heey!
Heeft er hier iemand een scriptje voor als je je gebruikersnaam bent vergeten?
Mvg, tree
heey!
Mvg, tree
Dit is niet zo moeilijk te maken. Je kan best dan ook een nieuwe maken (pass) want als je de wachtwoorden codeerd zijn ze niet (makkelijk) op te halen.
Als ik tijd heb maak ik er wel één.
Zeker te lui om te googlen?
$email=$_POST['email'];
$email=mysql_real_escape_string($email);
$status = "OK";
$msg="";
//error_reporting(E_ERROR | E_PARSE | E_CORE_ERROR);
// You can supress the error message by un commenting the above line
if (!stristr($email,"@") OR !stristr($email,".")) {
$msg="Your email address is not correct<BR>";
$status= "NOTOK";}
echo "<br><br>";
if($status=="OK"){ // validation passed now we will check the tables
$query="SELECT email,userid,password FROM plus_signup WHERE plus_signup.email = '$email'";
$st=mysql_query($query);
$recs=mysql_num_rows($st);
$row=mysql_fetch_object($st);
$em=$row->email;// email is stored to a variable
if ($recs == 0) { // No records returned, so no email address in our table
// let us show the error message
echo "<center><font face='Verdana' size='2' color=red><b>No Password</b><br> Sorry Your address is not there in our database . You can signup and login to use our site. <BR><BR><a href='signup.php'> Sign UP </a> </center>";
exit;}
// formating the mail posting
// headers here
$headers4="[email protected]"; // Change this address within quotes to your address
$headers.="Reply-to: $headers4\n";
$headers .= "From: $headers4\n";
$headers .= "Errors-to: $headers4\n";
//$headers = "Content-Type: text/html; charset=iso-8859-1\n".$headers;
// for html mail un-comment the above line
// mail funciton will return true if it is successful
if(mail("$em","Your Request for login details","This is in response to your request for login detailst at site_name \n \nLogin ID: $row->userid \n Password: $row->password \n\n Thank You \n \n siteadmin","$headers")){echo "<center><font face='Verdana' size='2' ><b>THANK YOU</b> <br>Your password is posted to your emil address . Please check your mail after some time. </center>";}
else{// there is a system problem in sending mail
echo " <center><font face='Verdana' size='2' color=red >There is some system problem in sending login details to your address. Please contact site-admin. <br><br><input type='button' value='Retry' onClick='history.go(-1)'></center></font>";}
else {// Validation failed so show the error message
echo "<center><font face='Verdana' size='2' color=red >$msg <br><br><input type='button' value='Retry' onClick='history.go(-1)'></center></font>";}
Zoiets vind ik,DIT is de site waar op ik t vond. Als hij niet werkt op je source moet je m maar ombouwen.
Ik heb die van de nieuwste bulletstar...
Oh, ik zie net dat je gebruikersnaam vergeten zoekt en niet wachtwoord:P, wacht zal even voor je zoeken.
Wat ook handig is , als iemand ze gebruikersnaam kwijd is dat ie dan met zen email adres kan inloggen ![]()
Ik heb is zon gescript gemaakt voor men profielen site.
<div id="center">
<form method="post" action="./?p=algemeen-gbkwijt" name="sendUser">
<table width="100%" cellspacing="0" cellpadding="0">
<td class="titel" colspan="2">Bulletstar - Gebruikersnaam kwijt</td>
<td class="tekst" colspan="2">
<img src="./bulletstar-icons/table_relationship.png" /> <font color="#00FF00"><b>Gebruikersnaam kwijt</b></font>
<br />Je bent je gebruikersnaam vergeten? Of weet niet meer hoe je jezelf hebt geregistreerd?<br />Via deze pagina kun je dat na-checken.
<br /><br />
<font color="red"><em>Misbruik van deze functie word <u>zwaar</u> bestraft!</em></font>
</td>
<td class="titel1" align="left" colspan="2">
Gebruikersnaam opvragen
</td>
if(isset($_POST['sendUser']))
$email = mysql_query("SELECT * FROM `users` WHERE `email`='".$_POST['email']."'");
if(preg_match('/^.+@.+\..+$/',$_POST['email']))
if(mysql_num_rows($email) > 0)
$user = mysql_fetch_object($email);
$sitelink = str_replace("www.","",$_SERVER["SERVER_NAME"]);
$replace = substr($_SERVER["SCRIPT_NAME"],strrpos($_SERVER["SCRIPT_NAME"],"/")+1);
$path = str_replace($replace, "", $_SERVER["SCRIPT_NAME"]);
if($path == ""){ $path = "/";}
$headers = 'MIME-Version: 1.0' . "\r\n";
$headers .= 'Content-type: text/html; charset=iso-8859-1' . "\r\n";
$headers .= "From: {$sitelink} <admin@{$sitelink}>" . "\r\n";
mail($_POST['email']," Bulletstar - Gebruikersnaam","
Er is zojuist een aanvraag binnengekomen om je gebruikersnaam even per e-mail te sturen.<br />
Onder dit email adres staat de volgende gebruiker geregistreerd: ".$user->login."<br /><br />
Deze aanvraag is gedaan door {$_SERVER['REMOTE_ADDR']}<br /><br />
Met vriendelijke groet,<br /><br />
Bulletstar Helpdesk<br />
http://www.{$sitelink}","$headers");
echo" <tr><td class=\"tekst2\" colspan=\"2\"><img src=\"./bulletstar-icons/tick.png\" /> Er is zojuist een e-mail verzonden!</td></tr>";
echo" <tr><td class=\"tekst2\" colspan=\"2\"><img src=\"./bulletstar-icons/error.png\" /> Het ingevoerde e-mail adres is niet ingebruik!</td></tr>";
echo" <tr><td class=\"tekst2\" colspan=\"2\"><img src=\"./bulletstar-icons/error.png\" /> Het ingevoerde e-mail adres is ongeldig!</td></tr>";
<td class="tekst" width="35%">
<img src="./bulletstar-icons/email_link.png" /> <b>E-mail adres:</b>
</td>
<td class="tekst2" width="65%">
<input type="text" name="email" style="width: 195px;">
</td>
<img src="./bulletstar-icons/tick.png" /> <input type="submit" name="sendUser" value="Stuur gebruikersnaam op!" style="width: 170px; cursor: pointer;">
</td>
<td class="titel" colspan="2"> </td>
Deze is van Bulletstar, de config moet erbij omdat bulletstar met ?p=script ofzo werkt..
Hartelijk bedankt, maar ik had hem net gefixed en hij werkt nu ![]()
Slotje:p :slotje:
