  • Verschillende domeinen
misdaad script
  • mattie1992
  • 26 augustus 2012 om 23:20
  • mattie1992
    Beste leden,
    Er zit een fout in mijn misdaad script, als er staat dat je 100% kans hebt mislukt de misdaad alsnog heel vaak. Kan iemand mij hiermee helpen?
    Script:
    include("_config.php");
    if(!check_login()){ header("Location: login.php"); exit; }
    include("_bovenbalk.php");
    include("_informatiebalk.php");
    include ("_anticheat.php");
    if($data->vakantie > 0){ include ('vakantie.php'); exit(); }
    if($data->status == "dood"){ include ('rip.php'); exit(); }
    if($jisin == 1) { include('jisin.php'); exit(); }
    if($data->vliegtijd - time() > 0){ include('reizen2.php'); exit(); }
    mysql_query("UPDATE `users` SET `online`=NOW() WHERE `login`='{$data->login}'");
    $misdaad1 = $data->misdaad1;
    $misdaad2 = $data->misdaad2;
    $misdaad3 = $data->misdaad3;
    $misdaad4 = $data->misdaad4;
    $misdaad5 = $data->misdaad5;
    $_GET['hide'] = safe($_GET['hide']);
    if($_GET['hide'] == '1'){ mysql_query("UPDATE `users` SET `misdaad1`=0 WHERE `login`='{$data->login}'"); $misdaad1 = 0; }
    if($_GET['hide'] == '2'){ mysql_query("UPDATE `users` SET `misdaad2`=0 WHERE `login`='{$data->login}'"); $misdaad2 = 0; }
    if($_GET['hide'] == '3'){ mysql_query("UPDATE `users` SET `misdaad3`=0 WHERE `login`='{$data->login}'"); $misdaad3 = 0; }
    if($_GET['hide'] == '4'){ mysql_query("UPDATE `users` SET `misdaad4`=0 WHERE `login`='{$data->login}'"); $misdaad4 = 0; }
    if($_GET['hide'] == '5'){ mysql_query("UPDATE `users` SET `misdaad5`=0 WHERE `login`='{$data->login}'"); $misdaad5 = 0; }
    if($_GET['show'] == '1'){ mysql_query("UPDATE `users` SET `misdaad1`=1 WHERE `login`='{$data->login}'"); $misdaad1 = 1; }
    if($_GET['show'] == '2'){ mysql_query("UPDATE `users` SET `misdaad2`=1 WHERE `login`='{$data->login}'"); $misdaad2 = 1; }
    if($_GET['show'] == '3'){ mysql_query("UPDATE `users` SET `misdaad3`=1 WHERE `login`='{$data->login}'"); $misdaad3 = 1; }
    if($_GET['show'] == '4'){ mysql_query("UPDATE `users` SET `misdaad4`=1 WHERE `login`='{$data->login}'"); $misdaad4 = 1; }
    if($_GET['show'] == '5'){ mysql_query("UPDATE `users` SET `misdaad5`=1 WHERE `login`='{$data->login}'"); $misdaad5 = 1; }
    <link rel="stylesheet" href="./css/noticeui.css" type="text/css" media="screen" title="no title" charset="utf-8" />
    <body onLoad="javascript:correct_png();"><center>
    <table width="100%" align="center">
    <tr><td class="subTitle"><b>Misdaad</b></td></tr>
    <tr><td class="mainTxt"><br />
    $time = time();
    $crime = $data->crime - time();
    $ccrime = gmdate('i:s',($data->crime - time()));
    if($data->crime - time() > 0)
    warn("Het zou opvallen als je teveel misdaden achter elkaar zou doen.<br>Neem wat rust en probeer het over <b><font id='CrimeCountdown'></font></b>  seconden weer.");
    echo"<script type='text/javascript'>
            var seconds=$crime;
            function display()
                seconds=seconds-1;
                if(seconds<0)
                    self.location.replace('misdaad.php');
                    var countdown = document.all? document.all[\"CrimeCountdown\"] : document.getElementById? document.getElementById(\"CrimeCountdown\") : \"\";
                    if (countdown)
                        countdown.innerHTML=seconds;
                        setTimeout('display()',1000);
            display();
    		</script></td></tr></table>";
    exit;
    if (isset($_POST['submit'])) {
    $misdaad = safe($_POST['misdaad']);
    if($misdaad > 15 || $misdaad < 1){ echo 'Je moet een misdaad kiezen.'; exit; }
    if(!preg_match('/^[0-9]+$/',$misdaad)){ echo 'Ongeldige optie gekozen.'; exit; }
    if($misdaad >= 4 && $misdaad <= 6 && $data->xp < 20){ echo 'Deze optie is pas beschikbaar vanaf Picciotto (rang 3).'; exit; }
    if($misdaad >= 7 && $misdaad <= 9 && $data->xp < 150){ echo 'Deze optie is pas beschikbaar vanaf Pickpocket (rang 5).'; exit; }
    if($misdaad >= 10 && $misdaad <= 12 && $data->xp < 1000){ echo 'Deze optie is pas beschikbaar vanaf Associate (rang 7).'; exit; }
    if($misdaad >= 13 && $misdaad <= 15 && $data->xp < 3000){ echo 'Deze optie is pas beschikbaar vanaf Leader (rang 9).'; exit; }
    if(($misdaad == 1 || $misdaad == 2 || $misdaad == 3) && $data->nrofcrime >= 0){ $kans = 6; $type = 1; }
    if(($misdaad == 1 || $misdaad == 2 || $misdaad == 3) && $data->nrofcrime >= 5){ $kans = 5; $type = 1; }
    if(($misdaad == 1 || $misdaad == 2 || $misdaad == 3) && $data->nrofcrime >= 10){ $kans = 4; $type = 1; }
    if(($misdaad == 1 || $misdaad == 2 || $misdaad == 3) && $data->nrofcrime >= 15){ $kans = 3; $type = 1; }
    if(($misdaad == 1 || $misdaad == 2 || $misdaad == 3) && $data->nrofcrime >= 20){ $kans = 2; $type = 1; }
    if(($misdaad == 1 || $misdaad == 2 || $misdaad == 3) && $data->nrofcrime >= 30){ $kans = 'tweeopdrie'; $type = 1; }
    if(($misdaad == 1 || $misdaad == 2 || $misdaad == 3) && $data->nrofcrime >= 45){ $kans = 1; $type = 1; }
    if(($misdaad == 4 || $misdaad == 5 || $misdaad == 6) && $data->nrofcrime >= 0){ $kans = 6; $type = 2; }
    if(($misdaad == 4 || $misdaad == 5 || $misdaad == 6) && $data->nrofcrime >= 10){ $kans = 5; $type = 2; }
    if(($misdaad == 4 || $misdaad == 5 || $misdaad == 6) && $data->nrofcrime >= 15){ $kans = 4; $type = 2; }
    if(($misdaad == 4 || $misdaad == 5 || $misdaad == 6) && $data->nrofcrime >= 25){ $kans = 3; $type = 2; }
    if(($misdaad == 4 || $misdaad == 5 || $misdaad == 6) && $data->nrofcrime >= 30){ $kans = 2; $type = 2; }
    if(($misdaad == 4 || $misdaad == 5 || $misdaad == 6) && $data->nrofcrime >= 45){ $kans = 'tweeopdrie'; $type = 2; }
    if(($misdaad == 4 || $misdaad == 5 || $misdaad == 6) && $data->nrofcrime >= 70){ $kans = 1; $type = 2; }
    if(($misdaad == 7 || $misdaad == 8 || $misdaad == 9) && $data->nrofcrime >= 0){ $kans = 6; $type = 3; }
    if(($misdaad == 7 || $misdaad == 8 || $misdaad == 9) && $data->nrofcrime >= 30){ $kans = 5; $type = 3; }
    if(($misdaad == 7 || $misdaad == 8 || $misdaad == 9) && $data->nrofcrime >= 40){ $kans = 4; $type = 3; }
    if(($misdaad == 7 || $misdaad == 8 || $misdaad == 9) && $data->nrofcrime >= 50){ $kans = 3; $type = 3; }
    if(($misdaad == 7 || $misdaad == 8 || $misdaad == 9) && $data->nrofcrime >= 60){ $kans = 2; $type = 3; }
    if(($misdaad == 7 || $misdaad == 8 || $misdaad == 9) && $data->nrofcrime >= 90){ $kans = 'tweeopdrie'; $type = 3; }
    if(($misdaad == 7 || $misdaad == 8 || $misdaad == 9) && $data->nrofcrime >= 135){ $kans = 1; $type = 3; }
    if(($misdaad == 10 || $misdaad == 11 || $misdaad == 12) && $data->nrofcrime >= 0){ $kans = 6; $type = 4; }
    if(($misdaad == 10 || $misdaad == 11 || $misdaad == 12) && $data->nrofcrime >= 60){ $kans = 5; $type = 4; }
    if(($misdaad == 10 || $misdaad == 11 || $misdaad == 12) && $data->nrofcrime >= 70){ $kans = 4; $type = 4; }
    if(($misdaad == 10 || $misdaad == 11 || $misdaad == 12) && $data->nrofcrime >= 85){ $kans = 3; $type = 4; }
    if(($misdaad == 10 || $misdaad == 11 || $misdaad == 12) && $data->nrofcrime >= 100){ $kans = 2; $type = 4; }
    if(($misdaad == 10 || $misdaad == 11 || $misdaad == 12) && $data->nrofcrime >= 150){ $kans = 'tweeopdrie'; $type = 4; }
    if(($misdaad == 10 || $misdaad == 11 || $misdaad == 12) && $data->nrofcrime >= 225){ $kans = 1; $type = 4; }
    if(($misdaad == 13 || $misdaad == 14 || $misdaad == 15) && $data->nrofcrime >= 0){ $kans = 6; $type = 5; }
    if(($misdaad == 13 || $misdaad == 14 || $misdaad == 15) && $data->nrofcrime >= 110){ $kans = 5; $type = 5; }
    if(($misdaad == 13 || $misdaad == 14 || $misdaad == 15) && $data->nrofcrime >= 120){ $kans = 4; $type = 5; }
    if(($misdaad == 13 || $misdaad == 14 || $misdaad == 15) && $data->nrofcrime >= 140){ $kans = 3; $type = 5; }
    if(($misdaad == 13 || $misdaad == 14 || $misdaad == 15) && $data->nrofcrime >= 200){ $kans = 2; $type = 5; }
    if(($misdaad == 13 || $misdaad == 14 || $misdaad == 15) && $data->nrofcrime >= 300){ $kans = 'tweeopdrie'; $type = 5; }
    if(($misdaad == 13 || $misdaad == 14 || $misdaad == 15) && $data->nrofcrime >= 450){ $kans = 1; $type = 5; }
    if($kans = 'tweeopdrie'){ $geluktt = rand(1,3); if($geluktt == 1 || $geluktt == 2){ $gelukt = 1; } }else{ $gelukt = rand(1,$kans); }
