Verwijderen werkt niet
  • Superior
  • 1 november 2009 om 15:35
  • Superior
    Goedemiddag allemaal,
    Ik ben bezig met een vriendenlijst scriptje, enkel werkt dit niet correct.
    Het toevoegen gaat tot nu toe zoals het moet gaan.
    Enkel het verwijderen wordt niet doorgevoerd en krijg ook geen errors.
    Code:
    if($_GET['prof'] == "friends")
    	//If he/she updates the add form
    	if(isset($_POST['budadd']))
    		//Check the post for SQL injections
    		$name	= checkInput($_POST['budname']);
    		//Check mysql for errors or defaults on the input
    		$mysql1	= mysql_query("SELECT username FROM players WHERE username = '".$name."'");
    		$mysql2	= mysql_query("SELECT username,buddy FROM buddylist WHERE buddy = '".$name."' AND username = '".$data->username."'");
    		//Check if the user exists
    		if(mysql_num_rows($mysql1) < 1)
    			begintable("Friends list - ERROR");
    			echo "There is no such username!";
    			exittable();
    		//Check if the user allready is added on the list
    		if(mysql_num_rows($mysql2) > 1)
    			echo "This user allready is on your friends list!";
    			exittable();
    		else {
    			//If all inputs are correct
    			mysql_query("INSERT INTO buddylist(username,buddy,date) values('".$data->username."','".$name."',NOW())") or die(mysql_error());
    			begintable("Friends list");
    			echo "You have succesfully added ".$name." to your friends list!";
    			exittable();
    	//IF he/she updates the delete form
    	if(isset($_GET['delete']))
    		$id		= checkInput($_GET['delete']);
    		$mysql	= mysql_query("SELECT * FROM buddylist WHERE id = '".$id."' AND username = '".$data->username."'");
    		$buddy	= mysql_fetch_object($mysql);
    		if(mysql_num_rows($mysql) < 1)
    			echo "There is no such username on your friends list!";
    			exittable();
    		else {
    			mysql_query("DELETE FROM buddylist WHERE id = '".$buddy->id."'");
    			echo "This user is no longer a friend of you!";
    			exittable();
    	//Get the data from query table
    	$mysql	= mysql_query("SELECT * FROM buddylist WHERE username = '".$data->username."'");
    	//Check if the user has anny friends
    		$text	= "<b><i>No Friends</i></b>";
    	//While lus
    	while($friend = mysql_fetch_array($mysql))
    		$text	= '<a href="?gc=profile&id='.$friend['buddy'].'">'.$friend['buddy'].'</a>
                	   <a href="?gc=editprofile&delete='.$friend['id'].'"><img src="images/icons/delete.png" border="0" /></a><br>';
    	echo '<form method="post">
    	  	  <table width="100%" class="content" cellpadding="2" cellspacing="6" border="0">
          		  <td width="150">Username:</td>
                  <td><input type="text" name="budname"></td>
                  <td width="150">&nbsp;</td>
                  <td><input type="submit" name="budadd" value="Add Friend"></td>
              </form>';
    	closetable();
    	begintable("Friends now");
    	echo '<table width="100%" class="content" cellpadding="2" cellspacing="6" border="0">
          		  <td>'.$text.'</td>
              </table>';
    	closetable();
    Graag geen onnodige reacties of lompe opmerkingen.
    Verbeter tips zijn natuurlijk wel altijd welkom van jullie.
    Superior
    • 1 november 2009 om 15:40
    Krijg je ook geen melding die je zelf hebt ingesteld? Dus ofwel: Gebruiker is geen vriend van je, ofwel gebruiker is uit je vriendenlijst gehaald?
  • Superior
    • 1 november 2009 om 15:42
    @Killingdevil
    Nee krijg momenteel geen enkele foutmelding of normale melding.
    Word terug gestuurd naar de des betreffende pagina zonder uitvoering van code.
    Edit:
    Kleine aanpassing op code vanwege de while lus die verkeerd stond.
    Helaas is dit ook niet de oplossing tot mijn fout.
    Laat hem toch even zien vanwege de aanpassing op de code.
    			exittable();
    			exittable();
    		else {
    			exittable();
    	if(isset($_GET['del']))
    		$id		= checkInput($_GET['del']);
    			exittable();
    		else {
    			mysql_query("DELETE FROM buddylist WHERE id = '".$id."'") or die(mysql_error());
    			exittable();
              </form>';
    	closetable();
    	echo '<table width="100%" class="content" cellpadding="2" cellspacing="6" border="0">';
    		echo "<tr>
    				<td><b><i>No Friends</i></b></td>
    			  </tr>";
    	//While lus to show all friends
    		echo '<tr>
    				<td><a href="?gc=profile&id='.$friend['buddy'].'">'.$friend['buddy'].'</a>
                	    <a href="?gc=editprofile&del='.$friend['id'].'"><img src="images/icons/delete.png" border="0" /></a><br></td>
              	  </tr>';
    	echo '</table>';
    	closetable();
    • 1 november 2009 om 15:58
    De link: '?gc=editprofile&delete='.$friend['id']
    De voorwaarden die moeten kloppen om bij het delete gedeelte te komen:
    mysql_num_rows($mysql) >= 1 (let op, met deze voorwaarde word de else uitgevoerd)
    Waar is het prof=friends gedeelte in de link?
    Wat zou er (in theorie) gebeuren als ik het volgende in het forum zou neer zetten?
    [img]?gc=editprofile&delete=1&prof=friends[/img]
  • Superior
    • 1 november 2009 om 16:03
    W0utR
    Klopt er zit namelijk ook een gedeelte om spelers toe te voegen aan je lijst.
    Voor zover ik zie word die netjes gesloten toch ?
    Darsstar
    De link klopt ook, hoger in het script staat nog meer wat daarbij hoort.
    Deze is alleen niet relevant tot de code dus hoef ik dit ook niet toe te voegen lijkt mij.
    Wat er zou gebeuren is niks met die code, ik moet nog wel wat aanpassen maar dit komt later.
    Gaat er nu om dat de delete gedeelte niet word uitgevoerd.
    • 1 november 2009 om 16:08
    De link klopt niet...
    ******?gc=editprofile&prof=friends&del=2
    En wat krijg ik te zien nadat ik jou eerst als vriend had toegevoeg:
    Dus verander die link!
    (en ga via POST werken)
  • Superior
    • 1 november 2009 om 16:15
    Het is opgelost..
    Miste nog een stukje link waardoor hij met een return naar begin werd gezet.
    Bedankt voor je hulp Darsstar :slotje:
