Oplossing 500 fout
  • Starohosting
  • 27 januari 2012 om 19:59
  • Starohosting
    Beste leden,
    Als ik mijn index upload krijg ik eeen interne 500 server fout.
    Wie kan het vinden in mijn code:
    <!DOCTYPE html PUBLIC '-//W3C//DTD XHTML 1.0 Strict//EN' 'http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd'>
    <html xmlns='http://www.w3.org/1999/xhtml' xml:lang='en' lang='en'>
    <head>
    <title><?php page_title(); ?></title>
    <meta http-equiv='Content-Type' content='application/xhtml+xml; charset=<?php if(defined('DEFAULT_CHARSET')) { echo DEFAULT_CHARSET; } else { echo 'utf-8'; }?>' />
    <meta name='description' content='<?php page_description(); ?>' />
    <meta name='keywords' content='<?php page_keywords(); ?>' />
    <script src='js/jquery-1.3.2.min.js' type='text/javascript'></script>
    <script src='js/jquery-ui-personalized-1.5.3.packed.js' type='text/javascript'></script>
    <script type='text/javascript' src='images.php'></script>
    <script type='text/javascript' src='slideshow.js'></script>
    <link href='<?php echo TEMPLATE_DIR; ?>/css/include.css' rel='stylesheet' type='text/css' media='screen, projection, tv' />
    <body>
    <div id='wrapper'>
    <div id='topUserBar'>
    <div class='centerContainer'>
    <ul id='nav'>
    show_menu2(0,SM2_ROOT,SM2_START,SM2_START|SM2_PRETTY,'[if(sib<=sibCount){<li>[a][menu_title][/a]}][if(sib==sibCount){ <li class=\'top\'><a class=\'top_link\' href=\'[url]'>[menu_title][/a]}]','</li>','<ul>');
    show_menu2(0, SM2_ROOT, SM2_START, '', '[if(sib<sibCount){<li>[a][menu_title][/a]}][if(class==menu-last){ 		<li><a class='last'href='[url]'>[menu_title][/a]}]','</li>','<ul>');
                    <ul class='sub'>
                    <span class='subArrow'>&nbsp;</span>
      show_menu2(0, SM2_ROOT+1, SM2_CURR+1, '', '<li>[a]<span class='last'>[menu_title]', '</span></a></li>' );
                     </ul>
                    </li>
    </ul>
    <div id='header'>
    <div id='header-img'>
    <div id='content'>
    <div class='contop'>
    <div class='contitle'>
    <div class='t-content'>
    hier tekst
    <div class='concenter'>
    <div class='context'>
          <h1><?php page_title(); ?></h1>
          <?php page_content(); ?>
    <div class='conbottom'></div>
    <div id='footer'>
    <div class='copyright'>
    <div class='copytext'>
    <a href='http://rvko.nl' target=_'blank'>Een school van de RVKO </a> | Alle rechten voorbehouden | Gemaakt door: <a href='http://starohosting.nl'>Starohosting.nl </a>
    </body>
    </html>
    Ik kon het probleem niet vinden.
    Wie kan me even op weg helpen
    Alvast bedankt:cheer:
    paypal.me
    • 27 januari 2012 om 20:08
    http://www.checkupdown.com/status/E500.html
  • faff
    • 27 januari 2012 om 20:18
    heb je het scriptje zelf geschreven?
    of gedownload van iets,
    als je gedownload hebt, zou ik de uitgever contacteren =)
    Fabio Dicola
    Eigenaar van Xprojects
    Xprojects is een pas gestart bedrijf!
    en maakt gebruik van bevorderde scripters & designers.
    site: http://www.Xprojects.com/
  • Starohosting
    • 27 januari 2012 om 20:19
    Dein het ligt toch aan de webscripting wanneer ik iets anders zet krijg ik wel gewoon de layout.
    Daar zit ik dus echt mee.
    paypal.me
  • Fitim
    • 27 januari 2012 om 21:54
    Licht aan je .htaccess
  • Starohosting
    • 28 januari 2012 om 09:23
    Dat kan niet want hier staat niets in dan alleen html inlezen als php
    paypal.me
    • 28 januari 2012 om 14:34
    Dat kan ook de oorzaak zijn. Door een fout van het inlezen.
  • Fitim
    • 28 januari 2012 om 16:09
    Citaat van Starohosting
    Klopt maar het licht aan je .htaccess
  • faff
    • 28 januari 2012 om 16:28
    ik snap al wat je bedoelt :p
    dat had ik vroeger ook :p
    instaleer een ftp manager :)
    met filezilla lukt dit wel,
    maak contact met je host!
    en upload het scripthe :) dit zou lukken
    Fabio Dicola
