taggs <!doctype html> <html> , meta charset = utf-8.
  • Laura
    Lady
    • 14 juni 2012 om 17:00
    ozziePHP: als je kan aantonen wat er verkeerd aan is, verander ik het.
    Maar voor zover ik weet werkt dit gewoon.
    Verder is voor beginners html5 zeker geen optie, maak je het alleen nog ingewikkelder voor hem.
    Laat eerst zijn script werken en dan kun je het altijd nog omzetten naar html5.
    Groetjes,
    Laura :x
    Groetjes,
    Laura
    xxx
  • ozziePHP
    • 14 juni 2012 om 17:04
    Dat klopt niet helemaal html5 is gemakelijk zeker als je al html gewoon kent. Ik zal zo even dit verbeteren met html 5 gebruik.
    Edit:
    session_start();
    if($count==1){
    else {
    }else{
     echo¨ <!doctype html>
    <html>
    <head>
    	<meta charset="UTF-8" />
    <body>
    <strong> Inloggen </strong>
    <form action=¨post.php¨>
     Gebruikersnaam : <input type=¨text¨ name=¨Gebruikersnaam¨ />
     Wachtwoord     : <input type=¨password¨ name=¨Password¨ />
                      <input type=¨submit¨ value=¨Login¨ />
    </body>
    </html>
    U moet nog wel de opmaak even verbeteren dit is gewoon simpel + form action moet worden veranderd ! Dit heb ik zo geschreven dat je 2 aparte file´s krijgt.
  • thexerox
    thexeroxprojects.be
    • 14 juni 2012 om 18:03
    Citaat van ozziePHP
    Edit:
    session_start();
    if($count==1){
    else {
    }else{
    <html>
    <head>
    <body>
    </body>
    </html>
    Waarom zou je daarvoor HTML5 moeten gebruiken? Je gebruikt geen enkele toegevoegde waarde van HTML5. Buiten het feit dat je geen doctype aangeeft (wat overgens niet meer moet in HTML5 en dus klopt).
    Op zich is het idd niet slecht dat je als beginner de dag van vandaag meteen met HTML5 start, maar zoals ik al eerder zei is dit voor dit specifieke script niet echt nodig. :cheer:
  • ZiraX
    IT Expert
    • 14 juni 2012 om 19:26
    Zoiezo klopt zn scipt niet, en heeft html5 hier niets mee te maken.
  • jopitan
    • 14 juni 2012 om 21:39
    Laura, je doet het wel goed. Het is alleen ozziePHP die zwaar onervaren is naar mijn mening. Overigens gebruikt hij exact dezelfde code als jij in zijn verbetering met HTML5. Daarnaast geeft hij in zijn verbetering niet eens echte HTML5 code en valt het gewoon onder bodyloze HTML. Hij heeft nu de stylesheet en de alignment, die er standaard in zou zitten met de tables, uitgehaald. Wat dus gewoon een flut pagina oplevert.
    Er zijn wel nettere manieren zoals classes en methods, maar dat is voor dit inderdaad totaal niet van belang.
    [offtopic]Allemaal waardeloze posts van ozziePHP, zonder onderbouwing whatsoever. De admin die hem heeft verbannen verdient een pluim. :}[/offtopic]
  • SOSjunk
    • 14 juni 2012 om 22:37
    Citaat van thexerox
    Doctype word nog steeds in html gebruikt hoor ! , jopitan hij laat een opzet zien zonder opmaak waarom zo kinderachtig reageeren. Doe het zelf nu eens beter dan als je het beter weet.
  • jopitan
    • 14 juni 2012 om 23:01
    Citaat van SOSjunk
    Ik reageer niet kinderachtig ik zeg gewoon waar het opstaat. Trouwens stop eens met proxies gebruiken om nieuwe users aan te maken. Beetje kinderachtig (en levenloos) om zo je ban te omzeilen.
    • 16 juni 2012 om 12:08
    Goed gezegd Jopitan.
    Deze 'scarface' blijft terugkomen met fake accounts.
    Verder biedt zijn script inderdaad geen meerwaarde en is het niet eens goed html 5.
    Laura haar script is tot nu toe nog het beste antwoord :cheer:
