Header location werkt niet..
  • Reverb
  • 2 april 2010 om 12:04
  • Reverb
    Lolz0r.
    Ik heb in mijn login script een header location staan, maar als je inlogt gaat hij niet daar heen..
    Hij werkt anders wel met een meta refresh redirect script..
    PHP CODE:
      if(isset($_POST['login'],$_POST['pass'])) {
        $login              = mysql_real_escape_string($_POST['login']);
        $pass               = mysql_real_escape_string($_POST['pass']);
        $dbres				= mysql_query("SELECT `login`,`activated` FROM `[users]` WHERE `login`='{$_POST['login']}' AND `pass`=('{$_POST['pass']}')");
        if(($data = mysql_fetch_object($dbres)) && $data->activated == 1) {
          $validate				= (rand(0,1000));
          setcookie("login",$data->login,time()+60*60*24,"/",".crime-killer.nl/");
          setcookie("validate",$validate,time()+60*60*24,"/",".crime-killer.nl/");
          mysql_query("REPLACE INTO `[online]`(`time`,`login`,`IP`,`validate`) values(NOW(),'{$_SERVER['REMOTE_ADDR']}','{$data->login}','$validate')");
          $_SESSION['login']		= $data->login;
          $_SESSION['IP']			= $_SERVER['REMOTE_ADDR'];
          $dbres				= mysql_query("SELECT *,UNIX_TIMESTAMP(`signup`) AS `signup` FROM `[users]` WHERE `login`='{$_SESSION['login']}'");
          $_SESSION['data']			= mysql_fetch_object($dbres);
     if($_GET['x'] == "logout") {
        mysql_query("DELETE FROM `[online]` WHERE `login`='{$_COOKIE['login']}' AND `validate`='{$_COOKIE['validate']}' AND `IP`='{$_SERVER['REMOTE_ADDR']}'");
        setcookie("login",'',time()-24*60*60,"/",".crime-killer.nl/");
        setcookie("validate",'',time()-24*60*60,"/",".crime-killer.nl/");
        unset($_SESSION['login']);
        unset($_SESSION['IP']);
        unset($_SESSION['data']);
      if(isset($_COOKIE['login'],$_COOKIE['validate'])) {
        setcookie("login",$_COOKIE['login'],time()+24*60*60,"/","");
        setcookie("validate",$_COOKIE['validate'],time()+24*60*60,"/","");
        print "<td width=200>Je bent nu uitgelogd!</td><meta http-equiv=Refresh content=2;url=index.php>
    <meta http-equiv=Refresh content=2;url=index.php> </tr></td> \n";
      else if($_GET['x'] == "lostpass") {
        print "  \n";
        if(isset($_GET['id'],$_GET['code'])) {
          $dbres				= mysql_query("SELECT `login` FROM `[temp]` WHERE `id`='{$_GET['id']}' AND `code`='{$_GET['code']}' AND `area`='lostpass'");
          if($data = mysql_fetch_object($dbres)) {
            $dbres				= mysql_query("SELECT `login`,`email` FROM `[users]` WHERE `login`='{$data->login}'");
            $newpass			= rand(100000,999999);
            mysql_query("UPDATE `[users]` SET `pass`=('$newpass') WHERE `login`='{$data->login}'");
            mysql_query("DELETE FROM `[temp]` WHERE `id`='{$_GET['id']}'");
            mail($data->email,"Ghettostreetz.nl password","Je wachtwoord is gereset, je kan nu inloggen met: $newpass","From: Ghettostreetz.nl <[email protected]>\n");
            print "Je nieuwe wachtwoord is ge-emailed naar {$data->email} als je hem niet in je normale postvak ontvangt kijk dan even in je ongewenste e-mail map dan staat hij daar.\n";
        else if(isset($_POST['email'],$_POST['login'])) {
          $dbres				= mysql_query("SELECT `login`,`email` FROM `[users]` WHERE `login`='{$_POST['login']}' AND `email`='{$_POST['email']}'AND `activated`=1");
            $code				= rand(100000,999999);
            mysql_query("INSERT INTO `[temp]`(`login`,`code`,`area`,`time`) values('{$data->login}',$code,'lostpass',NOW())");
            $id				= mysql_insert_id();
            mail($data->email,"Ghettostreetz.nl password","Er is een aanvraag binnengekomen om je wachtwoord te resetten. Als jij dit niet hebt aangevraagd, negeer deze email dan. Heb jij dit wel gedaan, klik dan op deze link: http://www.ghettostreetz.nl/login.php?x=lostpass&id=$id&code=$code","From: Ghettostreetz.nl <[email protected]>");
            print "  Je nieuwe wachtwoord is ge-emailed naar {$data->email} als je hem niet in je normale postvak ontvangt kijk dan even in je ongewenste e-mail map dan staat hij daar.\n";
            print "<br> Er is geen combinatie gevonden van de <br>gebruikersnaam en het e-mailadres!\n";
        print <<<ENDHTML
     <br><br><tr>
                  <td>
    	<form method="post">
    	<table align=center>
    	<tr><td>Login:</td>	<td><input type="text" name="login"></td></tr>
    	<tr><td>E-Mail:</td> <td><input type="text" name="email"></td></tr>
    	<tr><td></td><td align="right"><input type="submit" value="Ok" style="width: 100"></td></tr>
    	  	</td>
    ENDHTML;
         else if($data) {
        if($data->activated == 0)
          print " <tr><td class=\"mainTxt\">Je account is nog niet geactiveerd!</td></tr>\n";
        if($data->level == 1337)
          print "Jij kan niet inloggen omdat je <b>verbannen</b> bent!<BR>Reden: {$data->redenban}\n";
         mysql_query("INSERT INTO `[zendlogs2]`(`time`,`van`,`naar`,`cdonatie`,`login`,`ip`) values(NOW(),'Geen','Geen','Geen','{$data->login}','{$_SERVER['REMOTE_ADDR']}')");
    mysql_query("UPDATE `[users]` SET `logincheck`=`logincheck`+1 WHERE `login`='{$data->login}'");
    	header("location: nav.php");
      else {
        print "  \n";
          print " Verkeerde login of wachtwoord\n";
        print <<<ENDHTML
    	<table width="75%" align="center">
    	<tr><td width=100>Gebruikersnaam:</td> <td><input type="text" name="login" maxlength=16 style="width: 150;"></td></tr>
    	<tr><td width=100>Wachtwoord:</td> <td><input type="password" name="pass" maxlength=16 style="width: 150;"></td></tr>
    	<tr><td colspan="2"><a href="publiccomp.php">Openbare computer:</a> <input name="open" type="checkbox"></td></tr>
    	<tr><td></td><td align="left"><input type="submit" name="submit" style="width: 100;" value="Login"></td></tr>
      <table width="75%" border="0" align="center" cellpadding="0" cellspacing="0">
    <td colspan='2' style='text-align: center; padding-top: 25px;'>
    <a href='login.php?x=lostpass'>Wachtwoord vergeten?</a>
    </td>
    ENDHTML;
    ENDHTML;
    </body>
    </html>
    Projecten:
    http://lsjdesigns.nl/
    http://allesvooreeneuro.nl/
    • 2 april 2010 om 12:34
    Zet je error reporting hoger en kom er achter dat PHP een Headers Already sent foutmelding geeft...
    zie [func]ob_start[/func]...
  • Reverb
    Lolz0r.
    • 2 april 2010 om 13:05
    Dus wat kan ik dan doen?
    Projecten:
    • 2 april 2010 om 13:31
    Lezen...
    http://www.php.net/manual/en/function.header.php
    http://wiki.phpfreakz.nl/Headers_Already_Sent
  • Reverb
    Lolz0r.
    • 2 april 2010 om 19:59
    gelezen, maar kom niet echt verder?
    Projecten:
  • Mokerr
    Webspetter.nl
    • 2 april 2010 om 20:12
    else{
    Dit misschien?
    • 2 april 2010 om 20:23
    Mokerr
    Nee...
    Edit: Het is niet de oplossing voor zijn probleem, maar het is wel aan te raden ja...
    Reverb
    Het is vandaag geen 1 april meer weet je...
    Voor de slimmeriken die me niet begrijpen: ik geloof heb niet.
  • Reverb
    Lolz0r.
    • 2 april 2010 om 21:00
    Het is al gelukt!
    Bedankt.
    Projecten:
