  • GEZ Crimevalley source
Basing
  • lhmedia
  • 19 augustus 2009 om 16:30
  • lhmedia
    ik ben bezig met mijn site w3c valide temaken maar ik kom deze error tegen en ik snap de error niet helemaal. dit is de error:
    Line 95, Column 49: document type does not allow element "div" here; missing one of "object", "ins", "del", "map", "button" start-tag
    <a href="index.php?p=register"><div id="button2">Aanmelden</div></a> ✉
    The mentioned element is not allowed to appear in the context in which you've placed it; the other mentioned elements are the only ones that are both allowed there and can contain the element mentioned. This might mean that you need a containing element, or possibly that you've forgotten to close a previous element.
    One possible cause for this message is that you have attempted to put a block-level element (such as "<p>" or "<table>") inside an inline element (such as "<a>", "<span>", or "<font>").
    kan iemand mij aub helpen?
  • Niels
    -1
    • 19 augustus 2009 om 16:33
    Laat hem eens via w3 zelf zien. Dus met de link naar de site waar je aan werkt. Dit is nogal irritant om het zo te lezen zonder in iedergeval code tags
    -1
  • lhmedia
    • 19 augustus 2009 om 16:34
    w3 url:
    http://validator.w3.org/check?uri=http…lidator%2F1.654
    php script:
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="nl" lang="nl">
            <head>
                    <title>ItalianDon - Be a Godfather</title>
                    <link rel="stylesheet" type="text/css" href="opmaak.css" />
    				<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
    var dragswitch=0
    var nsx
    var nsy
    var nstemp
    function drag_dropns(name){
    temp=eval(name)
    temp.captureEvents(Event.MOUSEDOWN | Event.MOUSEUP)
    temp.onmousedown=gons
    temp.onmousemove=dragns
    temp.onmouseup=stopns
    function gons(e){
    temp.captureEvents(Event.MOUSEMOVE)
    nsx=e.x
    nsy=e.y
    function dragns(e){
    if (dragswitch==1){
    temp.moveBy(e.x-nsx,e.y-nsy)
    return false
    function stopns(){
    temp.releaseEvents(Event.MOUSEMOVE)
    //drag drop function for IE 4+////
    var dragapproved=false
    function drag_dropie(){
    if (dragapproved==true){
    document.all.showimage.style.pixelLeft=tempx+event.clientX-iex
    document.all.showimage.style.pixelTop=tempy+event.clientY-iey
    return false
    function initializedragie(){
    iex=event.clientX
    iey=event.clientY
    tempx=showimage.style.pixelLeft
    tempy=showimage.style.pixelTop
    dragapproved=true
    document.onmousemove=drag_dropie
    if (document.all){
    document.onmouseup=new Function("dragapproved=false")
    function hidebox(){
    if (document.all)
    showimage.style.visibility="hidden"
    else if (document.layers)
    document.showimage.visibility="hide"
            <body>
    		<div id="content2">
    		<div id="leeg"></div>
    		<div id="tekstgedeelte">
    include("includes/systemen/outgame/inc.login.php");
    ob_start();
    if(file_exists("outgame/" . @$_GET['p'] . ".php") && @$_GET['p'] != 'login') {
      include "outgame/" . @$_GET['p'] . ".php";
      include "outgame/login.php";
    		<div id="leeg2"></div>
    <div id="button">
    if($_GET['p'] == register){
    echo'<a href="index.php"><div id="button2">Inloggen</div></a>';
    echo'<a href="index.php?p=register"><div id="button2">Aanmelden</div></a>';
    if($_GET['p'] == reset){
    echo'<a href="index.php"><div id="button3">Inloggen</div></a>';
    echo'<a href="index.php?p=reset" ><div id="button3">Wachtwoord</div></a>';
            </body>
    edit: was mijn site link nog vergeten. bij deze:
    http://lhmedia.nl/layouts/official/
    • 19 augustus 2009 om 16:38
    Een div-element kan niet in een a-element staan. Een div-element is namelijk een block element, en een a element is een inline element: Block elementen kunnen niet in inline elementen staan, alleen andersom.
    • 19 augustus 2009 om 16:39
            <head>
    var dragswitch=0
    var nsx
    var nsy
    var nstemp
    temp=eval(name)
    function gons(e){
    nsx=e.x
    nsy=e.y
    function dragns(e){
    if (dragswitch==1){
    return false
    function stopns(){
    return false
    iex=event.clientX
    iey=event.clientY
    dragapproved=true
    if (document.all){
    function hidebox(){
    if (document.all)
            <body>
            <div id="content2">
    ob_start();
    <div id="button">
    echo'<div id="button2"><a href="index.php">Inloggen</a></div>';
    echo'<div id="button2"><a href="index.php?p=register">Aanmelden</a></div>';
    echo'<div id="button3"><a href="index.php">Inloggen</a></div>';
    echo'<div id="button3"><a href="index.php?p=reset">Wachtwoord</a></div>';
            </body>
    Nieuwe reactie samengevoegd met originele reactie op 19.08.09 16:43:17:
    Citaat van Killingdevil
    Je was me net voor, maar heb het aangepast :D
  • lhmedia
    • 19 augustus 2009 om 16:46
    mijn dank is groot:d
    • 19 augustus 2009 om 16:55
    Jammer dat iemand het dan weer voorkauwt... Zo leren we nooit iets natuurlijk.
  • lhmedia
    • 19 augustus 2009 om 16:57
    klopt maar daarboven is het uitgelegt dus nu weet ik het.