    if($type == 1){ $winst = rand(100,5000); }
    if($type == 2){ $winst = rand(5000,25000); }
    if($type == 3){ $winst = rand(25000,75000); }
    if($type == 4){ $winst = rand(75000,150000); }
    if($type == 5){ $winst = rand(150000,250000); }
    if($type == 1){
    $bernum = rand(0,3);
    if($misdaad == 1){ $bericht = Array("Je kon zijn portefeuille stelen, maar toen kwam hij achter je aan. Je wou hem net in elkaar slaan toen de politie arriveerde. Je zit nu in de gevangenis.","Je dacht dat alles goed verliep, totdat je doorhad dat je een waterpistool had meegenomen in plaats van een echt geweer. De vrouw die je wilde beroven had toevallig een zelfverdedigingscursus gedaan en je kwam weg met een lading blauwe plekken en een geschonden trots.","Hoe dom kun je zijn, wie gaat er dan toch ook op een zondag de snoepwinkel overvallen?","Het oude vrouwtje die je wou bestelen liep van schrik snel weg."); }
    if($misdaad == 2){ $bericht = Array("Je kon ongemerkt wegglippen met de kassa in je handen. Kijk de volgende keer wel uit waar je loopt en loop niet tegen lantaarnpalen op! De politie kon je gemakkelijk arresteren aangezien je buiten westen was.","Het was je gelukt om ongemerkt de winkel binnen te sluipen. Helaas struikelde je over een rondslingerende zuurstok waardoor je viel en je pistool verloor. De eigenaar zag het maar kon geen alarm slaan omdat hij zijn nieuwe alarmsysteem nog niet kende. Je kon ongeschonden wegkomen.","Nadat je de kassa had gestolen bleek hij leeg te zijn!","Toen je de winkel binnenkwam zag je een politieagent, je bent hem gesmeert."); }
    if($misdaad == 3){ $bericht = Array("Valt het niet een klein beetje op als je vrolijk met een vrachtwagen staat in te laden op klaarlichte dag? De politie arresteerde je nadat je de spullen weer netjes had moeten uitgeladen.","Je kon ongemerkt uit het magazijn een kluis meenemen. Maar toen je de politie in de verte zag aankomen heb je de kluis snel gedumpt in de bosjes en je bent weggelopen.","Misschien is het handig om de volgende keer een vrachtwagen te huren om de spullen in op te slaan! Zo te zien heb je niet de meest intelligente vrienden.","Je kon succesvol een kluis stelen, maar toen je de kluis met veel moeite opende bleek er niks in te zitten! Je bent voor gek gehouden door de winkel eigenaar..."); }
    $ber = $bericht[$bernum];
    if($bernum == 0 && $gelukt != 1){ mysql_query("INSERT INTO `jail`(`login`,`boete`,`stad`,`famillie`,`time`) VALUES('$data->login','{$boete}','{$data->stad}','{$data->famillie}',FROM_UNIXTIME($jailtime))"); }
    if($gelukt == 1){
     if($misdaad == 1){ goed("Je ging gladjes te werk en je zorgde ervoor dat anderen niet in konden grijpen. Je verdient <b>&euro; $winst</b>"); }
     if($misdaad == 2){ goed("Na een vlotte overval kon je de kassa snel openkraken die gevuld was met <b>&euro; $winst</b>"); }
     if($misdaad == 3){ goed("Je ging gladjes te werk en je zorgde ervoor dat niemand je kon zien. Je verdient <b>&euro; $winst</b>"); }
     mysql_query("UPDATE `users` SET `zak`=`zak`+$winst WHERE `login`='{$data->login}'");
    }else{ fout("$ber"); if($bernum == 0 && $gelukt != 1){echo'<center><br><br>Je zit in de gevangenis.</center>';} }
    mysql_query("UPDATE `users` SET `xp`=`xp`+1,`crime`=FROM_UNIXTIME($crimetijd),`nrofcrime`=`nrofcrime`+1 WHERE `login`='{$data->login}'");
    exit;
    if($type == 2){
    if($misdaad == 4){ $bericht = Array("Iemand in een supermarkt overvallen die recht tegenover een politiebureau zit is natuurlijk nooit echt handig. Je probeerde nog weg te komen, maar voor de verandering was er een keer genoeg blauw op straat.","Onderschat oude vrouwtjes niet! Toen je haar om haar geld vroeg pakte ze haar pepperspray en spoot het recht in je ogen. Een beetje dizzy verliet je de winkel.","Je kon zijn portefeuille stelen, maar toen kwam hij achter je aan. Je wou hem net in elkaar slaan toen je vanachter een klap kreeg.","Je wou net zijn portefeuille stelen toen al zijn vrienden tevoorschijn kwamen, je rende weg."); }
