Afwerking
  • R.H user removed
  • 23 april 2012 om 21:35
  • R.H user removed
    #TeamStitch
    Ik zit aan de afwerken van de clan pagina
    begintabel("Familie Mail");
      if(! ($data->clanlevel >= 8))
        exit;
      if ($data->clanmail == 0 && $data->clanconsig != 1 && $data->clanlevel != 9)
      	exit;
    <table width=100%>
    <?php /* ------------------------- */{
        if(isset($_POST['message'])) {
          $dbres				= mysql_query("SELECT * FROM `[temp]` WHERE `id`='{$_POST['id']}' AND `code`='{$_POST['code']}' AND `area`='message'");
          if(($check = mysql_fetch_object($dbres)) && $check->IP == $clientIP) {
            $dbres				= mysql_query("SELECT `login` FROM `[users]` WHERE `Mobieltje`=1 AND `clan`='{$data->clan}'");
            while($member = mysql_fetch_object($dbres)) {
              $_POST['subject']		= preg_replace('/</','<',$_POST['subject']);
              $_POST['message']		= preg_replace('/</','<',$_POST['message']);
              mysql_query("INSERT INTO `[messages]`(`time`,`IP`,`from`,`to`,`subject`,`message`) values(NOW(),'{$_SERVER['REMOTE_ADDR']}','[CLAN]{$data->clan}','{$member->login}','{$_POST['subject']}','{$_POST['message']}')");
              mysql_query("DELETE FROM `[temp]` WHERE `id`='{$_POST['id']}' AND `code`='{$_POST['code']}' AND `area`='message'");
          print "  <tr><td class=\"mainTxt\">Familie Bericht verzonden</td></tr>\n";
        $code				= rand(100000,999999);
        mysql_query("INSERT INTO `[temp]`(login,IP,code,area,time) values('{$data->login}','$clientIP','$code','message',NOW())");
        $id					= mysql_insert_id();
        print <<<ENDHTML
      <tr><td class="mainTxt">
    	<form name="form1" method="POST" action="clan-mail.cg"><table>
    	<input type="hidden" name="id" value="$id">
    	<input type="hidden" name="code" value="$code">
    	<tr><td width=100>Van:</td>		<td>[CLAN]{$data->clan}</td></tr>
    	<tr><td width=100>Onderwerp:</td>	<td><input type="text" name="subject" value="{$_REQUEST['subject']}" maxlength=25></td></tr>
    	<tr><td width=100 valign="top">Bericht:</td>
    						<td><textarea name="message" cols=40 rows=10>{$_REQUEST['message']}</textarea></td></tr>
    	<tr><td width=100></td>			<td align="right"><input type="submit" name="submit" value="Verzenden"></td></tr>
      </td></tr>
    ENDHTML;
    eindetabel();
    Zit nu vast met het inbouwen ervan...
    Ik weet dat een paar dingen niet kloppen maar weet niet naar wat ik ze moet wijzigen.
    Ik heb wel al een paar dingen kunnen wijzigen.
    Hier de database gedeelte van de site ( de bovenste in handtekening )
    -- phpMyAdmin SQL Dump
    -- version 3.5.0
    -- http://www.phpmyadmin.net
    -- Machine: localhost
    -- Genereertijd: 23 apr 2012 om 21:35
    -- Serverversie: 5.1.60-log
    -- PHP-Versie: 5.2.17
    SET SQL_MODE="NO_AUTO_VALUE_ON_ZERO";
    SET time_zone = "+00:00";
    /*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
    /*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
    /*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
    /*!40101 SET NAMES utf8 */;
    -- Databank: `stijnqg59_pkmo`
    -- Tabelstructuur voor tabel `clans`
    CREATE TABLE IF NOT EXISTS `clans` (
      `clan_id` int(3) NOT NULL,
      `clan_naam` varchar(255) NOT NULL,
      `clan_owner` varchar(255) NOT NULL,
      `clan_ownerid` int(10) NOT NULL,
      `clan_spelersaantal` varchar(255) NOT NULL,
      `clan_members` varchar(255) NOT NULL,
      `clan_beschrijving` varchar(255) NOT NULL,
      `clan_type` varchar(255) NOT NULL,
      `clan_level` int(2) NOT NULL,
      `clan_gold` bigint(10) NOT NULL,
      `clan_silver` bigint(10) NOT NULL,
      `clan_winkel` bigint(10) NOT NULL,
      PRIMARY KEY (`clan_id`)
    ) ENGINE=MyISAM  DEFAULT CHARSET=latin1;
    -- Gegevens worden uitgevoerd voor tabel `clans`
    INSERT INTO `clans` (`clan_id`, `clan_naam`, `clan_owner`, `clan_ownerid`, `clan_spelersaantal`, `clan_members`, `clan_beschrijving`, `clan_type`, `clan_level`, `clan_gold`, `clan_silver`, `clan_winkel`) VALUES
    (1, 'AreaLegendZz', 'Goldworthy', 10653, '1', '159633', 'Scripters Clan', 'flying', 1, 200, 2750, 0),
    (9, 'Victory', 'Skyress', 10667, '1', '21324', 'De Victory van Victini', 'dragon', 1, 0, 0, 0),
    (3, 'superdarkkyurem', 'dragonm', 10635, '2', '53414', 'iedereen mag zich aan melden', 'dragon', 2, 0, 1000, 0),
    (5, 'AreaCrew', 'Jarik7', 11723, '4', '44879', 'Iedereen is welkom, join!', 'fire', 1, 20, 0, 0),
    (6, 'Pokemon0Legendes', 'jrm1998', 10658, '14', '398782', 'Voor echte area spelers', 'metal', 3, 5, 212207, 0),
    (8, 'water', 'bayar14', 10775, '5', '54497', 'voor de coolste leden', 'water', 2, 115, 7185, 0),
    (7, 'Admins', 'Admin', 10637, '1', '10637', 'Dit is een clan enkel voor de admins!', 'dragon', 1, 0, 0, 0);
    /*!40101 SET CHARACTER_SET_CLIENT=@OLD_CHARACTER_SET_CLIENT */;
    /*!40101 SET CHARACTER_SET_RESULTS=@OLD_CHARACTER_SET_RESULTS */;
    /*!40101 SET COLLATION_CONNECTION=@OLD_COLLATION_CONNECTION */;
    Als u me kunt helpen hoor ik dit graag!
    R.H user removed
  • r-mulder
    Elite Member
    • 23 april 2012 om 21:38
    Wat wil je nu dat we gaan doen?
    Het is mij niet helemaal duidelijk..
  • R.H user removed
    #TeamStitch
    • 24 april 2012 om 07:31
    Om ervoor te zorgen dat die clan mail pagina juist staat voor de db die erbij staat en dus dat hij naar alle leden dat stuurt want er zit een deel van maffia force in waardoor het me moeilijker maakt
    R.H user removed
  • Nick
    • 24 april 2012 om 08:19
    Dat kan je toch makkelijk zelf aanpassen?
  • eeyk
    Crime-ware.nl
    • 24 april 2012 om 09:25
    ik weet niet wat voor spel je aan het maken ben wel weet ik dat wat je ook maak je spel zo niet meer uniek is je plaats al je scripts steeds op CP.
  • iCold
    • 24 april 2012 om 15:30
    Als je tog bezig bent, schrijf hem helemaal opnieuw. Dit script is verouderd. En het is de basis van PHP. Dit hoor je te weten.
