Gezocht index crimesource v20
  • Crimworld
  • 29 oktober 2010 om 10:42
  • Crimworld
    Ik zoek een index.php voor crimesource v20 kan iemand dit voor mij doen ?
  • Rahl
    Gevallen leider
    • 29 oktober 2010 om 10:47
    Al op Google gezocht?
  • Fitim
    • 29 oktober 2010 om 10:50
    Dit is van crimesource v1.3 (Is niet gecodereerd) De 2 indexen zijn dacht ik het zelfde, Hier is ie:
      include("_include-config2.php");
      $dbres				= mysql_query("SELECT `id` FROM `[users]` WHERE `activated`=1");
      $leden				= mysql_num_rows($dbres);
      $dbres2                                = mysql_query("SELECT `id` FROM `[users]` WHERE UNIX_TIMESTAMP(NOW())-UNIX_TIMESTAMP(`online`) < 300");
      $online                                = mysql_num_rows($dbres2);
      $laatstelid = mysql_query("select `login` from `[users]` order by id desc limit 0,3");
      $laatste = @mysql_result($laatstelid,0,0);
    	$hoogsterank = mysql_query("SELECT * FROM `[users]` WHERE `activated`>=0 ORDER BY rank DESC LIMIT 0,1");
    	$meestepower = mysql_query("SELECT * FROM `[users]` WHERE `activated`>=0 ORDER BY attack DESC LIMIT 0,1");
    	$meesterespect = mysql_query("SELECT * FROM `[users]` WHERE `activated`>=0 ORDER BY respect DESC LIMIT 0,1");
      if(isset($_POST['login'],$_POST['pass'])) {
        $dbres				= mysql_query("SELECT `login`,`activated` FROM `[users]` WHERE `login`='{$_POST['login']}' AND `pass`=MD5('{$_POST['pass']}')");
        if(($data = mysql_fetch_object($dbres)) && $data->activated == 1) {
          $validate				= md5(rand(0,1000));
          setcookie("login",$data->login,time()+60*60*24,"/","");
          setcookie("validate",$validate,time()+60*60*24,"/","");
          mysql_query("REPLACE INTO `[online]`(`time`,`login`,`IP`,`validate`) values(NOW(),'{$_SERVER['REMOTE_ADDR']}','{$data->login}','$validate')");
          $_SESSION['login']		= $data->login;
          $_SESSION['IP']			= $_SERVER['REMOTE_ADDR'];
          $dbres				= mysql_query("SELECT *,UNIX_TIMESTAMP(`signup`) AS `signup` FROM `[users]` WHERE `login`='{$_SESSION['login']}'");
          $_SESSION['data']			= mysql_fetch_object($dbres);
    <html>
    <head>
    <title><?php echo $page->sitetitle; ?></title>
    <link rel="stylesheet" type="text/css" href="<? echo $sitelink;?>/layout/intro/css/css.css">
    <link rel="shortcut icon" href="ico.ico" type="image/ico" />
    <link rel="icon" href="ico.ico" type="image/ico" />
    <style type="text/css">
    	#tdColGauche{background: #5a0303 url(layout/intro/images/tiles/blood5.gif) repeat;}
    	#tdColCentre{background: url(layout/intro/images/tiles/trousballes5.jpg) no-repeat top left;}
    	#tdColCentre.special{background: url(layout/intro/images/tiles/trousballes5_special.jpg) no-repeat top left;}
    	#tdColDroite{background: #2e2723 url(layout/intro/images/tiles/city5.jpg);}
    </style><script language="javascript" type="text/javascript" src="js/string.js"></script>
    <script language="javascript" type="text/javascript" src="js/functions.js"></script>
    <script language="javascript" type="text/javascript" src="js/text_counter.js"></script>
    <script language="javascript" type="text/javascript" src="js/swfobject.js"></script>
    <script type="text/JavaScript">
    function MM_swapImgRestore() { //v3.0
    var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
    function MM_preloadImages() { //v3.0
    var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
    var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
    if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
    function MM_findObj(n, d) { //v4.01
    var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
    d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
    if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
    for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
    if(!x && d.getElementById) x=d.getElementById(n); return x;
    function MM_swapImage() { //v3.0
    var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
    if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
    <body onLoad="MM_preloadImages('layout/intro/images/index_boutonLogRoll.jpg','layout/intro/images/index_boutonRegisterRoll.jpg')">
    <div id="index">
      <div id="indexContent">
        <div id="group"></div>
       	<!-- Formulaire de login -->
    	<div id="loginBox">
    			<form method="POST" action="login.php" id="loginForm">
    		  <input type="hidden" name="action" value="userLogin" />
    		  <label for="gebruikersnaam">Username		  <input tabIndex="1" name="login" type="text" maxlength="15" value="" class="width2"/>
    		  </label>
    		  <label for="wachtwoord">Password		  <input tabIndex="2" name="pass" type="password" maxlength="25" value="" class="width2" />
    		  </label>
    		  <input type="image" src="layout/intro/images/bt_play_en_off.gif" name="submit" id="play" onMouseOver="MM_swapImage('play','','layout/intro/images/bt_play_en_on.gif',1)" onMouseOut="MM_swapImgRestore()"  onclick="this.form.submit();" class="nobg" />
    		<ul class="inlineLinks">
    					</ul>
    	<!-- Bouton register -->
        <div id="registerBox">
         <!-- <h3>Story</h3>-->
          <p class="inlineLinks">
      $login					= $_POST['login'];
      $pass                     = $_POST['pass'];
      $passconfirm              = $_POST['passconfirm'];
      $city						= $_POST['stad'];
      $email					= $_POST['email'];
      $recruiter					= $rec;
      $IP						= $_SERVER['REMOTE_ADDR'];
      if(isset($_POST['submit'])) {
        $message					= Array(
    	"<b>Je login mag alleen A-Z, a-z, 0-9, _ en - hebben</b><BR><BR>",
       	"<b>De wachtwoorden die je gaf zijn niet identiek</b><BR><BR>",
    	"<b>Vul een geldig e-mail adres in</b><BR><BR>",
    	"<b>Selecteer een type crimineel</b><BR><BR>",
    	"<b>Er bestaat al iemand met die login</b><BR><BR>",
    	"<b>Er is al iemand met die e-mail</b><BR><BR>",
    	"<b>De login van je recruiter mag alleen A-Z, a-z, 0-9, _ en - in de naam hebbben</b><BR><BR>",
            "<b>Er is al een account in gebruik op deze computer!</b><BR><BR>");
        $msgnum					= -1;
        if(preg_match('/^[a-zA-Z0-9_\-]+$/',$login) == 0)
          $msgnum					= 0;
          if($pass == "" || $pass != $passconfirm)
          $msgnum					= 1;
        if(preg_match('/^.+@.+\..+$/',$email) == 0)
          $msgnum					= 2;
        else {
          $dbres					= mysql_query("SELECT `id` FROM `[users]` WHERE `login`='{$login}'");
          if(mysql_num_rows($dbres) > 0)
            $msgnum					= 4;
          $dbres					= mysql_query("SELECT `id` FROM `[users]` WHERE `email`='{$email}'");
        $msgnum					= 5;
    	 $dbres					= mysql_query("SELECT `id` FROM `[users]` WHERE `ip`='{$_SERVER['REMOTE_ADDR']}'");
        $msgnum					= 8;
            $msgnum					= 6;
            $msgnum                                 = 7;
          if($msgnum == -1) {
            mysql_query("UPDATE `[users]` SET `recruits`=`recruits`+'1' WHERE `login`='{$recruiter}'");
            mysql_query("UPDATE `[users]` SET `cash`=`cash`+'100000' WHERE `login`='{$recruiter}'");
    if($rec != "") {
            mysql_query("INSERT INTO `[messages]`(`time`,`from`,`to`,`subject`,`message`,`outbox`) values(NOW(),'$page->sitetitle','$recruiter','Referal','Je hebt een lid laten aanmelden op $page->sitetitle! je hebt &euro;100.000 contant geld van $page->sitetitle gekregen!','0')");
            mysql_query("INSERT INTO `[users]`(signup,login,pass,IP,email,land) values(NOW(),'$login',MD5('$pass'),'$IP','$email','$city')") or die (mysql_error());
            $id					= mysql_insert_id();
            mail($email,"$page->sitetitle - Account","$page->sitetitle - Account.
    Beste $login
    Hieronder staan uw login-gegevens vermeld.
    Login        = $login
    E-mail adres = $email
    Wachtwoord   = $pass
    Als een van de volgende gegevens niet juist zijn, kunt u dat melden aan een van de admins.
    Met bovenstaande gegevens kun je nu inloggen op $page->sitetitle ($sitelink).
    Voordat u begint met spelen willen wij u verzoeken eerst onderstaande regels door te lezen:
    -Spammen is niet toegestaan (meerdere berichjes met dezelfde inhoud rondsturen)
    -Het bedreigen en/of het beledigen word niet geaccepteerd.
    -Het gebruik van proxies is verboden.
    -Het is niet toegestaan om meerdere accounts te hebben, maar dat is als het goed is ook niet meer mogelijk (Broertjes, Zusjes? Neem contact op met een Admin).
    -Het maken van reclame word niet getollereerd en zal worden bestraft met een onvoorwaardelijke ban.
    Als laatste verzoeken wij u, het ontdekken een bug te melden aan 1 van de admins.
    Verzwijgen van een bug is niet strafbaar, het misbruik maken ervan wel.
    Uitgaande dat deze regels U volkomen duidelijk zijn, wensen wij U veel speel plezier op $page->sitetitle.
    Het $page->sitetitle Team.","From: $page->sitetitle <$sitelink");
      if(isset($_GET['id'],$_GET['code'])) {
        print "  <tr><td class=\"subTitle\"><b>Activatie</b></td></tr>\n";
        $id						= $_GET['id'];
        $code					= $_GET['code'];
        $dbres					= mysql_query("SELECT `login` FROM `[temp]` WHERE `area`='signup' AND `id`='$id' AND `code`='$code'");
        if($data = mysql_fetch_object($dbres)) {
    	$acti = 1;
    	mysql_query("UPDATE `[users]` SET `activated`=1,`signup`=NOW() WHERE `login`='{$login}'");
          mysql_query("DELETE FROM `[temp]` WHERE `id`='{$id}'");
          print "  <tr><td class=\"mainTxt\">Activatie voltooid, je kunt nu inloggen</td></tr>\n";
          print "  <tr><td class=\"mainTxt\">Incorrecte activatie-code...</td></tr>\n";
      else {
        if($msgnum != -1) {
          if(isset($msgnum) && $msgnum != -1)
            print "{$message[$msgnum]}\n";
            $rec = $_GET['rec'];
        print "  <TR><Td><br>&nbsp;</td></tr><tr><td class=\"subTitle\">
    		<b>Welkom op $page->sitetitle</b><BR>
    Meld je nu direct aan, speel samen met vele andere gangsters en maak kans op fantastische prijzen!
    </td></tr>\n";
          print <<<ENDHTML
    <div id="regBox">
      <tr><td class="mainTxt">
    	<form method="post" id="regForm" name="regForm" ><table align="center" class="2">
     	  <tr><td width=100><font size="2"><b>Login:</b><font color=red>*</td>		<td><input type="text" name="login" maxlength=16 style="width: 150;" value="$login"></td></tr>
              <tr><td width=100><font size="2"><b>Password:</b><font color=red>*</font></td>        <td><input type="password" name="pass" maxlength=16 style="width: 150;" ;"></td></tr>
              <tr><td width=100><font size="2"><b>Herhaal:</b><font color=red>*</font></td>        <td><input type="password" name="passconfirm" maxlength=16 style="width: 150;" ;"></td></tr>
    	  <tr><td width=100><font size="2"><b>E-Mail:</b><font color=red>*</td>	<td><input type="text" name="email" maxlength=64 style="width: 150;" value="$email"></td></tr>
              <tr><td width=100><font size="2"><b>Land:<font color=red>*</td>		<td><select name="stad" style="width: 150;">
    	  			<option value="1">Nederland</option>
    	  			<option value="2">Frankrijk</option>
    	  			<option value="3">Cuba</option>
    	  			<option value="4">Rusland</option>
    	  			<option value="5">Australie</option>
    	  			<option value="6">VS</option>
    						</select></td></tr>
    	  <tr><td width=100><font size="2"><b>Recruiter:</b></td>	<td><input type="text" CONTENTEDITABLE ="false" name="recruiter" maxlength=64 style="width: 150;" value="$rec"></td></tr>
    	  <tr><td></td><td align="center"> <input class="2" type="submit" name="submit" style="width: 100;" value="Aanmelden"></td></tr>
    	</table></form><br>
    ENDHTML;
          print "<tr><td class=\"subTitle\">Aangemeld</td></tr>
    <tr><td class=\"mainTxt\">SuccesVol.<br><br>
    Je bent geregistreerd bij <b>$page->sitetitle</b>, Je kunt nu meteen in loggen.</td></tr>\n";
    					</ul>
      <p id="footer">
    Leden: <?=$leden?> - Online: <?=$online?> - Nieuwste: <?=$laatste?> - <a HREF="login.php?x=lostpass">Wachtwoord vergeten: reset uw wachtwoord</a>
    <BR>
    //Copyright variabelen instellen
    $beginjaar = '2007'; // Beginjaar van je site
    $jaar = date ("Y");  //Ophalen systeemjaar
    $jaar2 = $jaar + 1;  //jaar2 = jaar + 1
    $bedrijfsnaam = ''; //Bedrijfsnaam website
    $rechten = ''; //Neerzetten rechten
    echo ' &copy' . ' ' . $beginjaar . ' - ' . $jaar . ' - ' . $bedrijfsnaam;
    ?> <?php echo $page->sitetitle; ?>
    	  </p>
    </body>
    </html>
    Ik hoop dat je er wat aan hebt.
    Met Vriendelijke Groet,
    Ajeti.
  • Crimworld
    • 29 oktober 2010 om 10:54
    Hartelijk bedankt :)
  • Fitim
    • 29 oktober 2010 om 10:56
    Citaat van Crimworld
    En is het gelukt?
  • Crimworld
    • 29 oktober 2010 om 12:15
    Ik moet alleen nog database :P moet dus nog even emand zoeken
  • cri
    • 29 oktober 2010 om 12:53
    [offtopic]Had hem gepost, maar is verwijderd en bericht van moderator kan ik niet openen.[/offtopic]
    zwpgangster, dus hij moet van u de gehele database beginnen te maken, voor de hele source....
    Crimworld u heeft pm
  • Fitim
    • 29 oktober 2010 om 14:02
    Ik stuurde op msn de gehele source.
    incl. de db (a)
  • Nillas
    NJMedia
    • 27 augustus 2011 om 12:21
    Jongens, kijk ff naar de datum van dit topic.
    • 27 augustus 2011 om 18:39
    Bumpen van een topic ouder dan 14 dagen is niet toegestaan op CP.
