Twitter Widged
  • freaky-flow
  • 10 mei 2011 om 20:22
  • freaky-flow
    Zielegerd
    Beste Criminalspoint leden,
    Ik weet niet hoe ik het moet uitleggen maar.
    De usertime/status is niet goed ingestelt ik weet niet hoe ik het moet fixen.
    Url: http://www.onlinestereo.nl/twit/twit.php
    Download url: http://www.onlinestereo.nl/twit/twit.rar
    Ja ik heb het van internet.
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
    <title>Twitter Api Tool</title>
    <link rel="stylesheet" href="apitool.css" type="text/css" />
    <!--Copy from here-->
    //Settings
    $username = 'M4zzy'; // Twitter username
    $tweetCount = 10; // The amount of tweets that will be visible.
    $cache_file = ''; //Name of the cachefile
    $cache_life = '3600'; //Cachelife in seconds
    //Do not edit below if you don't know what you're doing, you might mess up everything.
    $twitterFeed = 'http://twitter.com/statuses/user_timeline/'.$username.'.json?count='.$tweetCount;
    function timeAgo($timestamp){
    	$timestamp = strtotime($timestamp);
    	$now = time();
    	$timediff = floor($now - $timestamp);
    	switch(true){
    		case ($timediff < 60):
    		return $timediff.' seconds ago.';
    		case($timediff >= 60 && $timediff < 3600):
    		return floor($timediff/60).' minutes ago.';
    		case($timediff >= 3600 && $timediff < 7200):
    		return floor($timediff/3600).' hour ago.';
    		case($timediff >= 7200 && $timediff < 86400):
    		return floor($timediff/3600).' hours ago.';
    		case($timediff >= 86400 && $timediff < 172800):
    		return floor($timediff/86400).' day ago.';
    		case($timediff >= 172800 && $timediff < 602800):
    		return floor($timediff/86400).' days ago.';
    		case($timediff >= 602800 && $timediff < 1209600):
    		return floor($timediff/602800).' week ago.';
    		case($timediff >= 1209600 && $timediff < 31536000):
    		return floor($timediff/602800).' weeks ago.';
    		default:
    		return date('d-m-Y H:i', $timestamp);
    function makeLinksClickable($text){
    	$text = preg_replace("#(^|[\n ])([\w]+?://[\w]+[^ \"\n\r\t< ]*)#", "\\1<a href=\"\\2\" rel=\"external\" target=\"_blank\">\\2</a>", $text);
    	$text = preg_replace("#(^|[\n ])((www|ftp)\.[^ \"\t\n\r< ]*)#", "\\1<a href=\"http://\\2\" rel=\"external\" target=\"_blank\">\\2</a>", $text);
    	$text = preg_replace("/@(\w+)/", "<a href=\"http://www.twitter.com/\\1\" rel=\"external\" target=\"_blank\">@\\1</a>", $text);
    	$text = preg_replace("/#(\w+)/", "<a href=\"http://search.twitter.com/search?q=\\1\" rel=\"external\" target=\"_blank\">#\\1</a>", $text);
    	return $text;
    function cache($path, $time){
    	$cache = filemtime($path);
    	if (!$cache || (time() - $cache >= $time)){
    		return false;
    	}else{
    		return true;
    function getinfo($location){
    	$ch = curl_init();
    	curl_setopt($ch, CURLOPT_URL, $location);
    	curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
    	$output = curl_exec($ch);
    	curl_close($ch);
    	return $output;
    function read($filename){
    	$handle = fopen($filename, "r");
    	$contents = fread($handle, filesize($filename));
    	fclose($handle);
    	return trim($contents);
    if (file_exists($cache_file) && cache($cache_file, $cache_life)){
    	$twitter = read($cache_file);
    }else{
    	$twitter = getinfo($twitterFeed);
        file_put_contents($cache_file, $twitter);
    $tweets = json_decode($twitter);
    <div id="latesttweet">
    <ul>
    foreach ($tweets as $tweet){
    	echo '<li>', makeLinksClickable($tweet->text), '<br /><span><a href="http://twitter.com/' . $username . '/status/', $tweet->id, '/" rel="external" target="_blank">', timeAgo($tweet->created_at), '</a></span></li>';
    echo '<span class="more"><a href="http://twitter.com/', $username, '/" rel="external" target="_blank">More...</a></span>';
    </ul>
    Freaky-Flow.
  • zwpgangster
    • 10 mei 2011 om 20:32
    Hoebedoel je usertime/status is niet goed ingestelt
    MD-IT Solutions
  • freaky-flow
    Zielegerd
    • 10 mei 2011 om 20:39
    Citaat van zwpgangster
    Ja, dit is de link op het tool: http://twitter.com/M4zzy/status/6.80215832262E+16/
    Maar op twitter gewoon dit: http://twitter.com/#!/M4zZy/status/67986134243872768
  • zwpgangster
    • 10 mei 2011 om 20:41
    1ste link bestaat de user niet van!
    MD-IT Solutions
  • freaky-flow
    Zielegerd
    Juist wel. maak niet uit hoe je het in typt twitter verbetert het.
  • zwpgangster
    • 10 mei 2011 om 20:43
    hmzz raar,
    waar wordt dit stukje opgeroepen in het script?
    MD-IT Solutions
  • freaky-flow
    Zielegerd
    • 10 mei 2011 om 20:45
    hmzz raar,
    Volgens mij hier
        $text = preg_replace("#(^|[n ])([w]+?://[w]+[^ \"nrt< ]*)#", "\1<a href=\"\2\" rel=\"external\" target=\"_blank\">\2</a>", $text);
        $text = preg_replace("#(^|[n ])((www|ftp).[^ \"tnr< ]*)#", "\1<a href=\"http://\2\" rel=\"external\" target=\"_blank\">\2</a>", $text);
        $text = preg_replace("/@(w+)/", "<a href=\"http://www.twitter.com/\1\" rel=\"external\" target=\"_blank\">@\1</a>", $text);
        $text = preg_replace("/#(w+)/", "<a href=\"http://search.twitter.com/search?q=\1\" rel=\"external\" target=\"_blank\">#\1</a>", $text);
        return $text;
    of hier:
        echo '<li>', makeLinksClickable($tweet->text), '<span><a href="http://twitter.com/' . $username . '/status/', $tweet->id, '/" rel="external" target="_blank">', timeAgo($tweet->created_at), '</a></span></li>';
  • zwpgangster
    • 10 mei 2011 om 20:46
    dnek het niet, dit is de functie om de links klikbaar te maken
    MD-IT Solutions
  • freaky-flow
    Zielegerd
    • 10 mei 2011 om 20:49
    Time ETC is dit volgens mij dan.
    	$now = time();
    	switch(true){
    		default:
