POST werkt niet
  • bramieboy100
  • 11 januari 2013 om 17:09
  • bramieboy100
    Op mijn server werkt POST niet meer. Neem dit script bijvoorbeeld:
    <div id="page_container" style="text-align: center;">                        <h1>Withdraw & Deposit</h1>
                            <h2>Withdraw</h2>
                            <?php echo "Credits: " . $_POST['creditsw']; ?>
                            <form id="mini_form" action="http://spacedowngame.com/members/?page=bank" method="post">
                                <?php if(htmlentities($_GET['s']) == "1") { echo '<div class="succesbox"><strong>Succes!</strong> You have now <strong>' . $_SESSION['cww'] . '</strong> credits and <strong>' . $_SESSION['bw'] . '</strong> on your bank.</div>'; } ?>
                                <?php if(htmlentities($_GET['n']) == "0") { echo '<div class="errorbox"><strong>Error!</strong> The field credits may only contain numbers.</div>'; } ?>
                                <?php if(htmlentities($_GET['b']) == "0") { echo '<div class="errorbox"><strong>Error!</strong> You dont have enough money on your bank to withdraw.</div>'; } ?>
                                <label for="">Credits:</label> <input type="text" name="creditsw">
                                <input type="submit" value="Withdraw">
                            </form><br><br><br><br><br>
                            <h2>Deposit</h2>
                            <form id="mini_form" action="http://spacedowngame.com/members/?page=deposit" style="margin-bottom: 75px;" method="post">
                                <?php if(htmlentities($_GET['sd']) == "1") { echo '<div class="succesbox"><strong>Succes!</strong> You have now <strong>' . $_SESSION['cdd'] . '</strong> credits and <strong>' . $_SESSION['bd'] . '</strong> on your bank.</div>'; } ?>
                                <?php if(htmlentities($_GET['nd']) == "0") { echo '<div class="errorbox"><strong>Error!</strong> The field credits may only contain numbers.</div>'; } ?>
                                <?php if(htmlentities($_GET['bd']) == "0") { echo '<div class="errorbox"><strong>Error!</strong> You dont have enough money to deposit.</div>'; } ?>
                                <label for="">Credits:</label> <input type="text" name="creditsd">
                                <input type="submit" value="Deposit">
    Het staat wel in html tags enzo maar dit is een klein stukje. Eerst deed dit het wel en en stond er Credits: 10 bijv. Maar sinds ik een map heb aangemaakt (lijkt me erg sterk dat dit de oorzaak is) werkt het niet meer en staat er alleen nog maar Credits: . Weet iemand waardoor dit komt.
    LOL
    • 11 januari 2013 om 22:25
    Probeer even error reporting aan te zetten. Dat helpt vaak een heleboel!
    Even een aantal opmerkingen die off topic zijn, maar toch wel handig zijn:
    - Zet alles in de css. Je doet id="page_container" in je div en dan ga je nog extra style ernaast schrijven.
    - Gebruik single quotes voor je echo
    - Het is niet nodig om zo vaak php te openen en te sluiten. In de forms kan je er gewoon één php open één php sluiten van maken.
  • bramieboy100
    • 11 januari 2013 om 22:48
    Het probleem is inmiddels al opgelost door even een backup te restoren. Over die css, soms heeft het een andere stijl nodig. Ik bespaar veel ruimte op de schijf als ik het zo doe. Alsnog bedankt voor je hulp en de errors stonden aan. Er was niks fout aan de code maar aan de configuratie.
    LOL
