Uploadscript
  • RDMNL2010
  • 11 oktober 2010 om 17:22
  • RDMNL2010
    webbasing.com
    Beste leden van Criminalspoint,
    Ik ben al een tijdje bezig hiermee met een script om MP3 bestanden te uploaden.
    Nu wil het niet lukken... Ik heb in me php.ini me max_file_size al veranderd naar 8M (8mb) dus.
    hieronder het script..
    if (isset($_POST['submit']))
    echo "Please wait while we attempt to upload your file...<br><br>";
    $target_path = "upload/";
    $flag = 0; // Safety net, if this gets to 1 at any point in the process, we don't upload.
    $filename = $_FILES['uploadedfile']['name'];
    $filesize = $_FILES['uploadedfile']['size'];
    $mimetype = $_FILES['uploadedfile']['type'];
    $filename = htmlentities($filename);
    $filesize = htmlentities($filesize);
    $mimetype = htmlentities($mimetype);
    $target_path = $target_path . basename( $filename );
    if($filename != ""){
    echo "Beginning upload process for file named: ".$filename."<br>";
    echo "Filesize: ".$filesize."<br>";
    echo "Type: ".$mimetype."<br><br>";
    //First generate a MD5 hash of what the new file name will be
    //Force a MP3 extention on the file we are uploading
    $hashedfilename = md5($filename);
    $hashedfilename = $hashedfilename.".mp3";
    //Check for empty file
    if($filename == ""){
    $error = "No File Exists!";
    $flag = $flag + 1;
    //Now we check that the file doesn't already exist.
    $existname = "upload/".$hashedfilename;
    if(file_exists($existname)){
    if($flag == 0){
    $error = "Your file already exists on the server!
    Please choose another file to upload or rename the file on your
    computer and try uploading it again!";
    $flag = $flag + 1;
    //Whitelisted files - Only allow files with MP3 extention onto server...
    $whitelist = array(".mp3");
    foreach ($whitelist as $ending) {
    if(substr($filename, -(strlen($ending))) != $ending) {
     $error = "The file type or extention you are trying to upload is not allowed!
    You can only upload MP3 files to the server!";
    $flag++;
    //Now we check the filesize.  If it is too big or too small then we reject it
    //MP3 files should be at least 1MB and no more than 6.5 MB
    if($filesize > 6920600){
    //File is too large
    if($flag == 0){
    $error = "The file you are trying to upload is too large!
    Your file can be up to 6.5 MB in size only.
    Please upload a smaller MP3 file or encode your file with a lower bitrate.";
    $flag = $flag + 1;
    if($filesize < 1048600){
    //File is too small
    if($flag == 0){
    $error = "The file you are trying to upload is too small!
    Your file has been marked as suspicious because our system has
    determined that it is too small to be a valid MP3 file.
    Valid MP3 files must be bigger than 1 MB and smaller than 6.5 MB.";
    $flag = $flag + 1;
    //Check the mimetype of the file
    if($mimetype != "audio/x-mp3" and $mimetype != "audio/mpeg"){
    if($flag == 0){
    $error = "The file you are trying to upload does not contain expected data.
    Are you sure that the file is an MP3?";
    $flag = $flag + 1;
    //Check that the file really is an MP3 file by reading the first few characters of the file
    $f = @fopen($_FILES['uploadedfile']['tmp_name'],'r');
    $s = @fread($f,3);
    @fclose($f);
    if($s != "ID3"){
    if($flag == 0){
    $error = "The file you are attempting to upload does not appear to be a valid MP3 file.";
    $flag++;
    //All checks are done, actually move the file...
    if($flag == 0){
    if(move_uploaded_file($_FILES['uploadedfile']['tmp_name'], $target_path)) {
        //Change the filename to MD5 hash and FORCE a MP3 extention.
        if(@file_exists("upload/".$filename)){
        //Rename the file to an MD5 version
        rename("upload/".$filename, "upload/".$hashedfilename);
        echo "The file ".  basename( $filename ). "
          has been uploaded.  Your file is <a href='uploads/$hashedfilename'>here</a>.";
        else{
          echo "There was an error uploading the file, please try again!";
    } else{
    else {
    echo "File Upload Failed!<br>";
    if($error != ""){
    echo $error;
    <form action="" method="POST" enctype="multipart/form-data">
    Browse file to upload <input type="file" name="filetoupload" id="filetoupload"><br/>
    <input type="submit" name="submit"  value="Upload now">
    hopelijk dat iemand weet wat hier fout aan is
    map upload is al gechmod naar 755 dus dit is niet het probleem;)
    Webbasing.com
  • Superior
    • 11 oktober 2010 om 17:26
    Handig als je vermeld wat niet werkt, eventuele fouten ?
  • RDMNL2010
    webbasing.com
    • 11 oktober 2010 om 17:27
    Ja sorry vergeten,
    Het probleem is dus dat ie geen fouten aangeeft.. maar ook niks upload. Als ik op de knop Upload now klik dan laad ie (dit duurt een minuutje ofzo) en daarna is het gewoon klaar.. zonder enige melding.
    En als ik dan op me server kijk staat er dus niks in de map upload.
    Webbasing.com
  • Superior
    • 11 oktober 2010 om 17:28
    Staat de error report helemaal aan of gedeeltelijk ?
  • RDMNL2010
    webbasing.com
    ik heb het overigens ook met dit scriptje geprobeerd
    en deze deed het ook niet.:
    overigens .png afbeeldingen e.d. doet deze wel;)
    if(isset($_POST['sb'])) {
        $path = "../muziek";
        $file = $_FILES['filetoupload']['name'];
        move_uploaded_file($_FILES['filetoupload']['tmp_name'], "$path/$file");
    <input type="submit" name="sb" id="sb" value="Upload now">
    Nieuwe reactie samengevoegd met originele reactie op 11.10.10 17:29:01:
    error report staat helemaal aan
    Citaat van Superior
    Nieuwe reactie samengevoegd met originele reactie op 11.10.10 17:56:12:
    oke probleem is opgelost.. gewoon effe een simpele .htaccess code toegevoegd voor de file size blijkbaar werkt dit beter als het veranderen in me php.ini.
    Webbasing.com
  • R.Jipping
    ex Administrator
    • 11 oktober 2010 om 18:07
    op aanvraag gesloten
