Upload script probleem.
  • gamesongz
  • 30 december 2012 om 02:52
  • gamesongz
    Geert-Upload Developer
    Dus, ik wil eigenlijk dit...
    Dat ie de filename, Auto renamed naar song**.mp3
    Die ''**'' Moeten in cijfers veranderen.
    Dus bevoorbeeld,
    ik upload hoi.mp3 op.
    Die wordt gerenamed naar song1.mp3
    Iemand anders load qskdklq.mp3 op.
    Dan wordt die gerenamed naar song2.mp3
    Ik zou het waarderen, als iemand mij hierbij zou helpen.
    // Simple PHP Upload Script:  http://coursesweb.net/php-mysql/
    $uploadpath = '';      // directory to store the uploaded files
    $max_size = 200000000;          // maximum file size, in KiloBytes
    $alwidth = 90000;            // maximum allowed width, in pixels
    $alheight = 80000;           // maximum allowed height, in pixels
    $allowtype = array('mp3');        // allowed extensions
    if(isset($_FILES['fileup']) && strlen($_FILES['fileup']['name']) > 1) {
      $uploadpath = $uploadpath . basename( $_FILES['fileup']['name']);       // gets the file name
      $sepext = explode('.', strtolower($_FILES['fileup']['name']));
      $type = end($sepext);       // gets extension
      list($width, $height) = getimagesize($_FILES['fileup']['tmp_name']);     // gets image width and height
      $err = '';         // to store the errors
      // Checks if the file has allowed type, size, width and height (for images)
      if(!in_array($type, $allowtype)) $err .= 'Upload Failed, Invalid Extension';
      if($_FILES['fileup']['size'] > $max_size*1000) $err .= '<br/>Maximum file size must be: '. $max_size. ' KB.';
      if(isset($width) && isset($height) && ($width >= $alwidth || $height >= $alheight)) $err .= '<br/>The maximum Width x Height must be: '. $alwidth. ' x '. $alheight;
      // If no errors, upload the image, else, output the errors
      if($err == '') {
        if(move_uploaded_file($_FILES['fileup']['tmp_name'], $uploadpath)) {
          echo 'Song successfully uploaded';
          echo '<br />Link To Song <input type="text" class="optionstxt" readonly style="width:300px;" value="http://'.$_SERVER['HTTP_HOST'].rtrim(dirname($_SERVER['REQUEST_URI']), '\\/').'/'.$uploadpath.'">';
        else echo '<b>Unable to upload the file.</b>';
      else echo $err;
    • 30 december 2012 om 10:49
    Als aller eerste, wat overzicht in je programming zou geen probleem zijn voor het het debuggen ervan aangezien dat nu best irritant is om te doen, daarnaast als je een rename wilt uitvoeren in je upload script, waarom doe je dat dan niet? Aangezien ik zelf die niet terug kan vinden.
    Voor de rest is het script goed te doen hier en daar een wel wat omslachtige manier om er voor te zorgen dat hij iets controleert, maar er zijn altijd makkelijkere manieren zelfs voor iemand die al 10 jaar programmeert.
    Kijk eens naar deze (Dit script is niet getest):
    http://pastebin.com/JsZGHsL1
    Hiermee kan je is nagaan wat je miste, let voornamelijk op de error afhandeling en de renaming van je files naar song*.mp3 aangezien je die er niet in had zitten ga ik er vanuit dat je daar tegen aanliep om het werkend te krijgen, voel vrij om meer informatie er over te vragen als je iets niet snapt. :)
  • gamesongz
    • 30 december 2012 om 20:15
    Bedankt, dit is wat ik er van heb kunnen maken.
    [PHP]
    $newfilename = 'song' . ($fileCount + 50) . '.mp3'; //New File Name
    if($err == '') {
    if(move_uploaded_file($_FILES["fileup"]["tmp_name"], "" . $newfilename)) {
    echo '<br />Link To Song <input type="text" class="optionstxt" readonly style="width:300px;" value="http://'.%24_server['HTTP_HOST'].rtrim(dirname($_SERVER['REQUEST_URI']), '\\/').'/'.$uploadpath.'">';
    else echo $err;
    ?> [/code]
    Het probleem? Hij renamed naar Song**.mp3
    Het probleem is, dat ie steeds dezelfde cijfer pakt.
    Dus niet van 1 naar 2 etc gaat.
  • bramieboy100
    • 30 december 2012 om 20:40
    Dan doe je toch file_exits("song" . $number . ".mp3"){
    $number ++;
    LOL
  • gamesongz
    • 30 december 2012 om 20:51
    & $number = ?
    • 30 december 2012 om 20:57
    Je roept bij het maken van een bestand $filecount aan. Alleen bestaat $filecount niet.
  • gamesongz
    • 30 december 2012 om 21:00
    & $filecount moet zijn :X?
  • bramieboy100
    • 30 december 2012 om 21:18
    $number is op het begin 1. Als dus song1 al bestaat doet hij er een bij op. zo moet je eigenlijk een while maken en problem solved.
    LOL
  • gamesongz
    ik heb er ondertussen dit van gemaakt.
    Bedankt voor alle hulp!
    Alleen vroeg ik mij af, als het mogelijk is. een Lijst te hebben met alle .mp3 files.
    [PHP]<?php
    $fileCount = (int) count(glob($uploadpath . "*.mp3"));
    $newfilename = 'song' . ($fileCount + 1) . '.mp3'; //New File Name
    if($err == '') {
    echo '<br />Link To Song <input type="text" class="optionstxt" readonly style="width:300px;" value="http://'.%24_server['HTTP_HOST'].rtrim(dirname($_SERVER['REQUEST_URI']), '\\/').'/'.$newfilename.'">';
    else echo $err;
    ?> [/PHP]
