Betreft Doneren (Oud criminals script)
  • Dvalken
  • 8 juli 2017 om 22:19
  • Dvalken
    Beste mensen ik heb het ouden criminals script weer eens onder de ogen genomen maar blijf hangen met mijn donatie script,
    Hij stuurt namelijk het geld niet door en geeft ook geen melding oid
    misschien kijk ik er over heen
      $OMNILOG				= 1;
      if(! check_login()) {
        exit;
    <html>
    <head>
    <title>[( Criminals )]</title>
    <link rel="stylesheet" type="text/css" href="<?php echo ($_COOKIE['v'] == 2) ? "css-v2.css" : "css-v1.css"; ?>">
    <body style="background: #136E1D; margin: 0px;">
    <table width=100%>
      if(round($data->signup/3600-time()/3600) + 12 <= 0) {
        $dbres				= mysql_query("SELECT `login`,UNIX_TIMESTAMP(`signup`) AS `signup`,`cash` FROM `[users]` WHERE `login`='{$_GET['x']}' AND `activated`=1");
        if(($to = mysql_fetch_object($dbres)) && $to->login != $data->login) {
          if(round($to->signup/3600-time()/3600) + 12 <= 0) {
            print "  <tr><td class=\"subTitle\"><b>Doneren</b></td></tr>\n";
            if(isset($_POST['amount']) && preg_match("/^[0-9]+\$/",$_POST['amount']) && $_POST['amount'] > 0) {
              $amount			= $_POST['amount'];
              if($amount <= $data->cash) {
                mysql_query("SELECT GET_LOCK('donate_{$to->login}',5)");
                $data->cash			-= $amount;
                $to->cash			+= $amount;
                mysql_query("UPDATE `[users]` SET `cash`={$data->cash} WHERE `login`='{$data->login}'");
                mysql_query("UPDATE `[users]` SET `cash`={$to->cash} WHERE `login`='{$to->login}'");
                $forwardedFor		= ($_SERVER['HTTP_X_FORWARDED_FOR'] != "") ? $_SERVER['HTTP_X_FORWARDED_FOR'] : $_SERVER['HTTP_CLIENT_IP'];
                $forwardedFor		= preg_replace('/, .+/','',$forwardedFor);
                mysql_query("INSERT INTO `[logs]`(`time`,`IP`,`forwardedFor`,`login`,`person`,`code`,`area`) values(NOW(),'{$_SERVER['REMOTE_ADDR']}','$forwardedFor','{$data->login}','{$to->login}',$amount,'donate')");
                print "  <tr><td class=\"mainTxt\">Het bedrag is overgemaakt</td></tr>\n";
                mysql_query("SELECT RELEASE_LOCK('donate_{$to->login}')");
                print "  <tr><td class=\"mainTxt\">Zoveel geld heb je niet</td></tr>\n";
            print "  <tr><td class=\"mainTxt\">{$to->login} staat nog onder bescherming</td></tr>\n";
        print <<<ENDHTML
    	<table align="center">
    	  <tr><td width=100>Contant:</td>	<td align="right">\${$data->cash}</td></tr>
    	<form method="post"><table align="center">
    	  <tr><td width=60>Aan:</td>  <td><input type="text" name="to" value="{$_GET['x']}"></td></tr>
    		<tr><td width=60>Bedrag:</td>  <td><input type="text" name="amount"></td></tr>
    		<tr><td></td>  <td align="right"><input type="submit" name="submit" value="Doneer"  style="width: 100;"></td></tr>
    	</table></form>
      </td></tr>
    ENDHTML;
        print "  <tr><td class=\"mainTxt\">Je kan niet doneren wanneer je onder bescherming staat</td></tr>\n";
    </body>
    </html>
    <CENTER><SCRIPT TYPE="text/javascript" LANGUAGE="JavaScript" src="http://www.dutchleader.com/php/banex/view.php?id=leonie"></script></CENTER>
    • 8 juli 2017 om 23:36
    Zet het volgende eens boven je code. Dit is om eventuele fouten op te sporen:
    error_reporting(E_ALL);
    ini_set("display_errors", 1);
    Daarnaast is het gebruik van de mysql_* functies verouderd, onveilig en daarom dus ook af te raden.
    Om dan nog maar te zwijgen over het escapen van globals, of juist het ontbreken daarvan.
  • Dvalken
    • 9 juli 2017 om 10:59
    maakt niet uit ik wil gewoon het script volledig werkzaam hebben, voor eigen gebruik
    • 9 juli 2017 om 11:14
    Awel hij geeft toch hoe je het kan oplossen?
  • Dvalken
    • 9 juli 2017 om 13:59
    haha nee ben er mee bezig het was eerder de reactie die je erbij gaf
    • 9 juli 2017 om 17:03
    Hij heeft toch gelijk? Kan evengoed zijn dat je server zelf geen myqsl ondersteund...
  • T.Nijborg
    Hoofd Moderators
    • 11 juli 2017 om 22:11
    Citaat van Dvalken
    Citaat van Dvalken
    Dit maakt wel degelijk uit, de MySQL.* functies die @Victor omschrijft wordt door nieuwere PHP versie niet meer ondersteunt (Ik heb al mijn servers op PHP 7 of hoger draaien), waar de functies niet meer werken.
    Daarnaast het stukje code wat victor je wilt laten toevoegen is het aanzetten van foutmeldingen, hierdoor, op het moment dat jij jou stuk code draait, kun je zien of er iets mis gaat (Je krijgt dan fout meldingen te zien). Mochten er nou geen fout meldingen komen, kun je het beste gaan traceren waar het mis gaat, bijvoorbeeld door middel van echo's plaatsen, hierdoor (Althans zo doe ik het ;) ) kan ik zie tot waar mijn code runt, bijvoorbeeld voor een if statement een echo plaatsen, in de if statement, etc. Hierdoor zie je tot waar je code loopt, en kun je enigszins traceren waarom jij geen meldingen etc te zien krijgt.
    • 11 juli 2017 om 22:25
    Als aanvulling zou ik ook foutafhandeling inbouwen. Dit kan door middel van exceptions. Mocht je daar niet uitkomen, ask away! Als ik een query nu misloopt of niet doet wat jij verwacht heb je geen idee. 'Maakt niet uit ik wil gewoon dat het werkt' gaat daarom in deze case niet helemaal op.
    Ben je er al achter wat de fout is?
    • 16 juli 2017 om 07:52
    Je kan ook eens kijken naar een iets nieuwere source en vanuit daar gaan bouwen:
    https://github.com/Pattoow/Criminals
  • 3 Gasten
