layout inbouwen
  • Dj-Marlon
  • 30 november 2010 om 12:41
  • Dj-Marlon
    Leerling
    • 30 november 2010 om 17:22
    klopt en onderaan
    en de pagina staat nu links normaal is die in het midden.
  • RDMNL2010
    webbasing.com
    • 30 november 2010 om 17:23
    omg... weet je wel wat PHP is?? hoe het werkt?
    Webbasing.com
  • Dj-Marlon
    Leerling
    • 30 november 2010 om 17:27
    ja ik weet hoe t ongeveer werkt.
    leg me uit wat ik verkeerd doe.
    if (isset($data))
      //hier ingame
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    <title>DemonicEvil.nl</title>
    <link href="css/style.css" rel="stylesheet" type="text/css" />
    <body>
    <div id="header">
      <div class="marquee">
        <marquee>
        Demonic evil is currently under progress
        </marquee>
    <!-- end header -->
    <div id="wrapper">
      <div class="leftside">
        <div id="menu">
          <div class="menutop">
            <div class="menutoptext"><b>Navigatie</b></div>
          <div class="menucenter">
            <div class="menutext">
              <ul>
                <li><a href="index.html">Home</a></li>
                <li><a href="index.html">Over demonicevil</a></li>
                <li><a href="index.html">Register</a></li>
                <li><a href="index.html">Downloaden</a></li>
                <li><a href="index.html">Contact</a></li>
              </ul>
          <div class="menubottom"></div>
          <div id="menu2">
            <div class="menu2top">
              <div class="menu2toptext"><b>Navigatie 2</b></div>
            <div class="menu2center">
                <ul>
                </ul>
            <div class="menu2bottom"></div>
        <!-- end left side -->
      <div id="content">
        <div class="pagetop">
          <div class="pagetoptext"><b>lorem ipsum</b></div>
        <div class="pagecenter">
          <div class="pagetext"> <strong>Lorem Ipsum</strong> is simply dummy text of the printing and   typesetting industry. Lorem Ipsum has been the industry's standard dummy text   ever since the 1500s, when an unknown printer took a galley of type and   scrambled it to make a type specimen book. It has survived not only five   centuries, but also the leap into electronic typesetting, remaining essentially   unchanged. It was popularised in the 1960s with the release of Letraset sheets   containing Lorem Ipsum passages, and more recently with desktop publishing   software like Aldus PageMaker including versions of Lorem Ipsum. </div>
        <div class="pagebottom"></div>
      <div id="content2">
        <div class="pagetop2">
        <div class="pagecenter2">
          <div class="pagetext"> Contrary to popular belief, Lorem Ipsum is not simply random text. It has   roots in a piece of classical Latin literature from 45 BC, making it over 2000   years old. Richard McClintock, a Latin professor at Hampden-Sydney College in   Virginia, looked up one of the more obscure Latin words, consectetur, from a   Lorem Ipsum passage, and going through the cites of the word in classical   literature, discovered the undoubtable source. Lorem Ipsum comes from sections   1.10.32 and 1.10.33 of &quot;de Finibus Bonorum et Malorum&quot; (The Extremes of Good and   Evil) by Cicero, written in 45 BC. This book is a treatise on the theory of   ethics, very popular during the Renaissance. The first line of Lorem Ipsum,   &quot;Lorem ipsum dolor sit amet..&quot;, comes from a line in section 1.10.32.
            The standard chunk of Lorem Ipsum used since the 1500s is reproduced below   for those interested. Sections 1.10.32 and 1.10.33 from &quot;de Finibus Bonorum et   Malorum&quot; by Cicero are also reproduced in their exact original form, accompanied   by English versions from the 1914 translation by H. Rackham. </div>
        <div class="pagebottom2"></div>
      <!-- end wrapper -->
    </body>
    </html>
  • Robin
    • 30 november 2010 om 17:37
    Doe dit:
    if (isset($data))
      //hier ingame
    <head>
    <body>
    <div id="header">
        <marquee>
        </marquee>
    <!-- end header -->
    <div id="wrapper">
        <div id="menu">
              <ul>
              </ul>
          <div id="menu2">
                <ul>
                </ul>
      <div id="content">
          <div class="pagetext"> <strong>Lorem Ipsum</strong> is simply dummy text of the printing and   typesetting industry. Lorem Ipsum has been the industrys standard dummy text   ever since the 1500s, when an unknown printer took a galley of type and   scrambled it to make a type specimen book. It has survived not only five   centuries, but also the leap into electronic typesetting, remaining essentially   unchanged. It was popularised in the 1960s with the release of Letraset sheets   containing Lorem Ipsum passages, and more recently with desktop publishing   software like Aldus PageMaker including versions of Lorem Ipsum. </div>
      <div id="content2">
          <div class="pagetext"> Contrary to popular belief, Lorem Ipsum is not simply random text. It has   roots in a piece of classical Latin literature from 45 BC, making it over 2000   years old. Richard McClintock, a Latin professor at Hampden-Sydney College in   Virginia, looked up one of the more obscure Latin words, consectetur, from a   Lorem Ipsum passage, and going through the cites of the word in classical   literature, discovered the undoubtable source. Lorem Ipsum comes from sections   1.10.32 and 1.10.33 of "de Finibus Bonorum et Malorum" (The Extremes of Good and   Evil) by Cicero, written in 45 BC. This book is a treatise on the theory of   ethics, very popular during the Renaissance. The first line of Lorem Ipsum,   "Lorem ipsum dolor sit amet..", comes from a line in section 1.10.32.
            The standard chunk of Lorem Ipsum used since the 1500s is reproduced below   for those interested. Sections 1.10.32 and 1.10.33 from "de Finibus Bonorum et   Malorum" by Cicero are also reproduced in their exact original form, accompanied   by English versions from the 1914 translation by H. Rackham. </div>
    </body>
    </html>
  • Dj-Marlon
    Leerling
    • 30 november 2010 om 17:43
    Robin hartelijk dank voor je hulp.
    Nu is alles goed.
    Zoals blijkt ben ik de php tags vergeten.
  • eeyk
    Crime-ware.nl
    • 30 november 2010 om 18:16
    Dj-Marlon je kunt dit ook doen met
    Print <<<ENDHTML
    out game html
    ENDHTML;
    dan hoef je niet steeds lelijk <?php ?> te openen en dichten
    • 30 november 2010 om 18:22
    Endhtml is zo ouderwets, echo gast, echo (php hé)
  • Dj-Marlon
    Leerling
    • 30 november 2010 om 18:26
    ja echo kan ook.
    maar ik wil t met een index.php?do=pagina doen.
    Dus dan is het makkelijk te doen met sessies.
    print kan ook gebruikt worden das zo beetje het zelfde als echo alleen kom je dan weer terrecht met endhtml
    • 30 november 2010 om 18:32
    • #29
    Waar halen jullie die onzin vandaan?
    Print <<<ENDHTML is php 3 en is dus niet meer aangerademn te gebruiken.
    je hebt verder:
    - echo 'tekst';
    - echo "tekst";
    - print 'tekst';
    - print "tekst";
    Alsjeblieft.
  • 4 Gasten
