Onbekende fout
  • 27 februari 2010 om 20:02
    Beste cp'ers,
    Heb onderstaand script geschreven:
    if(isset($_POST['submit'])) {
    if($_POST['subject'] == "") {
    echo "<tr><td class=list2 colspan=2>Je bent vergeten een onderwerp in te vullen</td></tr>";
    } else if($_POST['message'] == "") {
    echo "<tr><td class=list2 colspan=2>Je bent vergeten een bericht in te vullen</td></tr>";
    if($_POST[to] == "1") {
    $query = "SELECT username,email,ontvangmail FROM users";
    $info = mysql_query($query) or die(mysql_error());
    $datie = mysql_fetch_object($info);
    $bericht = $_POST['message'].'\n\n Afmelden? http://mafiastar.eu/index.php?a=afmelden&username='.$datie->username;
    while ($gegeven = mysql_fetch_array($info)) {
    if($gegeven['ontvangmail'] == "1") {
    mail($gegeven[email],$_POST[subject],$bericht,"From: MafiaStar.eu<[email protected]>");
    echo "<tr><td class=list2 colspan=2>Het bericht is verstuurd naar <b>alle leden</b>!</td></tr>";
    } else{
    $info = mysql_query("SELECT username,email,ontvangmail FROM users WHERE username = '".$_POST['username']."'") or die(mysql_error());
    if($gegeven['ontvangmail'] == 1) {
    mail($gegeven['email'], $_POST['subject'], $bericht) or die("mislukt");
    echo popup_goed("Het bericht is verstuurd naar <b>".$_POST['username']."</b>!");
    <table>
    <form method="post">
    <tr><td class=list width=100>Naar:</td>
    <td class=list>
    <select name=to>
    <option value=0>Anders, typ hiernaast</option>
    <option value=1>Alle leden</option>
    </select>
    Of: <input type="text" name="username"></td></tr>
    <tr><td class=list>Waar:</td>
    <td class=list><select name=where>
    <option value=1>Postvak IN (e-mail)</option>
    </select></td></tr>
    <tr><td class=list>Onderwerp:</td>
    <td class=list><input type=text name=subject size=35></td></tr>
    <tr><td class=list valign=top>Bericht:</td>
    <td class=list><textarea name=message rows=20 cols=50></textarea></td></tr>
    <tr><td class=listtitle colspan=2 align=right><input type=submit name=submit value=Submit class=boton></td></tr></form>
    Echter, als ik het formulier verstuur, gebeurt er niks, de gelukt message word niet weergegeven.
    Ik weet niet hoe het komt.
    Bij to vul ik value 0 in, en ik vul m'n gebruikersnaam in. Maar ik krijg geen mail.
    In de database staat idd. ontvangmail op 1.
    Hoe kan dit?
    Bedankt alvast,
    Lars
  • Pharox
    Enjoy Coding
    • 27 februari 2010 om 20:13
    Ik wil niet off-topic of lullig overkomen, maar zou eerst netjes leren scripten.
    Ik zou persoonlijk sneller je fout zoeken als alles duidelijk is geschreven.
    Verder, kloppen de waardes wel die je opslaat?
    Heb je ook mysql_error() geprobeerd ?
    Project vendettagame.com:
    10% klaar
    • 27 februari 2010 om 20:14
    mySQL error staat er al.
    En heb geen errors gekregen ;)
  • Reverb
    Lolz0r.
    • 28 februari 2010 om 00:43
    Probeer eens
    Te veranderen in:
    <form method="post" action="" name="subject">
    Projecten:
    http://lsjdesigns.nl/
    http://allesvooreeneuro.nl/
    • 28 februari 2010 om 09:11
    Nee, werkt niet :(
    • 28 februari 2010 om 09:13
    Gebruik eens bovenaan:
         error_reporting(E_ALL);
  • MrMees
    De causeur!
    • 28 februari 2010 om 11:01
    Regel 8......
    Rembo&amp;amp;Rembo.
    • 28 februari 2010 om 11:52
    It's solved.
    Heb de table even weggehaald, heb $datie = mysql_fetch_object($info); weggehaald, en $bericht = $_POST['message'].'nn Afmelden? http://mafiastar.eu/index.php?a=afmelden&username='.$datie->username; in de while geplaatst. (natuurlijk $datie->username met $gegeven['username']; vervangen, en het werkt nu.
    Bedankt nog!
    Lars