    if($misdaad == 5){ $bericht = Array("Het is misschien verstandig om niet recht voor een camera te gaan staan als je stiekem je pistool trekt! De bewaking pakten jullie op.","Toen jullie naar de cassière keken schrok je je wezenloos. Je zus zat achter de kassa! Gelukkig liet ze jullie gaan maar wel zonder buit.","Er liep net een andere gangster met een lading geld naar buiten.","Je was de winkel uit, maar je viel over een oude zwerver die buiten zat. Hij nam je geld en liep weg."); }
    if($misdaad == 6){ $bericht = Array("Loopt de overval lekker, blijkt een van je maten een undercover agent te zijn. Inrekenen en wegwezen.","Misschien is het handig om een auto te stelen waar banden onder zitten! Volgende keer beter.","Heb je eindelijk een vrachtwagen geregeld, rijdt je maat hem na een succesvolle overval in de sloot. De politie was snel ter plaatse maar jullie konden ontkomen.","Het magazijn was te goed beveiligd. Je kreeg niet eens de deur open!"); }
    if($gelukt == 1){
     if($misdaad == 4){ goed("Je ging gladjes te werk en je zorgde ervoor dat anderen niet in konden grijpen. Je verdient <b>&euro; $winst</b>"); }
     if($misdaad == 5){ goed("Na een vlotte overval kon je de kassa snel openkraken die gevuld was met <b>&euro; $winst</b>"); }
     if($misdaad == 6){ goed("Het magazijn stond helemaal vol met voorraden. Omdat het erg druk was in de winkel was er geen personeel in het magazijn. Snel laadde je alles in en verkocht je de voorraad bij de dichtsbijzijnde concurrent. Je verdiende <b>&euro; $winst</b>"); }
    exit;
    if($type == 3){
    if($misdaad == 7){ $bericht = Array("Je wapen al trekken voordat je in het kantoor bent is niet erg verstandig. De werknemers zagen het en belden de politie. Terwijl jij de garagehouder beroofde stond de politie buiten het kantoor op je te wachten: Enkeltje gevangenis.","Je liep het kantoor binnen en trok je wapen. De garagehouder lachte en pakte een wapen met dubbel kaliber. Je schrok je te pletter en rende de garage uit vergezeld door een paar kogels.","Je geweer deed het niet en je zette het op lopen!","Toen je in het kantoor aankwam lag alles overhoop en je hoorde sirenes op de achtergrond. Je bent snel gevlucht."); }
    if($misdaad == 8){ $bericht = Array("Je gooide de kassa op de achterbank en ging snel achter het stuur zitten en reed met volle vaart achteruit: tegen een politieauto aan! Je kon geen kant meer op.","Misschien is het handig als je het probeert op een moment dat de garage open is. De garage was goed beveiligd en zodra je de klink aanraakte ging het alarm af. Je kwam met de schrik vrij.","Er word alarm geslagen, je moest wel vluchten anders was je opgepakt","De kassabediende spoot pepperspray in je ogen en je rende vernederend uit de winkel."); }
    if($misdaad == 9){ $bericht = Array("Je werd gearresteerd bij je poging om een auto te stelen.","Misschien is het handig om een auto te stelen waar banden onder zitten! Volgende keer beter.","Nadat je een auto had gestolen werd je achtervolgt, om te ontkomen ben je uit de auto gesprongen en het bos in gerend.","Het lukte je niet om een auto te stelen."); }
    if($gelukt == 1){
    $test = mysql_num_rows(mysql_query("SELECT `login` FROM `missies` WHERE `login`='{$data->id}'"));
    if($test == 0){ mysql_query("INSERT INTO `missies` (`id`,`login`) VALUES(NULL,'{$data->id}')") or die(mysql_error()); }
    $missie = mysql_fetch_object(mysql_query("SELECT `login`,`missie8` FROM `missies` WHERE `login`='{$data->id}'"));
    if($winst >= 70000 && $missie->missie8 == '0'){
     mysql_query("UPDATE `users` SET `bank`=`bank`+100000 WHERE `login`='{$data->login}'");
     mysql_query("UPDATE `missies` SET `missie8`='1' WHERE `login`='{$data->id}'");
     mysql_query("INSERT INTO `messages`(`time`,`from`,`to`,`subject`,`message`) values(NOW(),'Notificatie','{$data->login}','Missie voltooid!','Beste [login],<br><br>Gefeliciteerd! Je hebt de missie \'Steel minimaal €6.000,- bij een garage\' gedaan! Je ontvangt hiervoor &euro;100.000!<br><br>Met vriendelijke groet,<br>Notificatie')");
     if($misdaad == 7){ goed("Je stormde het kantoor van de garagehouder binnen die op dat moment bezoek had van een bepaalde vrouw met wie hij bepaalde acties verrichte. Je hoefde niet eens je wapen te trekken, de garagehouder gaf je al zijn geld als je je mond maar dichthield. De portomonnee was gevuld met <b>&euro; $winst</b>"); }
     if($misdaad == 8){ goed("Na een vlotte overval kon je de kassa snel openkraken die gevuld was met <b>&euro; $winst</b>"); }
     if($misdaad == 9){ goed("Je hebt succesvol een auto gejat! Er zat helaas veel schade aan. Je verkocht de auto voor een mager prijsje van <b>&euro; $winst</b>"); }
    mysql_query("UPDATE `users` SET `xp`=`xp`+2,`crime`=FROM_UNIXTIME($crimetijd),`nrofcrime`=`nrofcrime`+1 WHERE `login`='{$data->login}'");
    exit;
    if($type == 4){
    if($misdaad == 10){ $bericht = Array("Een van de medewerkers had je door en belde snel de politie. De politie was binnen no time ter plaatse, je bent gearresteerd.","Alles verliep perfect totdat je zelf overvallen werd door een mede-crimineel! Hij stopte een geweer in je maag en je liet gewillig de spullen vallen.","Dom! Je wist toch dat je een pasje nodig had om deze winkel in te mogen? Volgende keer beter.","Net toen je de winkel in wou gaan zag je een paar dieven naar buiten rennen. Je bent hem maar gesmeert."); }
    if($misdaad == 11){ $bericht = Array("Toen jij je pistool op de medewerker richtte glimlachte hij, tikte op het raam voor zijn kassa en zei: Kogelvrij glas. Je probeerde nog weg te komen, maar de deuren sloten automatisch.","De cassi&egrave;re had je al door voordat je je pistool trok en liet het alarm afgaan. Misschien is het handig om geen panty meer over je hoofd te doen bij een overval. Gelukkig kon je vluchten.","Net toen je in de kassa wou grijpen zag je dat er een agent de winkel binnenkwam. Gelukkig kon je nog vluchten.","Helaas, de kassa die je had gestolen bleek helemaal leeg te zijn!"); }
    if($misdaad == 12){ $bericht = Array("Na een lange achtervolging op de snelweg na een dramatische en erg opvallende overval raakte de benzine op. Je moesten de wagen langs de kant zetten, de kluis afstaan en mee naar het bureau.","Een medewerker vragen om de sleutel van de kluis wekt argwaan op. Gelukkig was je zo slim om weg te gaan uit de winkel bij het benzine station.","Je bent je gereedschap vergeten, je bent hem gesmeert.","Toen je bij de kluis aankwam bleek er een nieuw beveiligingssysteem te zijn ge&iuml;nstalleerd. Je bent hem gesmeert."); }
    if($gelukt == 1){
     if($misdaad == 10){ goed("Stiekem pakte je wat dure tijdschriften en flesjes drinken uit de schappen. Omdat het zo druk was had de medewerker niets door. Toen hij eenmaal doorhad dat het stille alarm afging reed je al lang en breed weer op de snelweg. Je verkocht de spullen voor maar liefst &euro;'.$winst</b>"); }
     if($misdaad == 11){ goed("De cassi&egrave;re schrok zich een ongeluk toen zij jou met een panty over je hoofd zag staan aan de andere kant. Zij gooide de hele kassa in je tas leeg: <b>&euro; $winst</b>"); }
     if($misdaad == 12){ goed("Je hebt succesvol een kluis gestolen met <b>&euro; $winst</b> erin!"); }
    exit;
    if($type == 5){
    if($misdaad == 13){ $bericht = Array("Wat jammer dat er tegenwoordig zichtbare en onzichtbare beveiliging in de juwelierswinkel zit! Toen het alarm afging wist je dat je erbij was.","Heel verstandig! Een overval plegen op koopavond terwijl de hele winkel vol zit. Gelukkig was je w&eacute;l zo wijs om te vluchte.","Omdat er tegenwoordig veel word gestolen uit de juwelier rijden er extra patrouillewagens langs. Toen je net de straat om liep zag je er een langsrijden. Je bent langs de juwelier doorgelopen.","Je zag een oude mevrouw met juwelen de winkel uitlopen. Je steelde de juwelen en rende weg. Maar toen je ze wou verkopen bleken deze nep te zijn!"); }
    if($misdaad == 14){ $bericht = Array("De verkoper had je allang door en op het moment dat je je pistool trok liet een van de agenten een kuchje en wist je dat je er bij was.","Wat een mislukking! Het was het nieuwste type kassa, waar je nog nooit van gehoord had. Ga eerst wat achtergrond informatie zoeken voordat je het nog een keer probeert.","Je werd door de bewakers de winkel uitgesmeten omdat je er nogal arm uit zag. Volgende keer beter!","Het was veel te druk in de winkel, je bent de winkel maar weer uitgelopen."); }
