Nieuws script probleem
  • Shahiem
  • 22 januari 2010 om 15:05
  • Shahiem
    http://www.hogwartscastle
    Bij me nieuws krijg ik dit, Als je bent uitgelogd:
    Notice: Undefined index: uId in /home/shahiem/domains/habboregio.nl/public_html/nieuws.php on line 87
    En dit krijg ik ook nog:
    Notice: Undefined variable: nFetch in /home/shahiem/domains/habboregio.nl/public_html/nieuws.php on line 99
    Code:
    require_once 'inc/header.php';
    if(isset($_GET['act']) && ($_GET['act'] == 'leesmeer') && ctype_digit(isset($_GET['id'])))
        $sQuery = mysql_query("SELECT * FROM member_news WHERE nId = " . $_GET['id']) or trigger_error(mysql_error());
        $sFetch = mysql_fetch_assoc($sQuery);
        $nameQuery = mysql_query("SELECT * FROM member_accounts WHERE uId = " . $sFetch['nAuthor']);
        $nameFetch = mysql_fetch_assoc($nameQuery);
        if($sFetch['nVisible'] == 1)
              echo '<div class="top">' . htmlentities($sFetch['nTitle'], ENT_QUOTES) . ' ' . (is_auth(2, $_SESSION['uId']) ? '<div style="float:right"><a href="admin_news?act=edit&amp;id=' . $sFetch['nId'] . '"><img src="img/pencil.png" alt="Wijzigen" /></a>' . ($sFetch['nVisible'] == '1' ? ' <a href="admin_news?act=delete&amp;id=' . $sFetch['nId'] . '"><img src="img/cross.png" alt="verwijderen" /></a></div>' : ' <a href="admin_news?act=reopen&amp;id=' . $nFetch['nId'] . '"><img src="img/newspaper_go.png" alt="Zet terug" /></a></div>') : '') . '</div><div class="mid">';
           echo ''.$sFetch['nText'].'';
    echo '<br /><p align="left" style="float: left;">Door <span style="color:' . $nameFetch['uCol'] . ';font-weight: bold;">' . htmlentities($nameFetch['uName'], ENT_QUOTES) . '</span> | ' . $sFetch['nDate'] . '</font></p></div>';
            $cQuery = mysql_query("SELECT cId, cVisible, cAuth, cText, cDate FROM member_news_comment WHERE cNewsId =" . $_GET['id'] . (is_auth(2, $_SESSION['uId']) == TRUE ? '' : ' AND cVisible = 1') . " ORDER BY cId ASC") or trigger_error(mysql_error());
            if(mysql_num_rows($cQuery))
                while($cFetch = mysql_fetch_assoc($cQuery))
                    $nameQuery = mysql_query("SELECT * FROM member_accounts WHERE uId = " . $cFetch['cAuth']);
                    echo '<div class="top">Reactie van ' . htmlentities($nameFetch['uName'], ENT_QUOTES) . '' . (is_auth(2, $_SESSION['uId']) ? '<div style="float:right"><a href="news_edit_comment?act=edit&amp;id=' . $cFetch['cId'] . '&amp;nId=' . $_GET['id'] . '"><img src="img/pencil.png" alt="Wijzigen" /></a>' . ($cFetch['cVisible'] == '1' ? ' <a href="news_edit_comment?act=delete&amp;id=' . $cFetch['cId'] . '&nId=' . $_GET['id'] . '"><img src="img/cross.png" alt="Verwijderen" /></a></div>' : ' <a href="news_edit_comment?act=reopen&amp;id=' . $cFetch['cId'] . '&amp;nId=' . $_GET['id'] . '"><img src="img/newspaper_go.png" alt="Zet terug" /></a></div>') : '') . '</div><div class="mid">';
    	echo '<div style="text-align: center; border-bottom: 1px dashed #000; margin-right: 5px;">
    				Gepost op ' . $cFetch['cDate'] . '
    			<div style="width: 110px; float: left;"> <strong><a href="profiel?id=' . $nameFetch['uId'] . '"><span style="color:' . $nameFetch['uCol'] . ';font-weight: bold;">' . htmlentities($nameFetch['uName'], ENT_QUOTES) . '</span></a></strong><br />';
     if(!empty($nameFetch['uAvatarUrl']))
                    echo image_resize($nameFetch['uAvatarUrl']);
    				echo '
    				<img src="img/muntjes.png" /> ' . $nameFetch['uCoins'] . '<br />
    				<img src="img/ster.png" /> ' . $nameFetch['uRangN'] . '
    			<div style="float: left; border-left: 1px dashed #000; width: 315px; padding: 5px; min-height: auto; height: auto;">';
                    echo ParseUbb(htmlentities($cFetch['cText'], ENT_QUOTES), 2);
    			echo '</div></div>
    			<div style="clear: both;"></div>';
            if(isset($_SESSION['uId']) && is_auth(1, $_SESSION['uId']))
                <div class="top">Reageren</div>
    <div class="mid">
                    <?php echo ubb('textbox', 'text'); ?>
                    <form name="textbox" action="news_reageer" method="POST">
                        <input type="hidden" name="NewsID" value="<?php echo $_GET['id']; ?>" />
                        <textarea cols="40" rows="5" id="textbox" name="text"></textarea><br />
                        <input type="submit" name="submit" value="Reageer" />
                echo '<div class="rederror"><br /><strong>Je moet ingelogd zijn om te reageren.</strong> <br /><a href="login">Log hier in</a> of <a href="registreer">maak een account aan.</a></div>';
            echo '<div class="rederror"><br /><strong>Dit nieuwsbericht is verwijderd</strong><br />Klik <a href="javascript:history.back(-1)">hier</a> om terug te gaan</div>';
        $per_pagina = 5;
        $start = isset($_GET['start']) && ctype_digit($_GET['start']) ? $_GET['start'] : 0;
        $pagina = ceil($start / $per_pagina) + 1;
        $paginas_mysql = mysql_query("SELECT count(1) AS aantal FROM member_news WHERE nVisible = 1") or die(mysql_error());
        $fetch_mysql = mysql_fetch_assoc($paginas_mysql);
        $paginas = ceil($fetch_mysql['aantal'] / $per_pagina);
        $sQuery = mysql_query("SELECT * FROM member_news " . (is_auth(2, $_SESSION['uId']) == TRUE ? '' : 'WHERE nVisible = 1'). " ORDER BY nDate DESC LIMIT " . $start . "," . $per_pagina);
        if(isset($_SESSION['uId']) && is_auth(2, $_SESSION['uId']))
        while($sFetch = mysql_fetch_assoc($sQuery))
            $countQuery = mysql_query("SELECT count(cId) AS commentCount FROM member_news_comment WHERE cNewsId = " . $sFetch['nId'] . " AND cVisible = 1") or trigger_error(mysql_error());
            $countFetch = mysql_fetch_assoc($countQuery);
            echo '<div class="top">' . htmlentities($sFetch['nTitle']) . ' ' . (is_auth(2, $_SESSION['uId']) ? '<div style="float:right"><a href="admin_news&amp;act=edit&amp;id=' . $sFetch['nId'] . '"><img src="img/pencil.png" alt="Wijzigen" /></a>' . ($sFetch['nVisible'] == '1' ? ' <a href="admin_news?act=delete&amp;id=' . $sFetch['nId'] . '"><img src="img/cross.png" alt="verwijderen" /></a></div>' : ' <a href="admin_news?act=reopen&amp;id=' . $nFetch['nId'] . '"><img src="img/newspaper_go.png" alt="Zet terug" /></a></div>') : '') . '</div><div class="mid">';
    echo '<br /><p align="left" style="float: left;">Door <span style="color:' . $nameFetch['uCol'] . ';font-weight: bold;">' . htmlentities($nameFetch['uName'], ENT_QUOTES) . '</span> | ' . $sFetch['nDate'] . '</font></p><p align="right" style="float: right;"><a href="nieuws?act=leesmeer&id=' . $sFetch['nId'] . '">Volledig bericht</a> |  <a href="nieuws?act=leesmeer&id=' . $sFetch['nId'] . '">(' . $countFetch['commentCount'] . ') reacties</a></p></div>';
                $hiddencountQuery = mysql_query("SELECT count(cId) AS hiddencommentCount FROM member_news_comment WHERE cNewsId = " . $sFetch['nId'] . " AND cVisible = 0") or trigger_error(mysql_error());
                $hiddencountFetch = mysql_fetch_assoc($hiddencountQuery);
                if($hiddencountFetch['hiddencommentCount'] > 0)
                echo ' (+' . $hiddencountFetch['hiddencommentCount'] . ' verborgen)';
            echo '</a>';
        echo '<div class="top">Paginanavigatie</div><div class="mid">';
        for($j = $pagina-5;$j < $pagina+5;$j++)
                  if($j > 0 && $j <= $paginas)
              if($j == $pagina)
                 echo'<strong>' . $pagina . '</strong>&nbsp;';
                 echo "<a href='nieuws?start=" . (($j-1)*$per_pagina) . "'>" . $j . "</a>&nbsp;";
    	echo '</div>';
    require_once 'inc/footer.php';
    [center]HogwartsCastle[/center]
  • Pharox
    Enjoy Coding
    • 22 januari 2010 om 15:18
    Jou error_reporting staat aan.
    Ik denk dat dit oplost wat je probleem is.
    if(isset($_SESSION['uId']) && $_SESSION['uID'] && is_auth(1, $_SESSION['uId']))
    Let op weet niet zeker, deze fouten heb ook ooit gehad.
    if (isset($_GET['iets']))
    //Bovenstaande krijg je die error
    if (isset($_GET['iets']) && $_GET['iets'])
    //Bovenstaande krijg je geen error
    Project vendettagame.com:
    10% klaar
  • Shahiem
    • 22 januari 2010 om 15:28
    Maar hoe los ik het op met die query?
  • Pharox
    Enjoy Coding
    • 22 januari 2010 om 16:52
    Welke query bedoel je precies ?
    10% klaar
    • 22 januari 2010 om 19:56
    Pharox
    isset() en empty() zorgen er juist voor dat je geen unidefined index/variable notices opduiken.
    if ($_SESSION['uId']) // notice!
    if(isset($_SESSIO['uId'])) // false
    Als je regel 89 voor regel 87 zet zal de eerste notice niet meer voorkomen.
    De tweede lijkt me een typo: $nFetch ipv $sFetch.
  • Pharox
    Enjoy Coding
    • 22 januari 2010 om 20:36
    Darsstar
    Excuus, wist enkel nog het voorbeeldje wat jij toen had verteld.
    Ga er dus nog even een tutorial over zoeken :$
    10% klaar
    • 23 januari 2010 om 10:06
    Ik denk dat je fout is dat je een verkorte if gebruikt maar deze if alleen maar met goed doet en zonder een else dus je doet wel de ? en niet de : .
    Controleer dat is ?
    En om die zonder else te houden moet je AND gebruiken.
