captcha...
  • AeroXbird
  • 8 november 2009 om 14:39
  • AeroXbird
    Lua/PHP scriptorrrrrr xD
    hallo criminalspoint, ik ben de laatste tijd bezig met een captcha script maar het lukt me nu niet echt om de verificatie in te voeren
    else{
       //request everything
       $dead = false; //We make 'dead' if some fields are not filled in don't check for pass and name in db.
       $message = "<font face=verdana size=1>Pleas fill in all fields correctly:<br>";
       $username = $_POST['name'];
       $pass1 = $_POST['pass1'];
       $pass2 = $_POST['pass2'];
       $email = $_POST['email'];
       $type = '1'; // level 1 = Non-official member | Level 2 =  Member | level 3 = Forum Mod | level 4 = ingame/forum moderator | level 5 = Administrator both ingame and forum |
       //begin search for errors
       if(strlen($username) <= 1 or strlen($username) >=15){
          $dead = true;
          $message = "Username (2-14)<br>";
       if (strlen($email) < 6 or strlen($email) > 70){
       $dead = true;
       $message = 'U need to fill in an e-mail!';
       if(strlen($pass1) < 6 or strlen($pass1) > 20 or $pass1 !== $pass2) {
          $dead = true;
          $message = "Password (6-20) or passwords does not match";
       if($dead == false and md5($_POST['norobot']) == $_SESSION['randomnr2']){
          $username = strtolower(trim(strip_tags($username)));
          $pass1 = trim($pass1);
          $pass1 = md5($pass1);
          $query = mysql_query("SELECT * FROM users WHERE login ='$username'");
          $aantalrijen = mysql_num_rows($query);
    	  print 'CAPTCHA PASSED!';
    	  else{
    	  print 'Bad captcha, try again';
          if($aantalrijen == 1){
             print "<font face=verdana size=1>Sorry, that username already exists.";
          else{
             $query1 = "INSERT INTO users(login, pass, ip, type, signup, email) VALUES ('$username','$pass1', '$ip','$type', 'NOW()', '$email')";
    		 $query = mysql_query($query1) or die (mysql_error());
             if($query){
                 print "<font face=verdana size=1>Welcome to The EXF clan, soon an admin of the clan may promote u to real member!<br><a href=login.php>Login now!</a>";
    elseif($dead == true){
             print $message;
    Error:
    Parse error: syntax error, unexpected T_ELSE in /var/www/exfclan.nl/htdocs/beta/register.php on line 195
    het script MOET checken of de captcha goed is, dan mag de query worden gestart, is de captcha fout, word er een foutmelding weergeven en de query NIET uitgevoerd
    ik hoop dat jullie mij kunnen helpen 8-|
    mvg,
    AeroXbird :D
  • Jasper
    • 8 november 2009 om 14:40
    misschien handig om de fout aan te geven, er staat nu wel dat regel 195 een fout bevat maar je script loopt nu maar tot 50 ;)
  • AeroXbird
    • 8 november 2009 om 14:41
    dat klopt,
    het probleem ligt onder :
    die else dus
  • MrMees
    De causeur!
    • 8 november 2009 om 14:42
    else{
          $dead = true;
       $dead = true;
          $dead = true;
          } //hier een haakje vergeten!
          else{
          else{
             if($query){
             print $message;
    Volgens mij is die zo goed :cheer:.
    Rembo&amp;amp;Rembo.
  • AeroXbird
    • 8 november 2009 om 14:44
    nee helaas niet, krijg nu een fout bij:
    maar je sluit de if af waarbij alles goed is gelijk voor mijn captcha check af dus dan kan de query ook niet gestart worden
  • MrMees
    De causeur!
    • 8 november 2009 om 14:58
    Welke error krijg je, en plaats je hele script op code dump of iets dergelijks.
  • AeroXbird
    • 8 november 2009 om 15:01
    ik probeer het nu op een andere manier, door de captcha te checken als hij FOUT is en op verzoek post ik hierbij mijn volledige code: http://pastebin.com/d6f5c5030
    AeroXbird
  • MrMees
    De causeur!
    • 8 november 2009 om 15:37
    En wat is er nou fout?
  • AeroXbird
    • 8 november 2009 om 15:48
    sorry, ik heb zelf in de tussentijd het probleem al opgelost :$ maar dankzij een paar "fixes" ben ik er zelf achter gekomen dus toch nog bedankt!
    :slotje: graag dan maar
    • 8 november 2009 om 15:49