    if($misdaad == 15){ $bericht = Array("De kluis was automatisch gelinkt aan het politiebureau dat vlakbij gevestigd is. De politie was binnen no time ter plaatse.","De verkoper rook het kruid dat je had meegebracht in de vorm van dynamiet om de kassa op te blazen. Toen hij nerveus zei dat hij een telefoontje ging plegen wist je dat het fout zat en nam je de benen.","Het magazijn was met stalen deuren beveiligd. Je kon er zelfs niet met je drilboor doorheen! Toen je iemand eraan hoorde komen ben je gevlucht.","Deze juwelierszaak bleek helemaal geen magazijn te hebben! Vreemd..."); }
    if($gelukt == 1){
    $missie = mysql_fetch_object(mysql_query("SELECT `login`,`missie9` FROM `missies` WHERE `login`='{$data->id}'"));
    if($winst >= 245000 && $missie->missie9 == '0'){
     mysql_query("UPDATE `missies` SET `missie9`='1' WHERE `login`='{$data->id}'");
     mysql_query("INSERT INTO `messages`(`time`,`from`,`to`,`subject`,`message`) values(NOW(),'Notificatie','{$data->login}','Missie voltooid!','Beste [login],<br><br>Gefeliciteerd! Je hebt de missie \'Steel minimaal €55.000,- bij een juwelier\' gedaan! Je ontvangt hiervoor &euro;100.000!<br><br>Met vriendelijke groet,<br>Notificatie')");
     if($misdaad == 13){ goed("De verkoper trapte volledig in je acteertalent. Als een zakenman hield je de verkoper bezig terwijl je de juwelen in een plastic tas stopte. Toen de verkoper er achter kwam dat je de juwelen had gestolen had je ze allang weer doorverkocht voor <b>&euro; $winst</b>"); }
     if($misdaad == 14){ goed("Je hebt succesvol de kassa gestolen, er zat maar liefst <b>&euro; $winst</b> in de kassa!"); }
     if($misdaad == 15){ goed("Terwijl je de verkoper onder schot hield zocht je beste maat ondertussen naar de kluis. Toen hij hem gevonden had, natuurlijk achter het lelijkste schilderij, maakte hij hem in enkele minuten open dankzij zijn ervaring. Je kreeg de helft van de buit: <b>&euro; $winst</b>"); }
    mysql_query("UPDATE `users` SET `xp`=`xp`+3,`crime`=FROM_UNIXTIME($crimetijd),`nrofcrime`=`nrofcrime`+1 WHERE `login`='{$data->login}'");
    exit;
    if($data->nrofcrime >= 0){ $kans = 6; $type = 1; }
    if($data->nrofcrime >= 5){ $kans = 5; $type = 1; }
    if($data->nrofcrime >= 10){ $kans = 4; $type = 1; }
    if($data->nrofcrime >= 15){ $kans = 3; $type = 1; }
    if($data->nrofcrime >= 20){ $kans = 2; $type = 1; }
    if($data->nrofcrime >= 30){ $kans = 1.5; $type = 1; }
    if($data->nrofcrime >= 45){ $kans = 1; $type = 1; }
    $kans1 = ceil(100/$kans);
    if($data->nrofcrime >= 0){ $kans = 6; $type = 2; }
    if($data->nrofcrime >= 10){ $kans = 5; $type = 2; }
    if($data->nrofcrime >= 15){ $kans = 4; $type = 2; }
    if($data->nrofcrime >= 25){ $kans = 3; $type = 2; }
    if($data->nrofcrime >= 30){ $kans = 2; $type = 2; }
    if($data->nrofcrime >= 45){ $kans = 1.5; $type = 2; }
    if($data->nrofcrime >= 70){ $kans = 1; $type = 2; }
    $kans2 = ceil(100/$kans);
    if($data->nrofcrime >= 0){ $kans = 6; $type = 3; }
    if($data->nrofcrime >= 30){ $kans = 5; $type = 3; }
    if($data->nrofcrime >= 40){ $kans = 4; $type = 3; }
    if($data->nrofcrime >= 50){ $kans = 3; $type = 3; }
    if($data->nrofcrime >= 60){ $kans = 2; $type = 3; }
    if($data->nrofcrime >= 90){ $kans = 1.5; $type = 3; }
    if($data->nrofcrime >= 135){ $kans = 1; $type = 3; }
    $kans3 = ceil(100/$kans);
    if($data->nrofcrime >= 0){ $kans = 6; $type = 4; }
    if($data->nrofcrime >= 60){ $kans = 5; $type = 4; }
    if($data->nrofcrime >= 70){ $kans = 4; $type = 4; }
    if($data->nrofcrime >= 85){ $kans = 3; $type = 4; }
    if($data->nrofcrime >= 100){ $kans = 2; $type = 4; }
    if($data->nrofcrime >= 150){ $kans = 1.5; $type = 4; }
    if($data->nrofcrime >= 225){ $kans = 1; $type = 4; }
    $kans4 = ceil(100/$kans);
    if($data->nrofcrime >= 0){ $kans = 6; $type = 5; }
    if($data->nrofcrime >= 110){ $kans = 5; $type = 5; }
    if($data->nrofcrime >= 120){ $kans = 4; $type = 5; }
    if($data->nrofcrime >= 140){ $kans = 3; $type = 5; }
    if($data->nrofcrime >= 200){ $kans = 2; $type = 5; }
    if($data->nrofcrime >= 300){ $kans = 1.5; $type = 5; }
    if($data->nrofcrime >= 450){ $kans = 1; $type = 5; }
    $kans5 = ceil(100/$kans);
    <form action="misdaad.php" method="post">
    <center><table width="100%">
    <tr><td class="lightTxt" colspan="6">Snoepwinkel</td></tr>
    if($misdaad1 == 0){ echo '<tr><td class="lightTxt2" colspan="6"><center><a href="misdaad.php?show=1">Weergeef de snoepwinkel</a></center></td></tr>'; }
    else{
     <td class="lightTxt2" rowspan="3" width="40%"><center><img src="images/misdaad-1.jpg" border="0"><br /><a href="misdaad.php?hide=1"><small>Verberg de snoepwinkel</small></a></center></td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="1" checked></td>
     <td class="lightTxt2"><img src="images/icons3/light-bulb.png" width="16" height="16" border="0"></td>
     <td class="lightTxt2">Beroof een consument</td>
     <td class="lightTxt2"><img src="images/icons3/chart.png" width="16" height="16" border="0"></td>
     <td class="lightTxt2" width="15%"><?= ($kans1)-(rand(0,2)) ?>% kans</td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="2"></td>
     <td class="lightTxt2">Beroof de kassa</td>
     <td class="lightTxt2"><?= ($kans1)-(rand(0,7)) ?>% kans</td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="3"></td>
     <td class="lightTxt2">Beroof het magazijn</td>
     <td class="lightTxt2"><?= ($kans1)-(rand(0,5)) ?>% kans</td>
    <tr><td class="lightTxt2" colspan="6"><center><input type="submit" name="submit" value="Doe misdaad!" style="width:120px"></center></td></tr>
    <?php } ?>
    <br />
    <tr><td class="lightTxt" colspan="6">Supermarkt</td></tr>
    if($data->xp < 20){ echo '<tr><td class="lightTxt2" colspan="6"><center>Deze optie is pas beschikbaar vanaf Picciotto (rang 3).</center></td></tr>'; }
    elseif($misdaad2 == 0){ echo '<tr><td class="lightTxt2" colspan="6"><center><a href="misdaad.php?show=2">Weergeef de supermarkt</a></center></td></tr>'; }
    else{
     <td class="lightTxt2" rowspan="3" width="40%"><center><img src="images/misdaad-2.jpg" border="0"><br /><a href="misdaad.php?hide=2"><small>Verberg deze optie</small></a></center></td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="4" checked></td>
     <td class="lightTxt2" width="15%"><?= ($kans2)-(rand(0,3)) ?>% kans</td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="5"></td>
     <td class="lightTxt2"><?= ($kans2)-(rand(0,4)) ?>% kans</td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="6"></td>
     <td class="lightTxt2"><?= ($kans2)-(rand(0,7)) ?>% kans</td>
    <?php } ?>
    <br />
    <tr><td class="lightTxt" colspan="6">Garage</td></tr>
    if($data->xp < 150){ echo '<tr><td class="lightTxt2" colspan="6"><center>Deze optie is pas beschikbaar vanaf Pickpocket (rang 5).</center></td></tr>'; }
    elseif($misdaad3 == 0){ echo '<tr><td class="lightTxt2" colspan="6"><center><a href="misdaad.php?show=3">Weergeef de garage</a></center></td></tr>'; }
    else{
     <td class="lightTxt2" rowspan="3" width="40%"><center><img src="images/misdaad-3.jpg" border="0"><br /><a href="misdaad.php?hide=3"><small>Verberg deze optie</small></a></center></td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="7" checked></td>
     <td class="lightTxt2">Beroof de eigenaar</td>
     <td class="lightTxt2" width="15%"><?= ($kans3)-(rand(0,4)) ?>% kans</td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="8"></td>
     <td class="lightTxt2"><?= ($kans3)-(rand(0,2)) ?>% kans</td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="9"></td>
     <td class="lightTxt2">Steel een auto</td>
     <td class="lightTxt2"><?= ($kans3)-(rand(0,5)) ?>% kans</td>
    <?php } ?>
    <br />
    <tr><td class="lightTxt" colspan="6">Benzinestation</td></tr>
    if($data->xp < 1000){ echo '<tr><td class="lightTxt2" colspan="6"><center>Deze optie is pas beschikbaar vanaf Associate (rang 7).</center></td></tr>'; }
    elseif($misdaad4 == 0){ echo '<tr><td class="lightTxt2" colspan="6"><center><a href="misdaad.php?show=4">Weergeef het benzinestation</a></center></td></tr>'; }
