Footer schuift weg
  • R.H user removed
  • 21 juni 2012 om 20:52
  • R.H user removed
    #TeamStitch
    Op de layout ( die Ferhat vrijgaf )
    Op mijn site laat die niet volledig de footer zien
    En schuift hij ook een deel opzij
    kijk hier:
    http://time2kill.eu/index2.php
    (Let niet op de fouten die in content worden weergegeven)
    Hoe valt dit te fixen?
    Pagina:
    session_start();
    include "config.php";
    $rangen = array("Zwerver","Nietsnut","Kruimeldief","Winkeldief","Loopjongen","Crimi","Gangster","Mobster","Master","Criminal Genius","Professional","Godfather","Ruler","Assassin","Kingpin","Untouchable","Legend","Legend Of T2K","Ultimate +100","Master Of T2K");
    $ervaring = array("10","50","100","200","350","500","750","1000","1500","2400","4800","7500","12000","25000","50000","100000","200000","350000","500000");
    function checkrangup($login)
      global $ervaring, $rangen;
      $dd = mysql_query("SELECT * FROM `crimz_leden` WHERE `login`='".$login."'");
      $user = mysql_fetch_object($dd);
      if($user->rang < 19)
        if($user->ervaring >= $ervaring[$user->rang])
          mysql_query("UPDATE `crimz_leden` SET `rang`=`rang`+1 WHERE `login`='".$login."'");
          mysql_query("insert into crimz_berichten (onderwerp,van,naar,datum,bericht) values ('Promotie', 'Time2Kill', '".$login."', NOW(), 'Gefeliciteerd,<br /><br />U bent gepromoveerd naar de volgende rang. Op naar de volgende rang!<br /><br />mvg,<br />Het Time2Kill-team')") or die(mysql_error());
    function getrang($login)
      global $rangen;
      $dd = mysql_query("SELECT `rang`FROM `crimz_leden` WHERE `login`='".$login."'");
      return $rangen[$user->rang];
    function clean($str) //check de ingevoerde POSTS
     if (is_numeric($str)) $str=floor($str);
     $cleaned=strip_tags($str);
     $cleaned=htmlspecialchars($cleaned);
     $cleaned=mysql_real_escape_string($cleaned);
     $to_clean=array("%20", "\"", "'", "\\", "=", ";", ":");
     $cleaned=str_replace($to_clean, "", $cleaned);
     return $cleaned;
    function check_login()
     if(isset($_SESSION['login']))
      $dbres = mysql_query("SELECT * FROM `crimz_leden` WHERE `login`='".$_SESSION['login']."'");
      $dat = mysql_fetch_object($dbres);
      if($dat->status == 0)
        return false;
      }else{ checkrangup($dat->login); return true; }
     {return false;}
    function antiflood()
        $maxaant = 15; // Maximale aantal bezoeken in 1 minuut
        $time = 60; //tijd in seconden
        $error = 'Je mag maar 15 paginas per minuut bekijken. Dit is o.a. ingesteld om de servers zo min mogelijk te belasten.'; // text bij te veel bezoeken.
        $melding = TRUE; //TRUE als je wilt weergeven hoevaak de pagina al is bezocht, anders FALSE
        if(isset($_SESSION['flood']))
            if((time()-$_SESSION['flood']['TijD']) >= $time)
                unset($_SESSION['flood']);
                $_SESSION['flood']['TijD']=time();
                $_SESSION['flood']['Views']=1;
                $_SESSION['flood']['Views']++;
                if($_SESSION['flood']['Views']>=$maxaant)
                    exit($error);
            if(isset($_SESSION['flood']['Views']))
                $aantnog = $maxaant - $_SESSION['flood']['Views'];
                if($melding == TRUE)
                    echo 'je mag deze pagina nog '.$aantnog.' keer bezoeken binnen '.$time.' seconden.<br>';
                echo 'je mag deze pagina nog '.--$maxaant.' keer bezoeken binnen '.$time.' seconden.';
    //antiflood();
    //LOAD
    function loading($seconde,$plink)
    echo "<table style='width:580px; background:#FFFFFF; border:#D4D4D4 solid 2px; text-align:center;'><tr><td><img src='images/loading11.gif' alt=''><br /><strong>Laden...</strong></td></tr></table>";
    echo "<meta http-equiv='refresh' content='".$seconde.";URL=index.php?p=".$plink."'>";
    return;
    function fout($melding)
    echo "<table class=error><tr><td width=25 align=center><img src=/images/cancel.png></td><td>".$melding."</td></tr></table>";
    return;
    function goed($melding)
    echo "<table class=goed><tr><td width=25 align=center><img src=/images/accept.png></td><td>".$melding."</td></tr></table>";
    return;
    function missie($melding)
    echo "<table class=missie>
    <td width=25 align=center><img src=/images/ticket.png></td><td>Missie <b>".$melding."</b> voltooid!</td>
    return;
    function info($melding)
    echo "<table class=info><tr><td width=25 align=center><img src=/images/exclamation.png></td><td>".$melding."</td></tr></table>";
    return;
    function infonoicon($melding)
    echo "<table class=info><tr><td>".$melding."</td></tr></table>";
    return;
    function item($s1,$s2,$s3,$s4,$s5)
    echo "<span id=".$s1."><table width=160>
    <tr class=lijst><td colspan=3><b>".$s2."</b></td></tr>
    <tr class=lijst><td><strong>Classe:</strong></td><td width=16><img src=images/shield.png></td><td>".$s3."</td></tr>
    <tr class=lijst><td><strong>Power:</strong></td><td width=16><img src=images/lightning.png></td><td><small>+</small>".$s4."</td></tr>
    <tr class=lijst><td><strong>Level:</strong></td><td width=16><img src=images/exp.png><td><small>+</small>".$s5."</td></tr>
    </table>";
    echo "</span>";
    function luck($gelukt,$expaf,$expbij,$hpaf,$hpbij,$auto,$item,$gevangenis,$geldbij,$autoschade,$autoweg)
    	echo "<table class=lijst width=100%>";
    	if ($gelukt == 1) {
    	echo "<tr><td width=16><img src=images/smiley-lol.png alt= /></td><td align=left><b>Het is gelukt!</td></tr>";
    	elseif ($gelukt == 0) {
    	echo "<tr><td width=16><img src=images/smiley-sad.png alt= /></td><td align=left><b>Het is mislukt!</td></tr>";
    	if ($expaf > 0) {
    	echo "<tr><td><img src=images/exp.png alt= /></td><td align=left><font color=red>".$expaf."</font> Ervaring verloren</td></tr>";
    	if ($expbij > 0) {
    	echo "<tr><td><img src=images/exp.png alt= /></td><td align=left><font color=green>".$expbij."</font> Ervaring gekregen</td></tr>";
    	if ($hpaf > 0) {
    	echo "<tr><td><img src=images/heart.png alt= /></td><td align=left><font color=red>".$hpaf."</font> HP verloren</td></tr>";
    	if ($hpbij > 0) {
    	echo "<tr><td><img src=images/heart.png alt= /></td><td align=left><font color=green>".$hpbij."</font> HP gekregen</td></tr>";
    	if ($geldbij > 0) {
    	echo "<tr><td><img src=images/money.png alt= /></td><td align=left><font color=green>&euro; ".$geldbij.",-</font> gekregen</td></tr>";
    	if ($auto != "none") {
    	echo "<tr><td><img src=images/car--plus.png alt= /></td><td align=left><b>".$auto."</b> staat nu in je garage</td></tr>";
    	if ($item != "none") {
    	echo "<tr><td><img src=images/wooden-box--plus.png alt= /></td><td align=left><b>".$item."</b> is toegevoegd aan je bezit</td></tr>";
    	if ($gevangenis != "none") {
    	echo "<tr><td><img src=images/building.png alt= /></td><td align=left>De politie heeft je opgepakt</td></tr>";
    	if ($autoschade == 1) {
    	echo "<tr><td><img src=images/car--exclamation.png alt= /></td><td align=left>Je auto heeft schade opgelopen</td></tr>";
    	if ($autoweg == 1) {
    	echo "<tr><td><img src=images/car-delete.png alt= /></td><td align=left>Je auto is in beslag genomen</td></tr>";
    	echo "</table>";
    return;
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    <title>Time2Kill <? if ($data) { echo "| Ingelogd als ".$data->login.""; } ?></title>
    <script type="text/javascript" src="lib/jquery.js"></script>
    <script type='text/javascript' src='lib/jquery.bgiframe.min.js'></script>
    <script type='text/javascript' src='lib/jquery.ajaxQueue.js'></script>
    <script type='text/javascript' src='lib/thickbox-compressed.js'></script>
    <script type='text/javascript' src='jquery.autocomplete.js'></script>
    <script type='text/javascript' src='localdata.js'></script>
    <script src="SpryAssets/SpryValidationSelect.js" type="text/javascript"></script>
    $().ready(function() {
    	function log(event, data, formatted) {
    		$("<li>").html( !data ? "No match!" : "Selected: " + formatted).appendTo("#result");
    	function formatItem(row) {
    		return row[0] + " (<strong>id: " + row[1] + "</strong>)";
    	function formatResult(row) {
    		return row[0].replace(/(<.+?>)/gi, '');
    	$("#tags").autocomplete([
    							 $query = mysql_query("SELECT * FROM `crimz_leden` ORDER BY `login` ASC") or die (mysql_error());
    while($s = mysql_fetch_object($query))
    	echo '"';
    echo "$s->login";
    echo '",';
    		width: 320,
    		highlight: false,
    		multiple: false,
    		multipleSeparator: " ",
    		scroll: true,
    		scrollHeight: 300
    	$("#clear").click(function() {
    		$(":input").unautocomplete();
    function changeOptions(){
    	var max = parseInt(window.prompt('Please type number of items to display:', jQuery.Autocompleter.defaults.max));
    	if (max > 0) {
    		$("#suggest1").setOptions({
    			max: max
    function changeScrollHeight() {
        var h = parseInt(window.prompt('Please type new scroll height (number in pixels):', jQuery.Autocompleter.defaults.scrollHeight));
        if(h > 0) {
    			scrollHeight: h
    function changeToMonths(){
    	$("#suggest1")
    		// clear existing data
    		.val("")
    		// change the local data to months
    		.setOptions({data: months})
    		// get the label tag
    		.prev()
    		// update the label tag
    		.text("Month (local):");
    <script type="text/javascript" src="ajaxtabs.js">
    * Ajax Tabs Content script v2.2- � Dynamic Drive DHTML code library (www.dynamicdrive.com)
    * This notice MUST stay intact for legal use
    * Visit Dynamic Drive at http://www.dynamicdrive.com/ for full source code
            <script type="text/javascript" src="js/jquery.js"></script> <!-- jQuery -->
            <script type="text/javascript"> <!-- Design Fixes + Update Header + Update naam -->
