  • Ictscripters / Koen
    frio 2 oktober 2026 om 14:45
    shiga 1 oktober 2026 om 19:09
Cron probleem
  • verkuylenr
  • 7 juni 2010 om 21:05
  • verkuylenr
    Hallo allemaal ik ben begonnen met mijn eigen criminals.
    Nu heb ik de crons gemaakt maar nu telt hij elke seconde de rente bij contant en bank geld
    dit moet eigenlijk elk uur doen
    dit is mijn cron
      $lastupdate = $sql->query("SELECT online FROM users ORDER BY online DESC LIMIT 1");
      $lastupdate = $sql->fetch($lastupdate, assoc);
      $lastupdate = strtotime($lastupdate['online']);
      $sec = strtotime(date("Y-m-d H", $lastupdate) . "00:00:00");
      $verschil = floor((time() - $sec) / 1);
      //sec:
      if($verschil > 100) {
          $sql->query("UPDATE users SET  health = '100'");
      $hour = strtotime(date("Y-m-d H", $lastupdate) . "00:00:00");
      $verschil = floor((time() - $hour) / 3600);
      //HOUR:
      if($verschil > 0) {
        $sql->query("UPDATE users SET veilig = veilig - '" . $verschil . "' WHERE veilig > '" . $verschil . "'");
        $sql->query("UPDATE users SET veilig = '0' WHERE veilig <= '" . $verschil . "'");
        $sql->query("UPDATE users SET maffia = maffia - '" . $verschil . "' WHERE maffia > '" . $verschil . "'");
        $sql->query("UPDATE users SET maffia = '0' WHERE maffia <= '" . $verschil . "'");
        $sql->query("UPDATE users SET bank = bank + '" . ($verschil * 250) . "'") or die(mysql_error());
        $sql->query("UPDATE users SET bank = bank + '" . ($verschil * 250) . "' WHERE betaald > '0'") or die(mysql_error());
        $sql->query("UPDATE users SET cash = cash + '" . ($verschil * 500) . "' WHERE UNIX_TIMESTAMP(NOW()) - UNIX_TIMESTAMP(online) <= '180'") or die(mysql_error());
        //DRUGS EN DRANK:
        $drugs = $sql->query("SELECT resetvalue, stad, naam FROM koersen");
        while($drug = $sql->fetch($drugs, assoc)) {
          $values = explode(', ', $drug['resetvalue']);
          $sql->query("UPDATE koersen SET koers = '" . rand($values[0], $values[1]) . "' WHERE resetvalue = '" . $drug['resetvalue'] . "' AND stad = '" . $drug['stad'] . "' AND naam = '" . $drug['naam'] . "'") or die(mysql_error());
      //DAY:
      $day = strtotime(date("Y-m-d", $lastupdate) . " 00:00:00");
      $verschil = floor((time() - $day) / 86400);
      if($verschil > 0) {
        $sql->query("UPDATE users SET betaald = betaald - '" . $verschil . "' WHERE betaald > '" . $verschil . "'");
        $sql->query("UPDATE users SET betaald = '0' WHERE betaald <= '" . $verschil . "'");
        $sql->query("UPDATE users SET vakantie = vakantie - '" . $verschil . "' WHERE vakantie > '" . $verschil . "'");
        $sql->query("UPDATE users SET vakantie = '0' WHERE vakantie <= '" . $verschil . "'");
        $sql->query("UPDATE users SET respect_uitdelen = respect_uitdelen + '" . $verschil . "'");
        $sql->query("UPDATE users SET bank = bank + (bank * '0.10') * '" . $verschil . "' WHERE rentedagen > '0'");
        $sql->query("UPDATE users SET bank = bank + (bank * '0.05') * '" . $verschil . "' WHERE rentedagen <= '0' AND betaald > '0'");
        $sql->query("UPDATE users SET bank = bank + (bank * '0.03') * '" . $verschil . "' WHERE rentedagen <= '0' AND betaald <= '0'");
        $sql->query("UPDATE users SET rentedagen = rentedagen - '" . $verschil . "' WHERE rentedagen > '" . $verschil . "'");
        $sql->query("UPDATE users SET rentedagen = '0' WHERE rentedagen <= '" . $verschil . "'");
        $sql->query("UPDATE users SET roulette = '0'");
        $sql->query("UPDATE users SET nederwiet = nederwiet + nederwietup");
        $sql->query("UPDATE users SET xtc = xtc + xtcup");
        $sql->query("UPDATE users SET lsd = lsd + lsdup");
        $sql->query("UPDATE users SET speed = speed + speedup");
        $sql->query("UPDATE users SET opium = opium + opiumup");
        $sql->query("UPDATE users SET storten = stortenreset");
        $sql->query("DELETE FROM clicks WHERE UNIX_TIMESTAMP(NOW()) - UNIX_TIMESTAMP(datum) >= '432000'");
        $sql->query("DELETE FROM berichten WHERE UNIX_TIMESTAMP(NOW()) - UNIX_TIMESTAMP(datum) >= '432000'");
        $sql->query("DELETE FROM attacklog WHERE UNIX_TIMESTAMP(NOW()) - UNIX_TIMESTAMP(datum) >= '432000'");
      $week = strtotime(date("Y-m-d H", $lastupdate) . "00:00:00");
      $verschil = floor((time() - $week) / 604800);
      //week:
      if($verschil <= 0) {
    Wat doe ik fout?
  • Jannick
    nyan nyan nyan nyan
    • 7 juni 2010 om 21:12
    Waarschijnlijk heb je dan in je DirectAdmin of zo een * niet naar 0 geset. Als je bijvoorbeeld dit hebt:
    Seconden - Minuten - Uren - Dagen
    Dan voert ie het elk uur uit, en elke minuut, en elke dag...
    Zet dat dan bijvoorbeeld naar
    Seconden - MInuten - Uren - Dagen
    0 0 * *
    Denk dat dit weinig met de cron zelf te maken heeft.
  • verkuylenr
    • 7 juni 2010 om 21:19
    dus ik moet het zo zetten?
  • Jannick
    nyan nyan nyan nyan
    • 7 juni 2010 om 21:30
    Nee. Uur moet ook een * zijn. Minuut op 0. En command moet een PHP-commando bevatten, en het absolute pad naar de PHP-file.
    Ik heb het zo:
    Link: http://upload.jannickbolten.nl/fbiwars.nl_-_D…75939459576.png
  • verkuylenr
    • 7 juni 2010 om 21:40
    sorry dit werkt niet :(
  • Jannick
    nyan nyan nyan nyan
    • 7 juni 2010 om 21:44
    Hoe had je het eerst staan?
  • verkuylenr
    • 7 juni 2010 om 21:51
    eerst stond er niks in..
    het werkte gewoon hij heeft het 1 dag goed gedaan.. bijna 2
    Nieuwe reactie samengevoegd met originele reactie op 07.06.10 22:07:08:
    edit: het zit hem in regel 23 tot en met 25
  • jemajeroen
    eerst: basshunter
    • 8 juni 2010 om 09:13
    *BUMP* op verzoek van topic starter
    • 8 juni 2010 om 09:56
    Veiligste is dat als je de cron neit in public_html zet . ;)
    Waarom?! Zodat mensen er niet zomaar bij kunnen. ;)
    Maar ts, wat is je pad nu in directadmin?
    Ieder geval heb je wel het goede pad in gevuld, ik neem aan dat je weet waar hij staat en welk pad dat is. Want test het is even na in je ftp zodat je zeker weet dat het goed is.
  • verkuylenr
    • 8 juni 2010 om 10:22
    mijn pad in direct admin is:
    /home/dwktcuyp/domains/crime-hell.nl/public_html/ronde1/includes
    Want mn cron staat in de map includes. Ik weet wel dat alleen de cron hour steeds flipt.
  • Mokerr
    Webspetter.nl
    • 8 juni 2010 om 11:34
    G4G source is illigaal!
  • jemajeroen
    eerst: basshunter
    • 8 juni 2010 om 11:40
    Daargaan we weer hoor...
    dit is de G4G Clone!
    Nieuwe reactie samengevoegd met originele reactie op 08.06.10 12:21:28:
    Het is opgelost.
    De fout zat in de config doordat iemand die het treinstation wou maken de hour blokeerde.
