Opencart probleem
  • Jordy.S
  • 9 januari 2012 om 17:45
  • Jordy.S
    http://jsnet.nl/upload/
    Wat is het probleem
    het script:
    final class Image {
        private $file;
        private $image;
        private $info;
    	public function __construct($file) {
    		if (file_exists($file)) {
    			$this->file = $file;
    			$info = getimagesize($file);
    			$this->info = array(
                	'width'  => $info[0],
                	'height' => $info[1],
                	'bits'   => $info['bits'],
                	'mime'   => $info['mime']
            	$this->image = $this->create($file);
          		exit('Error: Could not load image ' . $file . '!');
    	private function create($image) {
    		$mime = $this->info['mime'];
    		if ($mime == 'image/gif') {
    			return imagecreatefromgif($image);
    		} elseif ($mime == 'image/png') {
    			return imagecreatefrompng($image);
    		} elseif ($mime == 'image/jpeg') {
    			return imagecreatefromjpeg($image);
        public function save($file, $quality = 90) {
           $info = pathinfo($file);
        $extension = strtolower($info['extension']);
            if ($extension == 'jpeg' || $extension == 'jpg') {
                imagejpeg($this->image, $file, $quality);
            } elseif($extension == 'png') {
                imagepng($this->image, $file, 0);
            } elseif($extension == 'gif') {
                imagegif($this->image, $file);
         imagedestroy($this->image);
        public function resize($width = 0, $height = 0) {
        	if (!$this->info['width'] || !$this->info['height']) {
    			return;
    		$xpos = 0;
    		$ypos = 0;
    		$scale = min($width / $this->info['width'], $height / $this->info['height']);
    		if ($scale == 1) {
    			return;
    		$new_width = (int)($this->info['width'] * $scale);
    		$new_height = (int)($this->info['height'] * $scale);
        	$xpos = (int)(($width - $new_width) / 2);
       		$ypos = (int)(($height - $new_height) / 2);
           	$image_old = $this->image;
            $this->image = imagecreatetruecolor($width, $height);
    		if (isset($this->info['mime']) && $this->info['mime'] == 'image/png') {
    			imagealphablending($this->image, false);
    			imagesavealpha($this->image, true);
    			$background = imagecolorallocatealpha($this->image, 255, 255, 255, 127);
    			imagecolortransparent($this->image, $background);
    			$background = imagecolorallocate($this->image, 255, 255, 255);
    		imagefilledrectangle($this->image, 0, 0, $width, $height, $background);
            imagecopyresampled($this->image, $image_old, $xpos, $ypos, 0, 0, $new_width, $new_height, $this->info['width'], $this->info['height']);
            imagedestroy($image_old);
            $this->info['width']  = $width;
            $this->info['height'] = $height;
        public function watermark($file, $position = 'bottomright') {
            $watermark = $this->create($file);
            $watermark_width = imagesx($watermark);
            $watermark_height = imagesy($watermark);
            switch($position) {
                case 'topleft':
                    $watermark_pos_x = 0;
                    $watermark_pos_y = 0;
                    break;
                case 'topright':
                    $watermark_pos_x = $this->info['width'] - $watermark_width;
                    break;
                case 'bottomleft':
                    $watermark_pos_y = $this->info['height'] - $watermark_height;
                    break;
                case 'bottomright':
                    break;
            imagecopy($this->image, $watermark, $watermark_pos_x, $watermark_pos_y, 0, 0, 120, 40);
            imagedestroy($watermark);
        public function crop($top_x, $top_y, $bottom_x, $bottom_y) {
            $this->image = imagecreatetruecolor($bottom_x - $top_x, $bottom_y - $top_y);
            imagecopy($this->image, $image_old, 0, 0, $top_x, $top_y, $this->info['width'], $this->info['height']);
            $this->info['width'] = $bottom_x - $top_x;
            $this->info['height'] = $bottom_y - $top_y;
        public function rotate($degree, $color = 'FFFFFF') {
    		$rgb = $this->html2rgb($color);
            $this->image = imagerotate($this->image, $degree, imagecolorallocate($this->image, $rgb[0], $rgb[1], $rgb[2]));
    		$this->info['width'] = imagesx($this->image);
    		$this->info['height'] = imagesy($this->image);
        private function filter($filter) {
            imagefilter($this->image, $filter);
        private function text($text, $x = 0, $y = 0, $size = 5, $color = '000000') {
    		imagestring($this->image, $size, $x, $y, $text, imagecolorallocate($this->image, $rgb[0], $rgb[1], $rgb[2]));
        private function merge($file, $x = 0, $y = 0, $opacity = 100) {
            $merge = $this->create($file);
            $merge_width = imagesx($image);
            $merge_height = imagesy($image);
            imagecopymerge($this->image, $merge, $x, $y, 0, 0, $merge_width, $merge_height, $opacity);
    	private function html2rgb($color) {
    		if ($color[0] == '#') {
    			$color = substr($color, 1);
    		if (strlen($color) == 6) {
    			list($r, $g, $b) = array($color[0] . $color[1], $color[2] . $color[3], $color[4] . $color[5]);
    		} elseif (strlen($color) == 3) {
    			list($r, $g, $b) = array($color[0] . $color[0], $color[1] . $color[1], $color[2] . $color[2]);
    			return false;
    		$r = hexdec($r);
    		$g = hexdec($g);
    		$b = hexdec($b);
    		return array($r, $g, $b);
    Bezig met Eredivisie Voetbal project.
    (Tips zijn altijd welkom!)
    • 9 januari 2012 om 17:47
    Je hosting heeft jou op safe mode gezet waardoor het niet werkt.
  • Jordy.S
    • 9 januari 2012 om 17:48
    Ik kan hier bij komen, hoe verander ik dit?
  • mediazstudios
    Jou safe mode moet je uitzetten of je vraagt het aan de hoster...
    Mohamed Bourjel
    Mediazstudios / Audiovisuele & Grafische vormgeving
    Goodhosted / De no-nonsense webhosting provider
    kvk:53265025
  • Malik
    • 9 januari 2012 om 17:50
    via directadmin kan het of anders via de helpdesk.
  • Jordy.S
    • 9 januari 2012 om 17:56
    Ik heb plesk
    • 9 januari 2012 om 18:00
    Google het ;)
    En anders vraag je hoster ;)
  • mediazstudios
    • 9 januari 2012 om 22:17
    Oke een stappenplan voor jou gemaakt...
    Ga eerst naar domeinen...
    - Bij domeinen kies je jouw domein uit..
    Zodra je daar bent druk je op webhosting instellingen..
    Dan zie je onder SSI support / PHP support staan...
    Daar zie je dan het vinkje naast PHP'safe_mode' aan staan klik die uit en jou probleem is verholpen...
    Mohamed Bourjel
    kvk:53265025
  • 5 Gasten