    			// Design Fixes //
    		$(document).ready(function() {
    			var pixelDiffrence_white_content = 24; // Difference Between White top & White middle
    			var LowerbottemPixels	= 55;		   // How much Black glow needs to stick out
    			var graffitiHeight		= 145;		   // How much for Graffiti
    			var content_white_height = $("div#content_white").height();
    			var menu_height = $("div#menu_wrapper").height();
    			$("div#content_whitebottom").css("margin-top",content_white_height-pixelDiffrence_white_content);
    			$("div#content").css("height",content_white_height+LowerbottemPixels+auto);
    			$("div#content_graffiti").css("margin-top",content_white_height-graffitiHeight);
    		// Update Header + Content avatar //
    		$(document).ready(function(){
    				// Getting info
    			var info_bar_life = 50; 	// 50  Procent! LIFE
    			var info_bar_rank = 50;  	// 50  Procent! RANK
    				// Numbers between 0 - 100
    			switch(true)
    				case info_bar_life > 100 : info_bar_life = 100;
    							 break;
    				case info_bar_life < 0   : info_bar_life = 0;
    							 break
    			switch(true)
    				case info_bar_rank > 100 : info_bar_rank = 100;
    							 break;
    				case info_bar_rank < 0   : info_bar_rank = 0;
    							 break
    				// Updating % & Width
    			$("div#status_info_bar_leven").css("width",info_bar_life+"%");
    			$("div#status_info_bar_rank").css("width",info_bar_rank+"%");
            <script type="text/javascript" src="js/cufon-yui.js"></script> <!-- CUFON-->
    		<script type="text/javascript" src="js/Komika_Tittle_400.font.js"></script>  <!-- Komika Tittle! -->
            <script type="text/javascript" src="js/Komika_axis_400.font.js"></script>  <!-- Komika axis! -->
            <script type="text/javascript"> <!-- Replace Header 1 -->
    			Cufon.replace('h1', { fontFamily: 'Komika_Tittle' });
    			Cufon.replace('h2', { fontFamily: 'Komika_axis' });
    <link rel="stylesheet" type="text/css" href="jquery.autocomplete.css" />
    <link rel="stylesheet" type="text/css" href="lib/thickbox.css" />
        <!-- Style Cheets -->
        	<link type="text/css" rel="stylesheet" href="css/style.css" />
            <!--[if IE]>
            	<link type="text/css" rel="stylesheet" href="css/styleIE.css" />
            <![endif]-->
            <!--[if IE 6]>
                <link type="text/css" rel="stylesheet" href="css/styleIE6.css" />
            <![endif]-->
    	<!-- Javascript Files -->
        	<!--[if lt IE 9]>
                <script src="//html5shim.googlecode.com/svn/trunk/html5.js"></script>
            <![endif]-->
    <meta name="google-site-verification" content="pdXBv-QFiEuK_2yYBcucjGqUGRjuvUKUosaF2WMleGQ" />
    <? if ($data->body_tekst == "") { $tekst = 12; } else { $tekst = $data->body_tekst; } ?>
    <? if ($data->body_color_table == "") { $body_color_table = "dcdacd"; } else { $body_color_table = $data->body_color_table; } ?>
    <style type="text/css">
    body {
    	font-size: <? echo $tekst; ?>px;
    table.lijst td {
    	background-color: #<? echo $body_color_table; ?>;
    table.lijstleft td {
    	text-align:left;
    TR.lijst {
    </style>
    <!-- Begin plaats voor JS -->
    $ip1 = mysql_query("SELECT * FROM crimz_berichten WHERE `naar`='$data->login' AND `gelezen`='0'") or die($error[1]);
    $ip2 = mysql_num_rows($ip1);
    $ip3 = mysql_query("SELECT * FROM crimz_bvot WHERE `ontvanger`='$data->login'") or die($error[1]);
    $ip4 = mysql_num_rows($ip3);
    /*Example message arrays for the two demo scrollers*/
    var pausecontent1=new Array()
    <? if ($ip2 > 0) { ?>
    pausecontent1[0]='&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<a href="?p=mail"><img src="images/email_open.png"  border="0">&nbsp;&nbsp;<b><font color=red>Er zijn nieuwe berichten!</font></b></a>'
    <? } else { ?>
    pausecontent1[0]='&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<a href="?p=mail"><img src="images/email_open.png"  border="0">&nbsp;&nbsp;Er zijn geen nieuwe berichten.</a>'
    <? } if ($ip4 > 0) { ?>
    pausecontent1[1]='&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<a href="?p=item&q=ruilen&c=itemontvangen"><img src="images/lorry_flatbed.png"  border="0">&nbsp;&nbsp;<b><font color=red>Er zijn items naar je gestuurd!</font></b></a>'
    <? } else { ?>
    pausecontent1[1]='&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<a href="?p=item&q=ruilen&c=itemontvangen"><img src="images/lorry_flatbed.png"  border="0">&nbsp;&nbsp;Er zijn geen nieuwe items naar je gestuurd.</a>'
    <? } $gn1            = mysql_query("SELECT *,UNIX_TIMESTAMP(`klikmissie1`) AS `klikmissie1`,0 FROM `crimz_leden` WHERE `login`='$data->login'");
      $gn             = mysql_fetch_object($gn1);
      if($gn->klikmissie1 + 3600 < time()){   ?>
    pausecontent1[2]='&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<a href="?p=adverteer&c=klik"><img src="images/link.png"  border="0">&nbsp;&nbsp;<b><font color=red>Je kan weer een klikmissie doen!</font></b></a>'
    <? } else { ?>
    pausecontent1[2]='&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<a href="?p=adverteer&c=klik"><img src="images/link.png"  border="0">&nbsp;&nbsp;Er is geen klikmissie beschikbaar.</a>'
    var pausecontent2=new Array()
    $query000 = mysql_query("SELECT * FROM `crimz_forum` ORDER BY `datum2` DESC LIMIT 0,10");
    $num =-1;
    while($s000 = mysql_fetch_object($query000))
    $num++;
    pausecontent2[<? echo $num; ?>]='&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<? if ($s000->gesloten == 0) { ?><img src="images/forum_open.png" /><? } else { ?><img src="images/forum_gesloten.png" /><? } ?>&nbsp;&nbsp;<a href="?p=forum"><a href="?p=forum&topic=<? echo $s000->id; ?>"><? echo $s000->titel; ?></a></a>'
    * Pausing up-down scroller- � Dynamic Drive (www.dynamicdrive.com)
    * Visit http://www.dynamicdrive.com/ for this script and 100s more.
    function pausescroller(content, divId, divClass, delay){
    this.content=content //message array content
    this.tickerid=divId //ID of ticker div to display information
    this.delay=delay //Delay between msg change, in miliseconds.
    this.mouseoverBol=0 //Boolean to indicate whether mouse is currently over scroller (and pause it if it is)
    this.hiddendivpointer=1 //index of message array for hidden div
    document.write('<div id="'+divId+'" class="'+divClass+'" style="position: relative; overflow: hidden"><div class="innerDiv" style="position: absolute; width: 100%" id="'+divId+'1">'+content[0]+'</div><div class="innerDiv" style="position: absolute; width: 100%; visibility: hidden" id="'+divId+'2">'+content[1]+'</div></div>')
    var scrollerinstance=this
    if (window.addEventListener) //run onload in DOM2 browsers
    window.addEventListener("load", function(){scrollerinstance.initialize()}, false)
    else if (window.attachEvent) //run onload in IE5.5+
    window.attachEvent("onload", function(){scrollerinstance.initialize()})
    else if (document.getElementById) //if legacy DOM browsers, just start scroller after 0.5 sec
    setTimeout(function(){scrollerinstance.initialize()}, 500)
    // initialize()- Initialize scroller method.
    // -Get div objects, set initial positions, start up down animation
    pausescroller.prototype.initialize=function(){
    this.tickerdiv=document.getElementById(this.tickerid)
    this.visiblediv=document.getElementById(this.tickerid+"1")
    this.hiddendiv=document.getElementById(this.tickerid+"2")
    this.visibledivtop=parseInt(pausescroller.getCSSpadding(this.tickerdiv))
    //set width of inner DIVs to outer DIV's width minus padding (padding assumed to be top padding x 2)
    this.visiblediv.style.width=this.hiddendiv.style.width=this.tickerdiv.offsetWidth-(this.visibledivtop*2)+"px"
    this.getinline(this.visiblediv, this.hiddendiv)
    this.hiddendiv.style.visibility="visible"
    document.getElementById(this.tickerid).onmouseover=function(){scrollerinstance.mouseoverBol=1}
    document.getElementById(this.tickerid).onmouseout=function(){scrollerinstance.mouseoverBol=0}
    if (window.attachEvent) //Clean up loose references in IE
    window.attachEvent("onunload", function(){scrollerinstance.tickerdiv.onmouseover=scrollerinstance.tickerdiv.onmouseout=null})
    setTimeout(function(){scrollerinstance.animateup()}, this.delay)
    // animateup()- Move the two inner divs of the scroller up and in sync
    pausescroller.prototype.animateup=function(){
    if (parseInt(this.hiddendiv.style.top)>(this.visibledivtop+5)){
    this.visiblediv.style.top=parseInt(this.visiblediv.style.top)-5+"px"
    this.hiddendiv.style.top=parseInt(this.hiddendiv.style.top)-5+"px"
    setTimeout(function(){scrollerinstance.animateup()}, 50)
    else{
    this.getinline(this.hiddendiv, this.visiblediv)
    this.swapdivs()
    setTimeout(function(){scrollerinstance.setmessage()}, this.delay)
    // swapdivs()- Swap between which is the visible and which is the hidden div
    pausescroller.prototype.swapdivs=function(){
    var tempcontainer=this.visiblediv
    this.visiblediv=this.hiddendiv
    this.hiddendiv=tempcontainer
    pausescroller.prototype.getinline=function(div1, div2){
    div1.style.top=this.visibledivtop+"px"
    div2.style.top=Math.max(div1.parentNode.offsetHeight, div1.offsetHeight)+"px"
    // setmessage()- Populate the hidden div with the next message before it's visible
    pausescroller.prototype.setmessage=function(){
    if (this.mouseoverBol==1) //if mouse is currently over scoller, do nothing (pause it)
    setTimeout(function(){scrollerinstance.setmessage()}, 100)
    else{
    var i=this.hiddendivpointer
    var ceiling=this.content.length
    this.hiddendivpointer=(i+1>ceiling-1)? 0 : i+1
    this.hiddendiv.innerHTML=this.content[this.hiddendivpointer]
    this.animateup()
    pausescroller.getCSSpadding=function(tickerobj){ //get CSS padding value, if any
    if (tickerobj.currentStyle)
    return tickerobj.currentStyle["paddingTop"]
    else if (window.getComputedStyle) //if DOM2
    return window.getComputedStyle(tickerobj, "").getPropertyValue("padding-top")
    return 0
    var klokID=new Array();
    var klokIN=-1;
    var nu= new Date();
    var uur=nu.getHours();
    var min=nu.getMinutes();
    var sec=nu.getSeconds();
    if (eval(uur) < 10) {uur="0"+uur};
    if (eval(min) < 10) {min="0"+min};
    if (sec < 10) {sec="0"+sec};
    var nu = uur+":"+min+":"+sec;
    function schrijfKlok() {
    klokIN++
    if (document.all || document.getElementById || document.layers) {
    klokID[klokIN]="clock"+klokIN
    document.write("<span id='"+klokID[klokIN]+"' style='position:relative'>"+nu+"</span>")
    function startKlok() {
    nu= new Date()
    uur=nu.getHours()
    min=nu.getMinutes()
    sec=nu.getSeconds()
    if (eval(uur) <10) {uur="0"+uur}
    if (document.all) {
    for (i=0;i<=klokID.length-1;i++) {
    var dezeKlok=eval(klokID[i])
    dezeKlok.innerHTML=nu
    if (document.getElementById) {
    document.getElementById(klokID[i]).innerHTML=nu
    var timer=setTimeout("startKlok()",1000)
    window.onload=startKlok;
    function MM_jumpMenu(targ,selObj,restore){ //v3.0
      eval(targ+".location='"+selObj.options[selObj.selectedIndex].value+"'");
      if (restore) selObj.selectedIndex=0;
    <!-- Einde plaats voor JS -->
    <body>
    	<!--[if IE]>
            <img alt="BackGround" id="BackGround" src="img/css/background.jpg" />
        <![endif]-->
        <!-- Start of Wrapper -->
    	<div id="wrapper">
        	<!-- Header start -->
        	<header>
            	<div id="logo"></div>
                <div id="header_status_wrapper">
                    <div id="header_status">
                        <div id="header_status_graffiti"></div>
                        <div id="header_status_end"></div>
            </header>
            <!-- Header end -->
    		<!-- Content boxes START -->
            <!-- Content top boxes -->
            <div id="contenttop">
            	<div id="content_whitetop">
                	<div class="content_whitetop_txt">
                		<h1><a href="?p=begin">Hoofdkwartier</a></h1>
            <!-- Content middle boxes + content -->
            <div id="content">
    		  	<div id="content_white">
                	<div id="content_white_images"> <!-- White Images -->
                <!-- Content -->
                	<div id="content_wrapper">
    include $_GET['p'] . '.php';
                <!-- End content-->
                <!-- Menu -->
                <div id="menu_wrapper">
                    <div class="menu_header"> <h2> Stats</h2> </div>
                    <div class="menu_uitgeklapt">
                    	<ul>
    $getal_goed = number_format($data->geld, 0, ',', '.');
    $getal_goed2 = number_format($data->kluis, 0, ',', '.');
    $getal_goed3 = number_format($data->credits, 0, ',', '.');
    <table width="157" class="lijstleeg">
    <tr><td align="right" width="20"><img src="images/user.png" alt="" /></td><td align="left"><b>Naam:</b>&nbsp;<? echo $data->login; ?></td></tr>
    <tr><td align="right" width="20"><img src="images/money.png" alt="" /></td><td align="left"><b>Geld:</b>&nbsp;&euro;<? echo $getal_goed; ?>,-</td></tr>
    <tr><td align="right" width="20"><img src="images/kluis.png" alt="" /></td><td align="left"><b>bank:</b>&nbsp;&euro;<? echo $getal_goed2; ?>,-</td></tr>
    <tr><td align="right" width="20"><img src="images/cred.png" alt="" /></td><td align="left"><b><a href="?p=creditskopen">Credits:</b></a>&nbsp;<? echo $getal_goed3; ?></td></tr>
    <tr><td align="right" width="20"><img src="images/vip.png" alt="" /></td><td align="left"><b>Vipdagen:</b>&nbsp;<? echo ($data->VIP > 0)? $data->VIP : "Geen" ; ?></td></tr>
    <tr><td align="right" width="20"><img src="images/chart-up-color.png" alt="" /></td><td align="left"><b>Rang:</b>&nbsp;<? echo getrang($data->login); ?></td></tr>
    <tr><td align="right" width="20"><img src="images/chart-up.png" alt="" /></td><td align="left"><b>Ervaring:</b>&nbsp;<? echo $data->ervaring; ?></td></tr>
    <tr><td align="right" width="20"><img src="images/heart.png" alt="health"></td><td align="left"><p class="bar"><span style="width:<?php echo round($data->hp*100/100, 1);?>px;">&nbsp;&nbsp;<?php echo round($data->hp*100/100, 1);?>&nbsp;%</span></p></td></tr>
    <tr><td align="right" width="20"><img src="images/email.png" alt="" /></td><td align="left"><a href="?p=mail"><b>Berichten</b></a></td></tr>
                        </ul><div class="menu_uitgeklapt_break"></div>
                    <div class="menu_uitgeklapt_end"></div>
                    <br /><br />
                    <div class="menu_header"> <h2> Criminaliteit </h2> </div>
                    	<ul>
                        	<li><a href="?p=misdaad">Misdaad</a></li>
                            <li class="right"><a href="?p=moord">Aanvallen</a></li>
                    	<ul>
                        	<li><a href="?p=autos&c=steelauto">Autos</a></li>
                            <li class="right"><a href="?p=drugs&c=drugsfabriek">Drugs</a></li>
                    	<ul>
                        	<li><a href="?p=work">Werken</a></li>
                            <li class="right"><a href="?p=missies">Missies</a></li>
                    <br /><br />
                    <div class="menu_header"> <h2> Others </h2> </div>
    				<ul>
                            <li class="right"><a href="?p=bank">Bank</a></li>
                        </ul><div class="menu_uitgeklapt_break"></div><ul>
                    <br /><br />
                    <div class="menu_header"> <h2> Communicatie </h2> </div>
                    <br /><br />
                    <div class="menu_header"> <h2> Credits </h2> </div>
    				<ul>
                    <li><a href="?p=creditsshop">Credits Shop</a></li>
                    <li class="right"><a href="?p=creditskopen"><b>Credits Kopen</b></a></li>
    				<? if ($data->mod > 1) { ?>
    				<div class="menu_header"> <h2> Admin </h2> </div>
    				<ul>
                    <li><a href=""></a></li>
                    <li class="right"><a href="?p=admin_panel">Admin panel</a></li>
                <!-- End of menu-->
                <div id="content_whitebottom">
                <div id="content_graffiti"> <!-- Graffiti @ right bottom -->
            <!-- Content End boxes + footer -->
            <div id="contentbotton">
                <footer>
                	<div class="Footer_block">
                        Copyright &copy; 2010-2011 <a href="#">#</a> - Alle rechten voorbehouden <br />
                        Webdesign by  <a href="http://www.vrnet.be" target="_blank">Vrnet.be</a> <br>
                        Coded by	 <a href="http://www.ferhatremory.be" target="_blank">Ferhat Remory </a>
                    <div class="Footer_Div"></div>
                    	<a href="#">Beginpagina</a>  -  <a href="#">Forum</a>  -  <a href="#">Helpdesk</a>  -  <a href="#">Chatbox</a> <br />
    					<a href="#">Spelregels</a>  -  <a href="#">Adverteren</a>
                </footer>
            <!-- Content Boxers STOP -->
        <!-- End of Wrapper -->
        <script type="text/javascript"> Cufon.now(); </script> <!-- Ineternet Explorer Fix! -->
    </body>
    </body>
    </html>
    R.H user removed
    • 21 juni 2012 om 21:04
    Misschien is het omdat er een error is in je php dat je layout niet goed word weergegeven
  • R.H user removed
    #TeamStitch
    • 21 juni 2012 om 21:05
    Dat betwijfel ik want als je inlogt en dan op een pagina gaat ( waar hij geen fout weergeeft is het hetzelfde
    R.H user removed
    • 21 juni 2012 om 21:51
    Op lijn 658 is er een fout in je index ;).
  • ZiraX
    IT Expert
    • 22 juni 2012 om 04:15
    [offtopic]Jij hebt wel erg vaak hulp nodig. Wanneer ga je je eens verdiepen in foutoplossing?
    [/offtopic]
    Ontopic;
    Session Flood checker? 15 pagina's browser sluiten opnieuw inloggen, en je kan weer 15 pagina's kijken .
    1) Eigenaar & CEO // iSenses
  • Malik
    • 22 juni 2012 om 07:57
    Als ik er van uit mag gaan dat er niet naar php moet kijken kan je het volgende doen:
    In css van je footer, position: relative; toevoegen, als dit niet werkt float: left; erbij.
    (zie wel dat het css3 is, dus ben er nog niet zeker van)
