Database Class probleem
  • AeroXbird
  • 25 juli 2010 om 11:56
  • AeroXbird
    Lua/PHP scriptorrrrrr xD
    Hallo criminalspoints.
    Ik heb sinds kort mijn website online gezet, en ik heb daarbij een database class gemaakt, die ik op een rustige ochtend zou installeren.
    Nu blijkt dit moeilijker als gedacht.
    Verbind code:
    // Connect to MySQL
    $link = Connection::NewConnection( $sql_config['hostname'], $sql_config['database'], $sql_config['username'], $sql_config['password'] );
    if(!$link)
    $message  = '' . mysql_error() . '<br><br>Please inform a system administrator!';
    echo <<<ENDHTML
    <body bgcolor="#000000">
    <center><table cellspacing='0' width='700' height='1%' style='border: 1px solid #444444; margin-bottom: 4px'  cellpadding='2' >
    					<td height='35' width='700' background='' bgcolor='#333333' style='border-bottom: 1px solid #444444; text-align: left; padding-left:25px; vertical-align: middle;'>
    				    <b><font color='#999999'>A MySQL has error occured!</b>
    			</td>
    			<TR>
    			        <td bgcolor='#222222'  width='700' style='border-bottom:1px solid #444444;' height='25'>
    				    <font color='#999999'>The website has failed to connect to the mysql server!<BR>
    					Error: $message </font>
    			</td>
    			</TR>
    		    </table></center>
    ENDHTML;
    exit();
    Database Class:
    class Connection
            var $db_connection = null;        // Database connection string
            var $db_server = null;            // Database server
            var $db_database = null;          // The database being connected to
            var $db_username = null;          // The database username
            var $db_password = null;          // The database password
            var $CONNECTED = false;           // Determines if connection is established
            /** NewConnection Method
             * This method establishes a new connection to the database. */
            public function NewConnection($server, $database, $username, $password)
                // Assign variables
                global $db_connection, $db_server, $db_database, $db_username, $db_password;
                $db_server = $server;
                $db_database = $database;
                $db_username = $username;
                $db_password = $password;
                // Attempt connection
                try
                    // Create connection to MYSQL database
                    // Fourth true parameter will allow for multiple connections to be made
                    $db_connection = mysql_connect ($server, $username, $password, true);
                    mysql_select_db ($database);
                    if (!$db_connection)
                        throw new Exception('MySQL Connection Database Error: ' . mysql_error());
                        $CONNECTED = true;
                catch (Exception $e)
                    echo $e->getMessage();
    let op, dit is slechts een deel van de database class.
    ik hoop dat het op te lossen is.
    Mvg, AeroXbird
    EDIT: het is opgelost :slotje:
  • MrWasted
    • 25 juli 2010 om 12:30
    Hoe werd het opgelost, telkens uw antwoord plaatsen om zo meerdere topics en vragen te verkomen.
  • AeroXbird
    • 25 juli 2010 om 12:48
    Het probleem lag dat ik een $link deed voor de connectie class.
    ik heb het foutmeldingen in het class systeem geintergreerd.
    • 25 juli 2010 om 13:12
    Nog een probleem: ik zie nergens "$this".
    Oh, en waarom vang je die exception op?
    Doe dat lekker ergens anders (niet binnen de class).
    Bijvoorbeeld:
    try
    // Connect to MySQL
    catch(Exception $e)
    $message  = $e->getMessage();
    echo <<<ENDHTML
                </td>
                <TR>
                        Error: $message<br><br>
                        Please inform a system administrator!</font>
                </td>
                </TR>
                </table></center>
    ENDHTML;
    exit();
    Oh, en globals zijn ook lelijk..
    Doe mij een plezier (en hopelijk daarmee jezelf), en plaats de hele class zodat ik (en andere) je kunnen helpen met het verbeteren er van.
  • AeroXbird
    • 25 juli 2010 om 14:48
    Op verzoek van darrstar:
    class Connection
                // Assign variables
                try
                        $CONNECTED = true;
            /** Open Method
            * This method opens the database connection (only call if closed!) */
            public function Open()
                global $db_connection, $db_server, $db_database, $db_username, $db_password, $CONNECTED;
                if (!$CONNECTED)
                    try
                        $db_connection = mysql_connect ($db_server, $db_username, $db_password);
                        mysql_select_db ($db_database);
                            $CONNECTED = true;
                        echo $e->GetMessage();
                    return "Error: No connection has been established to the database. Cannot open connection.";
            /** Close Method
             * This method closes the connection to the MySQL Database */
             public function Close()
                global $db_connection, $CONNECTED;
                if ($CONNECTED)
                    mysql_close($db_connection);
                    $CONNECTED = false;
                    return "Error: No connection has been established to the database. Cannot close connection.";
    • 25 juli 2010 om 16:03
    http://www.php.net/manual/en/language.oop5.basic.php
    Lees daar eens iets over $this aub
    Dan kunnen al die lelijke globals weg...
  • AeroXbird
    • 27 juli 2010 om 23:30
    Ik heb er naar gekeken, maar ik snap dat $this niet helemaal
    en ik vind die examples ook niet bepaald duidelijk daar.
    • 27 juli 2010 om 23:50
    ok, laat ik het dan maar proberen uit te leggen:
    Beginnend met een feit:
    Dat staat er nu voor spek en bonen (en gebruik aub "public" en niet "var", wat nog PHP 4 is)
    Als je wilt dat het er niet voor spek en bonen staat, dan moet je die variabelen gaan gebruiken...
    Maar die variabele spreek je niet aan via $CONNECTED, $db_server etc.
    Maar via $this->CONNECTEC, $this->db_server etc.
    voorbeeldje:
    /** Open Method
                if ($this->CONNECTED)
                    return true;
                $this->db_connection = mysql_connect ($this->db_server, $this->db_username, $this->db_password);
                if ($this->db_connection)
                    if (mysql_select_db ($this->db_database))
                        return $this->CONNECTED = true;
    Geen lelijke global!
    En zo moet je met objecten werken (tenzij je statische variabele gaat maken) wat ik een pro vindt.
    PS. misschien dat ik morgen ochtend nog wat edit, ik ben moe :p
  • Spinazie
    Set sail, pirates!
    • 27 juli 2010 om 23:53
    $this is gewoon de variabele die het object waarin je werkt zelf bevat. Werkt alleen in object context though. Dat is logisch.
    Als je een methode of een variabele van je class in de class zelf terug wilt roepen (wat heel handig is voor private access), dan kun je $this gebruiken.
    Stel bijvoorbeeld dat je een methode hebt die een object zijn eigenschappen omzet in een array (ik noem maar wat). Dan zou je bijvoorbeeld $this->convertToArray(Exception $caughtshizzle) kunnen aanroepen als die methode bestond in de class waar je $this gebruikt.
    Snap je dit wel?
    Nieuwe reactie samengevoegd met originele reactie op 27.07.10 23:53:40:
    Oh te laat
  • AeroXbird
    • 28 juli 2010 om 00:15
    Dit heb ik nu:
    public $db_connection = null;        // Database connection string
    		public $db_server = null;            // Database server
            public $db_database = null;          // The database being connected to
            public $db_username = null;          // The database username
            public $db_password = null;          // The database password
            public $CONNECTED = false;           // Determines if connection is established
                    $this->db_connection = mysql_connect ($this->server, $this->username, $this->password, true);
                    mysql_select_db ($this->database);
    maar ik krijg constant een error dat hij niet in object context is.
  • Spinazie
    Set sail, pirates!
    • 28 juli 2010 om 00:19
    Je kunt het best even alle reacties lezen, ook die te laat zijn.
    $this kun je alleen gebruiken als je je class in object context aan het werk zet. Dat komt omdat $this zelf ook een object bevat, en PHP maakt niet automatisch een object voor je aan (gelukkig)
  • AeroXbird
    • 28 juli 2010 om 00:41
    Na wat tweaken heb ik het probleem opgelost, het probleem bleek dus de aanroeping van de class te zijn.
    Ik snap nu ook helemaal hoe de object context werkt, dankjewel
    kan een :slotje: op!
  • Spinazie
    Set sail, pirates!
    • 28 juli 2010 om 00:46
    Dus je kunt ook de PHP4 gewoontes weg gooien en met PHP5 beginnen? :p
    var $db_connection = null; << Refering to this
    In PHP5 maken we namelijk al gebruik van access levels (public, protected en private)
    http://www.sitemasters.be/tutorials/1/1/…cted_en_Private) :D
