    Syntax 28 juli 2026 om 15:47
help:)
  • dinand
  • 3 juli 2010 om 20:19
  • dinand
    ik heb de CC source en heb hem online.... maar ik krijg dan dit...
    Offline
    Beste bezoeker/speler.
    CrimeClubs heeft een paar update's we zetten het nu online. We proberen zo snel mogelijk weer online te zijn.
    CrimeAddicted Team
    dit is de config
    [offtopic]<?php /* ------------------------- */
    /*** Global Settings ***/
    $title	= CrimeAddicted;
    $url	= www.CrimeAddicted.com;
    include("ubb.inc.php");
    include("ubb.php");
        if(!(@mysql_pconnect("localhost","*****","*****") && @mysql_select_db("felmen_crimeclub"))) {
        print <<<ENDHTML
    <head>
    <title>CrimeAddicted</title>
    <style type="text/css">
    body {
    	background-color: #323233;
    body,td,th {
    	color: #FFFFFF;
    	font-family: Verdana, Arial, Helvetica, sans-serif;
    	font-size: 11px;
    	line-height: 140%;
    </style></head>
    <body>
    <br>
    <br>
    <br>
    <br>
    <br>
    <br>
    <br>
    <table width="500" border="0" align="center">
        <td valign="top"><p align="center"><img src="IMG/ca.png" alt="CrimeAddicted" width="418" height="81" /><br>
    <b>Offline</b><br>
    Beste bezoeker/speler.<br>
    <br>
    CrimeAddicted Team
    </p>
        </td>
    </body>
    </html>
    </html>
    ENDHTML;
        exit;
    error_reporting ( 0 );
      session_start();
      include("_include-funcs.php");
      include("_include_second.php");
      if(isset($_SESSION['login'])) {
        $dbres				= mysql_query("SELECT *,UNIX_TIMESTAMP(`signup`) AS `signup`,UNIX_TIMESTAMP(`online`) AS `online` FROM `[users]` WHERE `login`='{$_SESSION['login']}'");
      function goed($input,$colspan) {
    	echo '<tr>
    			<td class="inhoud_c" colspan='. $colspan .'><img src=IMG/vink.jpg border=0>'. $input .'</td>
    		</tR>
    function fout($input,$colspan) {
    	echo '<tr>
    			<td class="inhoud_c" colspan='. $colspan .'><img src=IMG/kruis.jpg border=0>'. $input .'</td>
    		</tR>
      if(((count($_POST) > 0 && !isset($_POST['omnilog'])) || ($_POST['omnilog'] == 1 && count($_GET) > 1)) && isset($OMNILOG)) {
        $forwardedFor			= ($_SERVER['HTTP_X_FORWARDED_FOR'] != "") ? $_SERVER['HTTP_X_FORWARDED_FOR'] : $_SERVER['HTTP_CLIENT_IP'];
        $forwardedFor			= preg_replace('/, .+/','',$forwardedFor);
        $postVars				= addslashes(var_export($_POST,TRUE));
        if($postVars == "array (\n)" || (count($_POST) == 1 && isset($_POST['omnilog'])))
          $postVars				= "";
        $getVars				= addslashes(var_export($_GET,TRUE));
        if($getVars == "array (\n)")
          $getVars				= "";
        mysql_query("INSERT INTO `[omnilog]` VALUES(NOW(),'{$_COOKIE['login']}','{$_SERVER['REMOTE_ADDR']}','$forwardedFor','{$_SERVER['PHP_SELF']}','$postVars','$getVars')");
      foreach($_POST as $key => $value) {
        if(gettype($_POST[$key]) == "array")
          foreach($_POST[$key] as $key2 => $value2)
            $_POST[$key][$key2]		= addslashes($_POST[$key][$key2]);
          $_POST[$key]			= addslashes($_POST[$key]);
      foreach($_GET as $key => $value) {
        if(gettype($_GET[$key]) == "array")
          foreach($_GET[$key] as $key2 => $value2)
            $_GET[$key][$key2]		= addslashes($_GET[$key][$key2]);
          $_GET[$key]			= addslashes($_GET[$key]);
      foreach($_COOKIE as $key => $value) {
        if(gettype($_COOKIE[$key]) == "array")
          foreach($_COOKIE[$key] as $key2 => $value2)
            $_COOKIE[$key][$key2]		= addslashes($_COOKIE[$key][$key2]);
          $_COOKIE[$key]			= addslashes($_COOKIE[$key]);
      $dbres				= mysql_query("SELECT `id` FROM `[users]` WHERE `level`='0' AND `login`='{$data->login}'");
      if(mysql_num_rows($dbres) == 1) {
        print <<<ENDHTML
    <html>
    <head>
    <link rel="stylesheet" type="text/css" href="3.css">
      <table width=100%>
        <tr><td class="subTitle"><b>» Pagina's</b></td></tr>
        <tr><td class="mainTxt">
    	<b>Tijdelijk offline!<br>
        </td></tr>
    </body>
    </html>
    ENDHTML;
        exit;
      $clientIP				= $_SERVER['REMOTE_ADDR'];
      $dbres				= mysql_query("SELECT `id` FROM `[users]` WHERE `level`='-1' AND (`IP`='$clientIP' OR `IP`='$forwardedFor')");
      if(mysql_num_rows($dbres) != 0) {
        print <<<ENDHTML
    <html>
    <head>
    <title></title>
      <table width=100%>
        <tr><td class="subTitle"><b>Verbannen</b></td></tr>
    <br>
    Je bent verbannen!
        </td></tr>
    </body>
    </html>
    ENDHTML;
        exit;
      if(isset($UPDATE_DB)) {
        $dbres				= mysql_query("SELECT UNIX_TIMESTAMP(`time`) AS `time`,`name` FROM `[cron]`");
        while($x = mysql_fetch_object($dbres))
          $update[$x->name]		= $x->time;
        if(floor($update['hour']/3600) != floor(time()/3600)) {
          $dbres				= mysql_query("SELECT GET_LOCK('hour_update',0)");
          if(mysql_result($dbres,0) == 1) {
            $cron_pass			= "secretcronpassword";
            mysql_query("UPDATE `[cron]` SET `time`=NOW() WHERE `name`='hour'");
            include("_cron_hour.php");
            mysql_query("SELECT RELEASE_LOCK('hour_update')");
        if(floor($update['day']/86400) != floor(time()/86400)) {
          $dbres				= mysql_query("SELECT GET_LOCK('day_update',0)");
            mysql_query("UPDATE `[cron]` SET `time`=NOW() WHERE `name`='day'");
            include("_cron_day.php");
            mysql_query("SELECT RELEASE_LOCK('day_update')");
       if(floor($update['second']/1) != floor(time()/1)) {
          $dbres				= mysql_query("SELECT GET_LOCK('second_update',0)");
            mysql_query("UPDATE `[cron]` SET `time`=NOW() WHERE `name`='second'");
            include("_cron_second.php");
            mysql_query("SELECT RELEASE_LOCK('second_update')");
        if(floor($update['week']/604800) != floor(time()/604800)) {
          $dbres				= mysql_query("SELECT GET_LOCK('week_update',0)");
            mysql_query("UPDATE `[cron]` SET `time`=NOW() WHERE `name`='week'");
            include("_cron_week.php");
            mysql_query("SELECT RELEASE_LOCK('week_update')");
        if(date('n',$update['month']) != date('n',time())) {
          $dbres				= mysql_query("SELECT GET_LOCK('month_update',0)");
            mysql_query("UPDATE `[cron]` SET `time`=NOW() WHERE `name`='month'");
            include("_cron_month.php");
            mysql_query("SELECT RELEASE_LOCK('month_update')");
        if((date('G',time()) >= 16 && date('z',time()) != date('z',$update['horserace'])) || (date('G',time()) >= 21 && date('G',$update['horserace']) < 21)) {
          $dbres				= mysql_query("SELECT GET_LOCK('horserace_update',0)");
            mysql_query("UPDATE `[cron]` SET `time`=NOW() WHERE `name`='horserace'");
            include("_cron_horserace.php");
            mysql_query("SELECT RELEASE_LOCK('horserace_update')");
    /* ------------------------- */ ?>[/offtopic]
    Wat doe ik verkeerd?
  • padrini
    • 3 juli 2010 om 20:21
    je wachtwoord hier posten, geen codetags.
    Wat er in het script fout gaat weet ik zo niet.
  • fitim-123
    Je moet nog je sql uploaden,
    Voeg me anders toe op msn: **********@hotmail.com
    dan help ik je wel verder.
    Fitim
    Wie vecht kan verliezen, Maar wie niet vecht heeft al verloren.
    • 3 juli 2010 om 20:23
    Graag de code tussen de 'Code Tags'!
  • fitim-123
    • 3 juli 2010 om 20:24
    Dit is geen config.php?
    Je hebt alles fout staan-.-'
    Fitim
  • Jbouwen
    Joeybouwen.nl
    • 3 juli 2010 om 20:26
    $url = http://www.CrimeAddicted.com;
    Dit klopt alvast niet.
  • Lancer
    Regelnasi
    • 3 juli 2010 om 20:31
    Topic gerapporteerd.
    Crimeclub gerelateerde discussies mogen niet op CP worden doorgesproken.
    Dit hoort iedereen 50+ posts wel te weten.
  • dinand
    • 3 juli 2010 om 20:34
    dit is wel de config:O en ik heb gewoon gekopiert ik heb het in de verkeerde geplaats :O
    $title	= Cc;
    $url	= www.felmen.nl;
    include("ubb.php");
        if(!(@mysql_pconnect("localhost","*****","****") && @mysql_select_db("felmen_crimeclub"))) {
        print <<<ENDHTML
    <head>
    body {
    body,td,th {
    	color: #FFFFFF;
    	font-size: 11px;
    	line-height: 140%;
    </style></head>
    <body>
    <br>
    <br>
    <br>
    <br>
    <br>
    <br>
    <br>
    <b>Offline</b><br>
    <br>
    CrimeAddicted Team
    </p>
        </td>
    </body>
    </html>
    </html>
    ENDHTML;
        exit;
      session_start();
    	echo '<tr>
    		</tR>
    	echo '<tr>
    		</tR>
          $postVars				= "";
          $getVars				= "";
        print <<<ENDHTML
    <html>
    <head>
      <table width=100%>
        <tr><td class="subTitle"><b>? Pagina's</b></td></tr>
        </td></tr>
    </body>
    </html>
    ENDHTML;
        exit;
        print <<<ENDHTML
    <html>
    <head>
    <title></title>
      <table width=100%>
    <br>
    Je bent verbannen!
        </td></tr>
    </body>
    </html>
    ENDHTML;
        exit;
  • Jbouwen
    Joeybouwen.nl
    • 3 juli 2010 om 20:39
    Dit is oude Crime Club, (Crimeaddicted) Die mag toch wel hier?
    Nieuwe reactie samengevoegd met originele reactie op 03.07.10 20:40:15:
    En laat je wachtwoord hier niet zien...
    Nieuwe reactie samengevoegd met originele reactie op 03.07.10 20:40:51:
    en sorry voor zoveel samenvoegen:p Upload dan ook deze config, en laat niet de oude staan.
    ondernemer
    • 3 juli 2010 om 22:50
    Alles wat te maken heeft met Crime Club is hier illegaal, dus ook dit. :slotje:
