PHP en radio buttons
  • ruttydm
  • 23 november 2013 om 12:50
  • ruttydm
    Ik wou in php met POST mijn radio button value oproepen maar het werkt niet.
    Ik krijg altijd de melding "There is not a Animal of that name"
    tewijl dit niet mag gebeuren.
    code:
    <?php //hunt animal module
    include 'connect.php';
    session_start();
    include "up_html.php";
    if (isset($_SESSION['player']))
    	  $player=$_SESSION['player'];
          $playerstats1="SELECT * from km_users where playername='$player'";
          $playerstats2=mysql_query($playerstats1) or die ("Could not find player");
          $playerstats3=mysql_fetch_array($playerstats2);
          print "<table class='maintable'>";
          print "<tr class='headline'><td><center>Select Monster to Slay</center></td></tr>";
          print "<tr class='mainrow'><td>";
          print "<form method='post'>";
          $monster1="SELECT * from km_monsters order by skill asc";
          $monster2=mysql_query($monster1) or die("Could not select Animal");
          while ($monster3=mysql_fetch_array($monster2))
    		$totalskill=$playerstats3[skillpts]+$monster3[skill];
    		$chance=($playerstats3[skillpts] / $totalskill * 100);
    		$chance2=round($chance, 0, PHP_ROUND_HALF_UP);
    		  print "<INPUT TYPE = 'radio' NAME = 'monstername' VALUE = 1 CHECKED><B>$monster3[name]</B><br><p>$chance2% chance, reward:$monster3[goldworth] gold</p><hr>";
    	print "<br>";
          print "<input type='submit' name='submit' value='Hunt Animal'></form>";
          print "</td></tr></table><br>";
        if(isset($_POST['submit']))
         if($playerstats3[numturns]<1)
            print "You need at least 1 turn to kill a monster, please go back to <A href='index.php'>Main</a>.";
             $monstername=$_POST['monstername'];
             $monstername=strip_tags($monstername);
             $selmonster="SELECT * from km_monsters where name='$monstername'";
             $selmonster2=mysql_query($selmonster) or die ("Cannot select Monster");
             $selmonster3=mysql_fetch_array($selmonster2);
             if (!$selmonster3)
               print "There is not a Animal of that name";
               $totalskill=$playerstats3[skillpts]+$selmonster3[skill];
               $randomnumber=rand(1,$totalskill);
               if($randomnumber<=$playerstats3[skillpts])
                 $gained=$selmonster3[pointsifkilled];
                 $gold=$selmonster3[goldworth];
                 $updateplayerstats="Update km_users set skillpts=skillpts+'$gained', gold=gold+'$gold' where playername='$player'";
                 mysql_query($updateplayerstats) or die("Could not update player stats");
                 print "<center><img src='images/knight.gif'></center>";
                 print "You slay the $selmonster3[name] is glorius combat and gained $gained skillpts";
                 print "<center><A href='index.php'>Kill more monsters</a></center>";
                 print "<center><img src='images/defeat.gif'></center>";
                 print $chance."The $selmonster3[name] laughs as you run away from the battle like a chicken<br><br>";
                 print "<A href='index.php'>Kill more monsters</a>";
    else //not logged in
        print "You are not logged in, please <A href='login.php'>Login</a>";
    include "down_html.php";
    Ik zou niet weten waar de fout ligt.
    Het gaat over de site: http://rutgerx99.ninetynine.axc.nl/
    http://infinidum.com/
    Bewerkt 2 keer, laatst door ruttydm (23 november 2013 om 12:59).
  • L.Kok
    • 23 november 2013 om 14:48
    Kan je ook de HTML eens laten tonen aub?
    Met enkel een php code zijn we niet veel.
    L.Kok
    YoungVision
  • ruttydm
    • 23 november 2013 om 15:31
    Die staat toch in de code?
    • 23 november 2013 om 17:00
    Je monstername is nu altijd met value 1 dat zag je wel ?
    Wat jij wilt bereiken is dat de input radio op elke waarde een andere naam heeft.
    P.S. leer wel van je foutafhandelingen in de code, ik doe dit niet voor me plezier maar om jou op weg te helpen, overigens is niet alles 100% veilig
    // Check if session is already running or not
    if (!session_id()) session_start();
    // Include connection/header
    include_once "connect.php";
    include_once "up_html.php";
    // Check for session "player"
    	//Find player within session
    	$playersess = mysql_real_escape_string($_SESSION['player']);
    	$sql_users = "SELECT * FROM km_users WHERE playername = '" . $playersess . "'";
    	// Check if query "km_users" could run
    	if ($result_users = mysql_query( $sql_users ))
    		$player = mysql_fetch_array($result_users); ?>
            <table class="maintable">
                <tr class="headline"><td><center>Select Monster to Slay</center></td></tr>
                <tr class="mainrow"><td>
                <form method="post">
    				$sql_monsters = "SELECT * FROM km_monsters ORDER BY skill ASC";
    				// Check if query "km_monsters" could run
    				if ($result_monsters = mysql_query( $sql_monsters ))
    					// While loop the results
    					while ($monsters = mysql_fetch_array($result_monsters))
    						$totalskill = $player['skillpts'] + $monsters['stats'];
    						$chance = ($player['skillpts'] / $totalskull * 100);
    						$chance = round($chance, 0, PHP_ROUND_HALF_UP); ?>
                            <input type="radio" name="monstername" value="<?php echo $monsters['name']; ?>" checked><b><?php echo $monster['name']; ?></b><br>
                            <p><?php echo $chance; ?> chance, reward: <?php echo $monster['goldworth']; ?> gold</p><hr>
    				else {
    					// Query could not run
    					echo "Error running query, contact the administrator.";
                <br>
                <input type="submit" name="submit" value="Hunt Animal">
                </td></tr>
    		// Run form submit
    		if (isset($_POST['submit']))
    			// Player has no more turns
    			if ($player['numturns'] < 1) {
    				echo 'You need at least 1 turn to kill a monster, please go back to <a href="index.php">Main</a>';
    			else {
    				// Turns left, run the page
    				$monstername = mysql_real_escape_string($_POST['monstername']);
    				$sql_monster = "SELECT * FROM km_monsters WHERE name = '" . $monstername . "'";
    					$monsters = mysql_fetch_array($result_monsters);
    					// Calculate monsters
    					$totalskill = $player['skillpts'] + $monsters['skill'];
    					$randnumber = rand(1, $totalskill);
    					$chance = ($player['skillpts'] / $totalskill * 100);
    					if ($randnumber <= $player['skillpts'])
    						$gained = $monsters['pointsifkilled'];
    						$gold = $monster['goldworth'];
    						$sql_users = "UPDATE km_users SET skillpts = skillpts + '" . $gained . "', gold = gold + '" . $gold . "' WHERE playername = '" . $playersess . "'";
    						if ($result = mysql_query( $sql_users )) { ?>
                            	<center><img src="images/knight.gif"></center>
                                You slay the <?php echo $monster['name']; ?> is glorius combat and gained <?php echo $gained; ?> skillpts
                                <center><a href="index.php">Kill more monsters</a></center>
    						else {
    							// Could not run query
    							echo "Error running query, please contact the administrator.";
    					else {
    						// Lost battle from monster ?>
                            <center><img src="images/defeat.gif"></center>
                            <?php echo $chance; ?> The <?php echo $monster['name']; ?> laughs as you run away from the battle like a chicken<br><br>
    				else {
    					echo "Error running query, please contact the administrator";
    	else {
    else {
    	// Player is not logged in
    	echo 'You are not logged in, please <a href="login.php">Login</a>';
    // Include footer
    include_once "down_html.php";
  • ruttydm
    • 23 november 2013 om 17:05
    Al opgelost ik moest een variabel bij value zetten, alweer zo'n domme fout.
    • 23 november 2013 om 17:08
    Citaat van ruttydm
    1 tip, hou HTML en PHP gescheiden, dan zul je dit soort dingen veel makkelijker vinden, en het is in mijn ervaring veel netter werken.
