Check_Login foutmelding
  • Reverb
  • 17 september 2009 om 00:20
  • Reverb
    Lolz0r.
    Ik heb sinds kort een foutmelding op me website waardoor je steeds de error beneden aan ziet staan
    De desbetreffende error:
    Fatal error: Cannot redeclare check_login() (previously declared in /storage/mijndomein/users/148156/public/sites/www.hiphopperz.nl/_include-funcs1.php:3) in /storage/mijndomein/users/148156/public/sites/www.hiphopperz.nl/_include-funcs1.php on line 44
    Het gaat dus om _include-fucs1.php
    Hier het script:
      function check_login() {
        if(isset($_SESSION['login'],$_SESSION['IP']) && $_SESSION['IP'] == $_SERVER['REMOTE_ADDR']) {
          if(! isset($_COOKIE['login'],$_COOKIE['validate'])) {
            $validate		= md5(rand(0,1000));
            setcookie("login",$_SESSION['login'],time()+60*60*24,"/","");
            setcookie("validate",$validate,time()+60*60*24,"/","");
            $validate		= $_COOKIE['validate'];
          mysql_query("REPLACE INTO `[online]`(`time`,`IP`,`login`,`validate`) values(NOW(),'{$_SERVER['REMOTE_ADDR']}','{$_SESSION['login']}','$validate')");
          return TRUE;
        else {
          if(isset($_COOKIE['login'],$_COOKIE['validate'])) {
            $login			= $_COOKIE['login'];
            $query			= mysql_query("SELECT * FROM `[online]` WHERE `login`='$login' AND `validate`='$validate' AND `IP`='{$_SERVER['REMOTE_ADDR']}' AND UNIX_TIMESTAMP(NOW())-UNIX_TIMESTAMP(`time`) < 60*60*24");
            if($user = mysql_fetch_object($query)) {
              mysql_query("UPDATE `[online]` SET `time`=NOW() WHERE `login`='$login' AND `validate`='$validate' AND `IP`='{$_SERVER['REMOTE_ADDR']}' AND UNIX_TIMESTAMP(NOW())-UNIX_TIMESTAMP(`time`) < 60*60*24");
              setcookie("login",$user->login,time()+60*60*24,"/","");
              $_SESSION['login']	= $user->login;
              $_SESSION['IP']	= $_SERVER['REMOTE_ADDR'];
              return TRUE;
            else {
              unset($_SESSION['login']);
              unset($_SESSION['IP']);
              setcookie("login",'',time()-100,"/","");
              setcookie("validate",'',time()-100,"/","");
              return FALSE;
          else {
            return FALSE;
    Weet iemand het?
    Projecten:
    http://lsjdesigns.nl/
    http://allesvooreeneuro.nl/
  • Seliim
    [s] e l ii m
    • 17 september 2009 om 00:59
          return TRUE;
        else {
              return TRUE;
            else {
              return FALSE;
          else {
            return FALSE;
    probeer dit is even kijken wat de resultaat nu is? :)
    • 17 september 2009 om 06:57
    Gebruik inclide_once() op de plaats waar je nu dit bestand include...
    PHP kan de functie niet overschrijven, dus blijkbaar wordt dat bestand 2 keer uitgevoerd.
  • Reverb
    Lolz0r.
    • 17 september 2009 om 09:57
    Darsstar als ik dat doe krijg ik 2 pagina's onder elkaar :O
    Projecten:
    • 17 september 2009 om 10:09
    Overal inderdaad include vervangen door include_once en require vervangen door require_once.
  • Reverb
    Lolz0r.
    • 17 september 2009 om 16:35
    Even proberen.
    Projecten:
  • SScripter
    • 18 september 2009 om 16:15
    Heeft het gelukt of niet?
    Want je include_funcs1 ziet er goed uit.
  • Reverb
    Lolz0r.
    • 18 september 2009 om 16:16
    Nee lukt niet, het gaat wel weg, maar je blijft ingelogd.
    Je kan niet meer uitloggen.
    Of je krijgt 2 pagina's onder elkaar.
    Heel storend dus.
    Projecten:
    • 18 september 2009 om 17:08
    Dat vind ik heel vreemd.
    Zeg je nou dat er door include_once()/require_once() je 2 pagina's onder elkaar krijgt?
    Dat lijkt me onmogelijk...
    Laat je index.php eens zien aub.
    Op het moment kan ik me geen goed beeld vormen...
  • Reverb
    Lolz0r.
    • 18 september 2009 om 19:20
    De code moest ik even dumpen, hij liep vast.
    http://codedumper.com/edoku
    Projecten:
