  4. Javascript + Ajax
    frio 12 november 2026 om 19:48
ID Meegeven
  • J.Rijdes
  • 23 november 2012 om 16:31
  • J.Rijdes
    Hoi hoi,
    Ik wil het volgende:
    Als ik op mijn link klik dat er een dialog opent (gebeurd ook) en dan de tekst komt te zien van de meegeven ID.
    Enkel is de link via Java. Dus ik zou niet weten hoe ik dit moet oplossen.
    De link:
    <a class="open-note-dialog" href="javascript:void(<?php echo $file['id']; ?>);">
    Hoe ik het probeerde op te halen:
    				$query_notes = mysql_query("SELECT * FROM notes WHERE id = '".$_GET['javascript:void']."'");
    				$file = mysql_fetch_array($query_notes);
    Volledig script:
    <div class="details grid_12">
    					<h2>Notes</h2>
    					<a href="javascript:void(0);">New note<span class="icon icon-plus"></span></a>
    					<section>
    					$query_count = mysql_query("SELECT * FROM notes WHERE contactid = '".$list['id']."' AND userid = '".$user_info['id']."'");
    					if(mysql_num_rows($query_count) == 0) {
    						echo "<p><i>You dont have any notes for this contact.</i></p>";
    						<ul class="logs">
    					$query_notes = mysql_query("SELECT * FROM notes WHERE contactid = '".$list['id']."' AND userid = '".$user_info['id']."'");
    					while($file = mysql_fetch_array($query_notes))
    							<li>
    									<strong><?php echo $file['title']; ?></strong>
    									<small><?php echo $file['date']; ?></small>
    								</a>
    							</li>
    						</ul>
    					</section>
    				</div><!-- End of .details -->
    				<div class="clearfix"></div>
    				<div class="divider"></div>
    				<div class="grid_12">
    					<a href="javascript:void(0);" class="button red right">Delete Account</a>
    				<!-- Example note Dialog -->
    				<div style="display: none;" id="note-dialog" title="<?php echo $file['title']; ?>">
    						<div class="row">
    								<strong>Date: <?php echo $file['date']; ?></strong><br><br>
    								<small><?php echo $file['note']; ?></small>
    					<div class="actions">
    						<div class="right">
    							<button class="red submit" onClick="window.location='?p=remove_note&id=<?php echo $file['id']; ?>'">Remove</button>
    				</div><!-- End of #note-dialog -->
    			<script>
    				$$.ready(function() {
    				// Note Dialog
    				$( "#note-dialog" ).dialog({
    					autoOpen: false,
    					modal: true,
    					width: 400,
    					open: function(){ $(this).parent().css('overflow', 'visible'); $$.utils.forms.resize() }
    				}).find('button.submit').click(function(){
    					var $el = $(this).parents('.ui-dialog-content');
    					if ($el.validate().form()) {
    						$el.dialog('close');
    				}).end().find('button.cancel').click(function(){
    					$el.find('form')[0].reset();
    					$el.dialog('close');;
    				$( ".open-note-dialog" ).click(function() {
    					$( "#note-dialog" ).dialog( "open" );
    					return false;
  • bramieboy100
    • 23 november 2012 om 16:42
    Stuur via javascript naar website.com/?id=pagina. Dan kun je het toch makkelijk ophalen.
    LOL
  • J.Rijdes
    • 23 november 2012 om 16:45
    Bram, dat is dus me vraag.
    Hoe?
  • bramieboy100
    • 23 november 2012 om 16:53
    In je dialog php zetten. <?php $id = $_GET['id']; ?>
    LOL
  • J.Rijdes
    • 23 november 2012 om 17:00
    Hoe geef ik hem mee in de link..
  • bramieboy100
    • 23 november 2012 om 17:13
    Sorry hoor maar als je de link is website.com/index.php?id=hierid dan is $id = $_GET['id']: hierid.
    LOL
  • J.Rijdes
    • 23 november 2012 om 17:16
    Sorry hoor, maar kijk even in het topic.
    Ik heb dit als link:
    <a class="open-note-dialog" href="javascript:void(0);">
    Dus hoe geef ik hier een Id aan mee?
    Bij een href weet ik het ook wel..
  • bramieboy100
    • 23 november 2012 om 17:22
    O sorry mijn fout. Je kunt het proberen om een session mee te geven of een variabel in javascript.
    LOL