    else{
     <td class="lightTxt2" rowspan="3" width="40%"><center><img src="images/misdaad-4.jpg" border="0"><br /><a href="misdaad.php?hide=4"><small>Verberg deze optie</small></a></center></td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="10" checked></td>
     <td class="lightTxt2">Steel consumpties</td>
     <td class="lightTxt2" width="15%"><?= ($kans4)-(rand(0,7)) ?>% kans</td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="11"></td>
     <td class="lightTxt2"><?= ($kans4)-(rand(0,2)) ?>% kans</td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="12"></td>
     <td class="lightTxt2">Beroof de kluis</td>
     <td class="lightTxt2"><?= ($kans4)-(rand(0,3)) ?>% kans</td>
    <?php } ?>
    <br />
    <tr><td class="lightTxt" colspan="6">Juwelier</td></tr>
    if($data->xp < 3000){ echo '<tr><td class="lightTxt2" colspan="6"><center>Deze optie is pas beschikbaar vanaf Leader (rang 9).</center></td></tr>'; }
    elseif($misdaad5 == 0){ echo '<tr><td class="lightTxt2" colspan="6"><center><a href="misdaad.php?show=5">Weergeef de juwelier</a></center></td></tr>'; }
    else{
     <td class="lightTxt2" rowspan="3" width="40%"><center><img src="images/misdaad-5.jpg" border="0"><br /><a href="misdaad.php?hide=5"><small>Verberg deze optie</small></a></center></td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="13" checked></td>
     <td class="lightTxt2">Steel juwelen</td>
     <td class="lightTxt2" width="15%"><?= ($kans5)-(rand(0,3)) ?>% kans</td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="14"></td>
     <td class="lightTxt2"><?= ($kans5)-(rand(0,4)) ?>% kans</td>
     <td class="lightTxt2"><input type="radio" name="misdaad" value="15"></td>
     <td class="lightTxt2"><?= ($kans5)-(rand(0,2)) ?>% kans</td>
    <?php } ?>
    </td></tr></table>
    <?php include("_onderbalk.php"); ?>
    • 27 augustus 2012 om 01:59
    Wat heb je geprobeerd?
  • zwpgangster
    • 27 augustus 2012 om 08:33
    normaal gesproken zit er een rand functie in zodat je om de zoveel keer een keer mislukt en dan paar keer lukt en dan weer mislukt!
    MD-IT Solutions
  • L.Kok
    • 27 augustus 2012 om 08:44
    Stel dat ik dit doe:
    $succeskans = rand(0, 100);
    //Kijken of de misdaad is gelukt, je hebt bij deze misdaad 40% kans dat hij lukt
    if($succeskans <= 40){
    echo'misdaad gelukt!';
    }else{
    echo'misdaad mislukt!';
    Natuurlijk is dit niet zo een mooi manier omdat de kans altijd zal blijven staan op 40 en dit dus niet leuk is voor de spelers.
    Echter kan je iets maken zodat de kans wordt berekend door het aantal keer dat de speler een misdaad heeft uitgevoerd.
    L.Kok
    YoungVision
  • zwpgangster
    • 27 augustus 2012 om 14:36
    L.Kok,
    Je kan ook een array maken zoals jij bedoeld?
    $succeskans array(40,60,80,100,10,20,30,40,50,60,70,80,90,100)
    MD-IT Solutions
  • mattie1992
    • 27 augustus 2012 om 15:22
    oke maar ziet ook iemand de fout in mijn script? Ik kan het zelf namelijk niet vinden :(
  • zwpgangster
    • 27 augustus 2012 om 15:30
    het is geen fout, je moet gewoon iets aanpassen zodat als hij 100% kans is dat hij ook gewoon lukt..
    Misschien een soort van voorbeeld:
    if($kans5 == 100){
    $succeskans = 100
    }else{
    }else{
    MD-IT Solutions
  • mattie1992
    • 28 augustus 2012 om 16:44
    ik kom er nog steeds niet uit :( is er nog iemand die mij een klein voorbeeld kan geven in mijn script?
  • Donny5300
    • 28 augustus 2012 om 17:06
    Ik heb in mijn script heel iets anders... Bij mijn script staat de kans in de database... De kans percentage wordt eruit gehaald. Een mt_rand functie word weergeven. Als de waarde uit de database kleiner is dan mislukt de misdaad. Als de waarde groter is dan de mt_rand, dan lukt de misdaad. Misschien heb je hier wat aan? Contact me anders even via PM of iets, dan zet ik kort een voorbeeldje in elkaar :)
    Meld je alvast aan op Underworld Mafia Nation! ! Er wordt druk gesleuteld aan deze website, en wanneer het klaar is krijgt iedereen een mail voor de ronde start!
    • Nieuwe layout onderweg!
    • Nieuwe updates in ontwikkeling!
